Fuel
Fuel Tank
Filler Pipe
To check the filler pipe for leaks, lift the rear o/s wheel and slide under the car. Locate the filler pipe coming from the rear wing. Grab the joining rubber pipe to the tank stub and pull it downwards.
Either the rubber pipe will pull off or fall apart, or you will see the filler stub on the tank move on it's brazed join to the tank. The rubber pipe can be replaced cheaply, but if the filler stub moves then the entire tank will have to be replaced.
Fuel Pump
Fuel Level Senders
Fuel Filter
Fuel Lines
Fuel Hoses
Fuel Rail
Injectors
The injectors are the exit point of the fuelling system. They are electrically-operated solenoids which, when activated, squirt fuel at such high pressures that it atomises into a fine mist, which is the most efficient form for it to burn.
Fuel Pressure Regulator
Carbon Canister
Controlling
Fuel Pump Relay
No Fuel to Engine
If spark is definitely present, the test to see if any fuel is reaching your engine is to detatch one of the hoses in the engine bay, put the end into a container (such as a water bottle) and then crank the engine. If fuel gets to the bottle, you have fuel. To do this:
- Depressurise the system by removing Fuse 11 and cranking the engine
- Locate the thick rubber hoses leading to the FPR or fuel rail
- Undo the jubilee clip to the nearest accesible hose, pull the hose off and put the end into a securely-placed container
- Replace Fuse 11
- Crank the engine for a few seconds
- Check the bottle
- Check Fuse 11
- Identify and remove the Fuel Pump Relay.
- With the relay removed, bridge pins 30 (red wire) and 87 (green/violet) to directly power the fuel pump. Turn on ignition, and check for fuel.
- If fuel is now present, the fault lies in the controlling system.
- If no fuel is present, remove the fuel filter and place a suitable fluid containter here. Crank engine. If fuel is now present, replace your fuel filter.
- If fuel is still not present, the fault lies with your fuel pump.
Fuel Smell (Inside)
Fuel Smell (Outside)
Fuel Leak
| Leak Location | Cause | Solution |
| Engine Bay | Perished fuel hoses | Replace hoses |
| Rear Passenger Arch | Fuel Filter | Replace |
| Rear Driver Arch | Rusty filler pipe | Grab the rubber joining pipe and pull. If the stub pipe moves, replace fuel tank. |
Rich Running
Flooding
Cold Start
Hot Start
None at this time.
Diesel
- Main article: Diesel
