Converting to Motronic 1.3
Benefits
| Distributor cap and rotor arm | Toothed crank wheel | ECU |
| Camshaft rotor adapter | Crank Position Sensor | |
| Camshaft dust cover | CPS bracket | |
| Injectors and loom | Engine bay loom | |
| Air Flow Meter | Cylinder Identification Sensor | |
| Oil Level Sender | ||
| Temperature Gauge Sender |
Installation
From Jetronic
Distributor
Injectors
Air Flow Meter
Oil Level Sensor
Temperature Sender
From Motronic 1.0
Crank Position Sender
The most involved aspect is fitting this toothed crank wheel. This involves removing the radiator and the fan before you can access the existing pulley. Once you've got those off, undo the bolts holding the existing pulley, pull it off and fit the toothed pulley in its place.
While you've got all those cooling parts removed, you'll find it easier to mount the CPS bracket. The bracket is held in place with an M8 bolt, low down on the block on the exhaust side. With the bracket in place, the sender can be fixed to it, and the wiring routed around the front of the engine. The plug should be mounted under the ICV, where it will connect to the main engine loom.
One end of the loom is the ECU plug. So that you can understand how everything fits together, check the pinouts for Motronic 1.3. The ECU plug passes through the bulkhead next to the battery. You will have to gain access to the ECU to unclip it, then feed the ECU plug through the rubber grommet into the engine bay.
The other big connector on the loom will be the C101 plug. The C101 connects the engine loom to the main vehicle Loom, supplying a switched power feed as well as sending data back out to the Instruments. Two styles of C101 plug were fitted to the E30, and you will most likely have the older style plug on your vehicle. Rather than converting your new loom to the old plug, is it better to convert your body loom plug to the new style round connector. Try to obtain this C101 from the same donor vehicle, as well as the length of wire that runs to the fuse box. Then you will start the slow procedure of cutting off the old plug and joining the wires to your new plug. All the pinouts are on the C101 page.
CID
From Motronic 1.1
