M5x Looms
The looms available to you are dependant on the donor vehicle. Looms from the E34 will have an ECU plug that reaches to the right side of the car, while the E36 loom goes to Near side of the vehicle.
M50B25
Pin # C101 | Colour | Goes to.. on E30 | Connect to Pin # M50B25 engine plug | |
1 | blue | pin 16 blue plug inst cluster - Charge light | 25 | blue |
2 | green/yellow | Pin 16 check panel - static oil level | 1 | blue/white |
3 | ||||
4 | brown | pin 26 blue plug inst cluster- temp gauge | 12 | brown/yellow |
5 | brown/green | pin 18 blue plug inst cluster- oil press light | 23 | brown/grey |
6 | green/white | Fuse 9 - Oxygen sensor relay | 22 | green/white |
7 | green | ign switch - switched power | 21 | green |
8 | white/black | pin 11 blue plug inst cluster- fuel rate input | 24 | white/black |
9 | black | pin 7 blue plug inst cluster- engine speed input | 20 | black |
10 | blue | pin 20 check panel- dynamic oil level | 2 | blue/yellow |
11 | white/green | pin 22 blue plug inst cluster- reset service lights | 19 | white/green |
12 | grey | Check Engine indicator | 8 | grey |
13 | green/purple | fuse 11- fuel pump relay | 13 | green/purple |
14 | black/white | pin 10 white plug inst cluster- speed signal out | 14 | black/white |
15 | black/green | pin 1 blue plug inst cluster- from unloader relay | 15 | black/green |
16 | white/black | Diagnostic connector pin 6 | 17 | white/purple |
17 | ||||
18 | black/yellow | ign switch- start | 18 | black/yellow |
19 | ||||
20 | red/yellow | ABS power | 3 | red/white |
M52B28
Pin # C101 | Colour | Goes to.. on E30 | Connect to Pin # M52B28 engine plug | |
2 | blue/black | Pin 16 check panel - static oil level | if fitting oil level sensor, connect here | |
3 | ||||
4 | brown/purple | pin 26 blue plug inst cluster- temp gauge | 12 | brown/purple |
5 | black/brown | pin 18 blue plug inst cluster- oil press light | 23 | brown/green |
6 | green/yellow | Fuse 9- Oxygen sensor relay | 22 | green/white |
8 | yellow/white | pin 11 blue plug inst cluster- fuel rate input | 24 | white/black |
10 | purple/green | pin 20 check panel- dynamic oil level | if fitting oil level sensor, connect here | |
11 | white/blue | pin 22 blue plug inst cluster- reset service lights | 19 | white/green |
12 | ||||
13 | purple/red | fuse 11- fuel pump relay | 13 | green/purple |
14 | blue/yellow | pin 10 white plug inst cluster- speed signal out | not connected | |
16 | ||||
17 | ||||
19 | ||||
20 | brown | pin 20 blue plug inst cluster- ground | not necessary to connect |
Comments
Unused Wires
Econometer
