M42
Revision as of 20:54, 6 September 2012 by Grrrmachine (talk | contribs)
The BMW M42 is a 4-cylinder 16-valve engine, fitted to the 318is as well as early E36 models.
M42 engine
In E30 form it's twin cam 16v 4cyl 1796cc engine. It is an aluminium alloy engine which shares a development history with the M1, M5 and M635CSi engines.
The M42 is the last chain-driven engine fitted to the E30, and the first 16-valve unit. It featured a number of innovations that made it a far more modern engine than any other fitted to the E30, including a twin-valve throttle body, coil pack ignition and bi-concave combustion chambers. This made the 318iS both an economical and performance model, with good power and torque characteristics.
The engine also saw service in the E36, which added a serpentine belt front pulley system and a different intake manifold. It was finally superseded in that model by the M44.
Models
M42B18 1.8 L (1796 cc/110 in³) 101 kW (136 hp) @ 6000 175 N·m (129 ft·lbf) @ 4500 6300 1989-96
100 kW (134 hp) @ 5500 172 N·m (127 ft·lbf) @ 4500 6300 1989-96
The M42 Sump is a two part design with an upper and lower sump. The upper part bolts directly to the block, sealed with a gasket, and the lower sump then bolts to the upper.
Sump Gasket
The iron block is bored to 84mm. The cylinders have a maximum ovality of: 0.01mm/0.0004" with an identical maximum taper. Compression pressures : 10-11bar (143-156psi):
Crankshaft : End play: 0.0031-0.0064"
Con-rods : Max. weight variance without bearing shells: 4g/14oz split equally between big and small ends
Pistons : Clearance: 0.0004-0.0016"
Piston rings : Gap: Top & bottom compression rings = 0.0080-0.0160" ; oil ring = 0.0080-0.0180"
Firing order: 1-3-4-2
The engine has hydraulic tappets which reduce the maintenance of the engine.
Cylinder head : Height = 140mm/5.512"; minimum height = 139.55mm/5.494"
Cams
Being a 16V engine, the M42 head features two camshafts; an Intake and an Exhaust.
Camshaft : Duration: inlet 252 exhaust 252 Lift: inlet 10.2 exhaust 10.2
Lobe height: 1.8755-1.8803"
Valves : Seat angle: 45 degrees
Valve clearance : None, automatically compensated by hydraulic tappets
Rocker Arms
Timing Chain
Breather Hose
Intake Manifold
The inlet manifold is a two pieces design aimed at improving the low down torque of the engine.
Throttle Body
Engine Mounts
Torques
Nm ft-lbs
Big ends - Step 1 23 17
Big ends - Step 2 +70 degrees
Camshaft sprocket 13-17 10-12
Camshaft bearing cap bolts 13-17 10-12
Crankshaft damper 300-320 217-231
Cylinder head Step 1 30-35 22-25
Cylinder head Step 2 +90-95 degrees
Cylinder head Step 3 +90-95 degrees
Exhaust manifold 22-24 17-18
Flywheel 82-94
Intake manifold 13-17 10-12
Main bearings Step 1 20-25 14-18
Main bearings Step 2 +47-53 degree turn
Viscous fan coupling (LH threads) 40-50 29-36
Timing chain tensioner: 23-27 17-19
Profile Gasket
Part Qty Part Number Part Qty Part Number
Gasket 1 111 217 215 46 Gasket 1 116 117 344 90
Bolt set 1 111 217 219 39 Nut 4 183 017 377 74
Valve cover 1 111 217 218 76 Valve cover 3 111 217 214 75
Gasket 1 111 412 478 49 Gasket 1 115 317 211 72
Gasket 1 111 412 478 37 Gasket 1 116 117 346 84
O-ring 1 121 417 272 20 O-ring 1 115 317 212 18
Seal ring 1 071 199 633 55 Throttle-b 2 135 412 474 00
Gasket 1 183 017 119 69 Gasket set 1 111 417 219 19
Antifreeze 1 821 414 677 04
Timing Chain Tensioner
  • Timing Chain tensioner part (x1): 113 117 431 87
  • Timing Chain tensioner washer part(x1): 071 199 633 55
Adjusting Timing Chain
Main article: Adjusting M42 Cam Timing
Tapping/ticking noise
Fuel smell
Lumpy idle
Loose Sump Bolts
Coil On Plug
Throttle Body Heater Delete
M20 Flywheel
Not all M42's came with dual mass fly wheels which is a common misconception. A cheaper and more road freindly alternative to an aluminium flywheel is to fit an M20 flywheel and clutch assembly.
Chips
Stroker Engines
See also
