Body Kits
Revision as of 15:31, 13 November 2011 by Grrrmachine (talk | contribs)
Bodykits
Hartge H26/H27
Description Fitted to the facelifted Hartge models, H26 and H27
Features Fitting Picture
Tech 2
Description Fitted to the facelifted 325i Sport in 1988-1991.
Bumper Fitting Guide
Front Valance
Skirts 2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number.
Rear Bumper
Lips
Name Fitted To Features Fitting Picture
Pre-facelift Lip
Facelift Lip
iS Lip
Volvo Lip
Side Skirts
SE Skirts The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. However, there's nothing preventing you from fitting these to your own E30. Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
