M10
Revision as of 12:13, 11 September 2012 by Grrrmachine (talk | contribs)
Models
M10B18 1.6 L (1766 cc/97 in³) 89 hp (66 kW) @ 5500 101 ft·lbf (137 N·m) @ 4000 6200 1982-1987
M10B18 1.8 L (1776 cc/109 in³) 105 hp (77 kW) @ 5800 107 ft·lbf (145 N·m) @ 4500 6200 1987
The engine in all E30s is a three-part design, featuring a cast-iron Block with a Sump at the bottom and an aluminium Head at the top.
Every engine needs its fluids and filters changed regularly. The M10 engine will also needs its timing chain replaced after a certain mileage, but more important is the condition of the chain sprocket. If yours is getting rattly, learn more about changing the timing chain.
Carburettor Upgrade
The Pierburg 2BE carburettor found in 316 models is not considered a particularly good carburettor. Converting to a Weber carburettor will yield more power and more tuning options. Learn more about Weber carburettors.
Useful websites
See also
