M10
| M10B18 | 1.6 L (1766 cc/97 in³) | 89 hp (66 kW) @ 5500 | 101 ft·lbf (137 N·m) @ 4000 | 6200 | 1982-1987 |
| M10B18 | 1.8 L (1776 cc/109 in³) | 105 hp (77 kW) @ 5800 | 107 ft·lbf (145 N·m) @ 4500 | 6200 | 1987 |
| M10B18 9:1 | |
| 82-88 | |
| Ø: | 89 |
| KH: | 47.1 |
| ÜH: | 4.5 |
| GL: | 83.6 |
| BO: | 22.0 x 58 |
| Stroke: | 71 |
| Conrod Length: | 135 |
| Volume | 1766cc |
| Piston Shape: |
Timing Chain
Cam
All engines use an 8mm stem.
Valve tappet clearance, inlet and exhaust on a cold engine: 0,20mm
Valve tappet clearance, inlet and exhaust on a warm engine: 0,25mm
Rocker Arms
Breather Hose
Engine Mounts
M10 engine mounts are the standard design of aluminium arms cushioned with rubber mounts. On some models a hydraulic shock absorber was also fitted to provide superior vibration damping.
Carburettor Upgrade
The Pierburg 2BE carburettor found in 316 models is not considered a particularly good carburettor. Converting to a Weber carburettor will yield more power and more tuning options. Learn more about Weber carburettors.
