Motronic
Revision as of 20:56, 19 December 2011 by Grrrmachine (talk | contribs)
Bosch Motronic ECU
The components of the Motronic ML1.x systems for the most part remained unchanged during production, although there are some differences in certain situations.
Fuel delivery, Ignition timing, and dwell angle are incorporated into the same ECU to create a 3-dimensional map of the engine parameters relating to engine speed and load. Crank position and engine speed is determined by a pair of sensors reading from the flywheel (or toothed pulley at the front of the engine on later models). A separate constant idle speed system monitors and regulates base idle speed settings.
Motronic 1.1 & 1.3
The Motronic 1.1 System was used by BMW from 1987. This was then superseded in 1988 by the Motronic 1.3 system that was also used by PSA on some XU9J-series engines (which previously used Motronic 4.1).
Chipping
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. The flat spots are eliminated by removing the unnecessary parts in the standard program that are there to cater for low-grade fuels, high altitudes, etc. used in other parts of the world. Alternatively, the existing EPROM can be blanked in an ultra-violet EPROM eraser and a new program burned into it using an EPROM programmer linked to a PC. This is referred to as a remap, commonly carried out while dyno testing for optimising the fuelling, etc.
EPROM
Hexadecimal Language:
ECU Codes
316i: 0 261 200 174/989
318iS: 0 261 200 175
M3 2.3: 0 261 200 071
M3 2.5: 0 261 200 091
