Technical
E30 Technical
Engines
| Name | Volume | Engine | Valvetrain | Fuel | Output | Torque | Engine code | Years |
| 316 | 1766cc | 4cyl | SOHC 8V | Petrol | 99hp (66kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M10B18 | 1982–1990 |
| 316i | 1596cc | 4cyl | SOHC 8V | Petrol | 102hp (75kW) @4500 rpm | 105ft/lb (140Nm) @4250 rpm | M40B16 | 1988–1995 |
| 318 | 1766cc | 4cyl | SOHC 8V | Petrol | 104hp (77kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M10B18 | 1982–1990 |
| 318i | 1796cc | 4cyl | SOHC 8V | Petrol | 113hp (85kW) @4500 rpm | 122ft/lb (165Nm) @4250 rpm | M40B18 | 1987–1995 |
| 318iS | 1766cc | 4cyl | SOHC 8V | Petrol | 140hp (104kW) @4500 rpm | 127ft/lb (172Nm) @4250 rpm | M42B18 | 1989–1991 |
| 320i | 1766cc | 6cyl | SOHC 12V | Petrol | 123hp (92kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | M20B20 | 1982–1985 |
| 320i | 1766cc | 6cyl | SOHC 12V | Petrol | 127hp (95kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | M20B20 | 1985–1991 |
| 320iS | 1990cc | 4cyl | DOHC 16V | Petrol | 192hp (143kW) @6750 rpm | 155ft/lb (210Nm) @4750 rpm | S14 | 1982–1990 |
| 323i | 1766cc | 6cyl | SOHC 12V | Petrol | 139-150hp (104-110kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | M20B23 | 1982–19850 |
| 325e | 1766cc | 6cyl | SOHC 12V | Petrol | 101hp (75kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M20B16 | 1982–1990 |
| 325i | 1766cc | 6cyl | SOHC 12V | Petrol | 101hp (75kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M20B25 | 1982–1990 |
| 325iX | 1766cc | 6cyl | SOHC 12V | Petrol | 101hp (75kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M20B16 | 1982–1990 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | S14 | 1986–1988 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 212hp (158kW) @6750 rpm | 170ft/lb (0Nm) @4600 rpm | S14 | 1989–1991 |
| M3 Evolution | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | S14 | 1987–1987 |
| M3 Evolution II | 2302cc | 4cyl | DOHC 16V | Petrol | 217hp (162kW) @6750 rpm | 181ft/lb (0Nm) @4750 rpm | S14 | 1988–1988 |
| M3 Sport Evolution | 2467cc | 4cyl | DOHC 16V | Petrol | 235hp (175kW) @6750 rpm | 177ft/lb (0Nm) @4750 rpm | S14 | 1990–1990 |
| 324d | 2443cc | 6cyl | SOHC 12V | Diesel | 84hp (63kW) @4600 rpm | 112ft/lb (152Nm) @2400 rpm | M21D24 | 1985–1993 |
| 324td | 2443cc | 6cyl | SOHC 12V | Diesel | 114hp (85kW) @4800 rpm | 162ft/lb (220Nm) @2400 rpm | M21D24 | 1985–1993 |
Over the years, many E30s have been played with, and many other engines can now be seen smuggled under the bonnet of both racing and road-going E30s. If you're interested in changing your motor for something with a bit more grunt, check out the Engine Swap section.
Gearbox and Differential
The following were fitted to each E30:
Drum or Disc
Suspension and Steering
Body Styles and Fittings
The E30 was offered in a number of body styles. A 2-door and 4-door Saloon, Cabriolet and Touring
Electrical
Maintenance
To get the most out of your E30, it pays to look after it. After all, everyone needs a bit of TLC occasionally, and your car deserves to have these things done to it on a fairly regular basis:
While they left the factory as the ultimate vehicle of their time, some drivers feel that the E30 needs improving to keep up with modern traffic. This list of popular improvements will highlight the most common ways to increase the performance of your car.
Engine Swaps
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
| First Column Header | Second Column Header | Third Column Header |
| We | Love | E30s |
| Old | Skool | Cool |
