Technical
Revision as of 17:49, 22 September 2011 by Grrrmachine (talk | contribs)
E30 Technical
Engines
Name Volume Engine Valvetrain Fuel Output Torque Engine code Years
316 1766cc 4cyl SOHC 8V Petrol 99hp (66kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M10B18 1982–1990
316i 1596cc 4cyl SOHC 8V Petrol 102hp (75kW) @4500 rpm 105ft/lb (140Nm) @4250 rpm M40B16 1988–1995
318 1766cc 4cyl SOHC 8V Petrol 104hp (77kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M10B18 1982–1990
318i 1796cc 4cyl SOHC 8V Petrol 113hp (85kW) @4500 rpm 122ft/lb (165Nm) @4250 rpm M40B18 1987–1995
318iS 1766cc 4cyl SOHC 8V Petrol 140hp (104kW) @4500 rpm 127ft/lb (172Nm) @4250 rpm M42B18 1989–1991
320i 1766cc 6cyl SOHC 12V Petrol 123hp (92kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm M20B20 1982–1985
320i 1766cc 6cyl SOHC 12V Petrol 127hp (95kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm M20B20 1985–1991
320iS 1990cc 4cyl DOHC 16V Petrol 192hp (143kW) @6750 rpm 155ft/lb (210Nm) @4750 rpm S14 1982–1990
323i 1766cc 6cyl SOHC 12V Petrol 139-150hp (104-110kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm M20B23 1982–19850
325e 1766cc 6cyl SOHC 12V Petrol 101hp (75kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M20B16 1982–1990
325i 1766cc 6cyl SOHC 12V Petrol 101hp (75kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M20B25 1982–1990
325iX 1766cc 6cyl SOHC 12V Petrol 101hp (75kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M20B16 1982–1990
M3 2302cc 4cyl DOHC 16V Petrol 197hp (147kW) @6750 rpm 176ft/lb (0Nm) @4750 rpm S14 1986–1988
M3 2302cc 4cyl DOHC 16V Petrol 212hp (158kW) @6750 rpm 170ft/lb (0Nm) @4600 rpm S14 1989–1991
M3 Evolution 2302cc 4cyl DOHC 16V Petrol 197hp (147kW) @6750 rpm 176ft/lb (0Nm) @4750 rpm S14 1987–1987
M3 Evolution II 2302cc 4cyl DOHC 16V Petrol 217hp (162kW) @6750 rpm 181ft/lb (0Nm) @4750 rpm S14 1988–1988
M3 Sport Evolution 2467cc 4cyl DOHC 16V Petrol 235hp (175kW) @6750 rpm 177ft/lb (0Nm) @4750 rpm S14 1990–1990
324d 2443cc 6cyl SOHC 12V Diesel 84hp (63kW) @4600 rpm 112ft/lb (152Nm) @2400 rpm M21D24 1985–1993
324td 2443cc 6cyl SOHC 12V Diesel 114hp (85kW) @4800 rpm 162ft/lb (220Nm) @2400 rpm M21D24 1985–1993
Maintenance
All engines need looking after, and while simple jobs like Oil Changes are standard to all E30s, some jobs are specific to either the 4-cylinder or 6-cylinder engines. Click on the engine model for your car to get specific information.
Engine Swaps
M50 M52 M30
Gearbox and Differential
The following were fitted to each E30:
For more information on the E30 braking system, check the Brakes.
Maintenance
If needed, E30 brakes can be improved in a number of ways. While some choose to upgrade to rear discs, others prefer to use bigger discs and callipers from newer BMWs, which necessitates an upgrade to a 5-bolt hub.
Suspension and Steering
Maintenance
Over time, the rubber suspension components will dry out, harden and perish. This inevitable deterioration means that all the bushes will need replacing at some point. Renovating the bushes with original rubber components will dramatically improve the ride quality,
Body Styles and Fittings
The E30 was offered in a number of body styles. A 2-door and 4-door Saloon, Cabriolet and Touring
Maintenance
Electrical
Maintenance
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
Table Title
First Column Header Second Column Header Third Column Header
We Love E30s
Old Skool Cool
