Fuel
Revision as of 12:48, 3 November 2011 by Grrrmachine (talk | contribs)
Fuel Tank
Filler Pipe
To check the filler pipe for leaks, lift the rear o/s wheel and slide under the car. Locate the filler pipe coming from the rear wing. Grab the joining rubber pipe to the tank stub and pull it downwards.
Either the rubber pipe will pull off or fall apart, or you will see the filler stub on the tank move on it's brazed join to the tank. The rubber pipe can be replaced cheaply, but if the filler stub moves then the entire tank will have to be replaced.
Fuel Pump
Fuel Level Senders
Fuel Filter
Fuel Lines
Fuel Hoses
Fuel Rail
Injectors
The injectors are the exit point of the fuelling system. They are electrically-operated solenoids which, when activated, squirt fuel at such high pressures that it atomises into a fine mist, which is the most efficient form for it to burn.
Fuel Pressure Regulator
Carbon Canister
Controlling
Fuel Pump Relay
No Fuel to Engine
If spark is definitely present, the test to see if any fuel is reaching your engine is to detatch one of the hoses in the engine bay, put the end into a container (such as a water bottle) and then crank the engine. If fuel gets to the bottle, you have fuel. To do this:
  • Depressurise the system by removing Fuse 11 and cranking the engine
  • Undo the jubilee clip to the nearest accesible hose, pull the hose off and put the end into a securely-placed container
  • Replace Fuse 11
  • Check the bottle
  • Check Fuse 11
Fuel Smell (Inside)
Fuel Smell (Outside)
Fuel Leak
Fuel Leaks
Leak Location Cause Solution
Rich Running
Flooding
Cold Start
Hot Start
None at this time.
Diesel
Main article: Diesel
