Body Kits
Revision as of 09:19, 13 November 2011 by Grrrmachine (talk | contribs) (New page: Body kits, also knows as an Aerodynamics Package, were plastic or fibreglass accessories that fitted to the extremities of the car. While their aerodynamic function is limited, they do pro...)
Side Skirts
SE Side Skirts
The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. However, there's nothing preventing you from fitting these to your own E30.
Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
Click here for the official BMW side skirt fitting guide
Bumpers
M-Tech
Lips
iS Lip
Spoilers
