M10
Revision as of 16:56, 11 September 2012 by Grrrmachine (talk | contribs)
Models
M10B18 1.6 L (1766 cc/97 in³) 89 hp (66 kW) @ 5500 101 ft·lbf (137 N·m) @ 4000 6200 1982-1987
M10B18 1.8 L (1776 cc/109 in³) 105 hp (77 kW) @ 5800 107 ft·lbf (145 N·m) @ 4500 6200 1987
M10B18 9:1
82-88
Ø: 89
KH: 47.1
ÜH: 4.5
GL: 83.6
BO: 22.0 x 58
Stroke: 71
Conrod Length: 135
Volume 1766cc
Piston Shape: M10Pistons.jpg
Timing Chain
The M10 uses a chain to drive the valvetrain (unlike the M20 and M40 engines). Therefore, a sprocket is mounted at the end of the crankshaft to power the chain, which drives a corresponding sprocket on the camshaft. While some people feel that chains are indestructible, it is recommended to replace this chain every 100,000 miles. In the event of a noisy chain, replacing the chain tensioner should quieten things down.
Learn more about changing the timing chain.
Cam
On the M10, an overhead camshaft drives the intake and exhaust valves via rocker arms. This camshaft is chain-driven, and held in place using 5 bearings. It is lubricated by an overhead oil spray bar. The rear end of the cam features the gearing to power the distributor.
All engines use an 8mm stem.
Rocker Arms
Breather Hose
Engine Mounts
M10 engine mounts are the standard design of aluminium arms cushioned with rubber mounts. On some models a hydraulic shock absorber was also fitted to provide superior vibration damping.
If you are taking an engine from an [[E21] or E28, you will need E30 engine mounts.
Every engine needs its fluids and filters changed regularly. The M10 engine will also needs its timing chain replaced after a certain mileage, but more important is the condition of the chain sprocket. If yours is getting rattly, learn more about changing the timing chain.
Carburettor Upgrade
The Pierburg 2BE carburettor found in 316 models is not considered a particularly good carburettor. Converting to a Weber carburettor will yield more power and more tuning options. Learn more about Weber carburettors.
Useful websites
See also
