Revision as of 13:53, 9 December 2011 by Grrrmachine (talk | contribs)
Main article: Clutch
The clutch itself is a typical three-piece mechanism of clutch disc, pressure plate and release bearing. It is a typical service component, and therefore has a fixed lifetime. When replacing the clutch, all three components should be replaced at the same time.
  • Put the handbrake on full
  • Select 2nd or 3nd gear
  • Give the engine plenty of revs
  • Now gently release the clutch pedal, giving more throttle as the clutch bites.
  • If your handbrake works well then you should be able to stall the engine. If you can get the clutch all the way up with the engine still revving then the clutch requires maintenance.
The gearboxes on all cars are bolted to the back of the engine via a bell housing, and are held to the car by a crossmember. While it is possible to remove the gearbox from the car in situ, it is considered much easier to disconnect the Engine and remove both units in one.
Manual
Manual Gearboxes
Four-Speed Five-Speed
316
318i
316 316i 318i
320i 324d
318iS 323i Sport 323i 324td 325e
325i 325iX
325i Sport
1st 3.76 3.72 3.72 3.76 3.83 3.35
2nd 2.04 2.02 2.02 2.33 2.20 2.03
3rd 1.32 1.32 1.61 1.32 1.40 1.36
4th 1.00 1.00 1.00 1.23 1.00 1.00
5th 0.81 0.80 1.00 0.81 0.81
Reverse 4.10 3.45 3.71 4.10 3.46 3.20
Getrag 242 Getrag 240 or 242/5 Getrag 240 Getrag 245 Getrag 260 Getrag 260/5
The M42 engine mates up to the same gearbox used in M40 engines, but is not campatible with earlier M10 gearboxes due to the angle of installation, which will cause problems with the shifter and rear gearbox mount. In a similar way, although the M40 and M42 boxes are interchangeable, the input/output shafts are different and so is the propshaft. This means that replacing a 318iS gearbox with the more mundane 318i unit will necessitate a change in prop.
  • Getrag 240 - MN or BMV
  • Getrag 242 - LF, MD or BMU
  • Getrag 242/5 - AY, AW or LG
  • Getrag 245 - BJ
  • Getrag 260 - NW, ANB or TNW
  • Getrag 260/5 - TNN or HM
Automatic
Automatic Gearboxes
Three-Speed Four-Speed
316 318i 320i 323i 325i
1st 2.48 2.73 2.48
2nd 1.48 1.56 1.48
3rd 1.00 1.00 1.00
4th 0.73 0.73
Reverse 2.09 2.09 2.09
ZF 3 HP 22 ZF 4 HP 22
Selector
Gear stick and shifter rod
Propshaft
Propshaft centre joint and bearing, with collar nut highlighted
Manual Automatic
316 318i
318iS
320i 1526mm 1337mm
323i 1468mm 1337mm
324td 325i 1483mm 1327mm
Guibo
Bearing
Main article: Differentials
Output Flanges
Output flange and drive shaft
Drive Shafts
Oil Leaks
Sloppy Gearstick
