M42
The BMW M42 is a 4-cylinder 16-valve engine, fitted to the 318is as well as early E36 models.
In E30 form it's twin cam 16v 4cyl 1796cc engine. It is an aluminium alloy engine which shares a development history with the M1, M5 and M635CSi engines.
The M42 is the last chain-driven engine fitted to the E30, and the first 16-valve unit. It featured a number of innovations that made it a far more modern engine than any other fitted to the E30, including a twin-valve throttle body, coil pack ignition and bi-concave combustion chambers. This made the 318iS both an economical and performance model, with good power and torque characteristics.
The engine also saw service in the E36, which added a serpentine belt front pulley system and a different intake manifold. It was finally superseded in that model by the M44.
The M42 Sump is a two part design with an upper and lower sump. The upper part bolts directly to the block, sealed with a gasket, and the lower sump then bolts to the upper.
Sump Gasket
The iron block is bored to 84mm. The cylinders have a maximum ovality of: 0.01mm/0.0004" with an identical maximum taper. Compression pressures : 10-11bar (143-156psi):
Firing order: 1-3-4-2
The engine has hydraulic tappets which reduce the maintenance of the engine.
Cams
Being a 16V engine, the M42 head features two camshafts; an Intake and an Exhaust.
Lobe height: 1.8755-1.8803"
Rocker Arms
Timing Chain
Breather Hose
Intake Manifold
The inlet manifold is a two pieces design aimed at improving the low down torque of the engine.
Throttle Body
Engine Mounts
Torques
| Nm | ft-lbs | |
| Flywheel | 82-94 | |
Profile Gasket
Timing Chain Tensioner
Adjusting Timing Chain
Main article: Adjusting M42 Cam Timing
Tapping/ticking noise
Fuel smell
Lumpy idle
Loose Sump Bolts
Coil On Plug
Throttle Body Heater Delete
M20 Flywheel
Not all M42's came with dual mass fly wheels which is a common misconception. A cheaper and more road freindly alternative to an aluminium flywheel is to fit an M20 flywheel and clutch assembly.
Chips
Stroker Engines
