M10
At the end of 1982 with the release of the E30, a 1.8 litre carburreted version was fitted to the base model 316 and a fuel-injected version powered the 318i. A smaller 1.6litre carburreted engine from the E21 was exported to Greece and Yugoslavia as the rare 316s. These models comprised the 4-cylinder range of E30 engines alongside the M20-powered 320i and 323i. At the same time, the engine would be fitted to the E28.
After the September 1987 facelift the fuel-injected M10 would be known as the 316i, removing the 316 from the model line-up. The 318i was fitted with the new M40 engine which would also power the 316i from September 1988.
| M10B18 | 1.6 L (1766 cc/97 in³) | 89 hp (66 kW) @ 5500 | 101 ft·lbf (137 N·m) @ 4000 | 6200 | 1982-1987 |
| M10B18 | 1.8 L (1776 cc/109 in³) | 105 hp (77 kW) @ 5800 | 107 ft·lbf (145 N·m) @ 4500 | 6200 | 1987 |
Every engine needs its fluids and filters changed regularly. The M10 engine will also needs its timing chain replaced after a certain mileage, but more important is the condition of the chain sprocket. If yours is getting rattly, learn more about changing the timing chain.
Carburettor Upgrade
The Pierburg 2BE carburettor found in 316 models is not considered a particularly good carburettor. Converting to a Weber carburettor will yield more power and more tuning options. Learn more about Weber carburettors.
