M40
Revision as of 21:38, 7 October 2011 by Grrrmachine (talk | contribs)
The BMW M40 is a 4-cylinder engine, fitted to the 316 and 318 after 1987. It replaced the M10 as the standard 4-cylinder engine.
Models
M40B16 1.6 L (1596 cc/97 in³) 75 kW (101 hp) @ 5500 143 N·m (105 ft·lbf) @ 4250 6200 1988
73 kW (98 hp) @ 5500 141 N·m (104 ft·lbf) @ 4250 6200 1988
M40B18 1.8 L (1796 cc/109 in³) 85 kW (114 hp) @ 5500 165 N·m (122 ft·lbf) @ 4250 6200 1987
83 kW (111 hp) @ 5500 162 N·m (119 ft·lbf) @ 4250 6200 1987
M40B16
The M40B16 is a 1.6 L (1596cc) version of the M40 producing 102hp and 105 ft.lb of torque using Motronic 1.3 fuel injection.
The M40B16 was also fitted to the E36.
M40B18
The M40B18 is a 1.8 L (1796cc) version of the M40 producing 115hp and 122 lb.ft of torque. Like the M40B16, it also uses Motronic 1.3 fuel injection
The M40B18 was also fitted to the E34 from 1988 to 1994, and briefly the E32 in 1992-1993.
Characteristics
Engine Bay
Won't Rev Over 5000
Unfortunately, this is a common sign of engine wear, and indicates a worn out cam shaft. The only solution is to replace.
Useful websites
See also
