Instruments
Revision as of 07:15, 8 October 2012 by Grrrmachine (talk | contribs)
Dash Cluster
SI Batteries
Coding Plug
Individual Gauges
Speedometer
Odometer
Fuel Gauge
Temp Gauge
Tachometer
Econometer
Dash Lights
Battery Light
Oil Pressure Light
Check Light
Brake Lights
Indicators
Main article: Indicators
Inspection Lights
OBC
Main article: OBC
Check Panel
Extra Gauges
VDO Gauges
Alpina
Alpina digital gauges
Speedo Not Working
Rev Counter Not Working
The rev counter takes its signal directly from the ECU. It's a square-wave signal, so you can't check it with a regular multimeter, but you can check that the signal wire is in good condition between the clocks and the ECU. This is a black wire that, on Motronic 1.3 vehicles, runs from ECU pin 6 through the C101 plug pin 7 to the dash cluster's blue plug pin 7. Most likely, there is corrosion on the C101 plug which is affecting the signal.
Fuel Gauge Not Working
Temp Gauge Not Working
The Temp Gauge is driven by the Brown Plug, a heat resistor that screws into the engine head. Failure of the brown plug is rare, but not uncommon. To test, first unplug the cable from the brown plug, and earth the terminal with a piece of wire (for older cars with two-pin terminals, just bridge them together). If you switch the ignition on, the gauge should go to full hot. If it doesn't, reconnect the cable and repeat the test by earthing pin 4 (brown/purple wire) of the C101 plug. If it now works, the issue is normally corrosion of the C191 plug.
If the wire test at the C101 plug still doesn't make the gauge move, the most common cause of temperature gauge issues is the Brass Nut; a small nut at the back of the dash cluster that comes loose over time. Simple tightening of this nut can resolve a number of issues, but access to this nut requires the dash cluster to be removed, which is why testing the wiring with the above method is often the preferred solution.
Brake Pad Light Flickering
Brake pad resistor joints
A very common issue relates to the Brake Pad Wear indicator, which has been known to flicker or come on at random intervals, regardless of the condition of the brake pads themselves. This problem is caused almost exclusively by a loose resistor within the dash cluster.
A little bit of fresh solder and the application of a hot soldering iron, and the job's done.
