Converting to Motronic 1.3
Revision as of 17:00, 31 January 2012 by Kedge (talk | contribs)
Benefits
From Jetronic From Motronic 1.0 From Motronic 1.1
Distributor cap and rotor arm Toothed crank wheel ECU
Camshaft rotor adapter Crank Position Sensor
Camshaft dust cover CPS bracket
Injectors and loom Engine bay loom
Air Flow Meter Cylinder Identification Sensor
Oil Level Sender
Temperature Gauge Sender
Installation
From Jetronic
Camshaft rotor adapter (7) and dust cover (6)
Distributor
Injectors
Air Flow Meter
Oil Level Sensor
Temperature Sender
From Motronic 1.0
Here you can see the CPS in position on the front of the block, ready to pick up the signal off the crank pulley. All M20 blocks have the threaded holes ready to fit this.
On the left is the toothed crank pulley you'll need to fit(note the 7th hole which is for the locating pin), then on the right is the PAS pulley that then bolts in place, you can use your existing one.
What wiring does need doing is for instrumental purposes only and easiest to carryout on the ECU plug end. There are two wires you need to cut on the ECU plug and then connect to the C104 plug which will now but unconnected following the remocal of the old loom. The easiest thing to do is cut the matching plug from the old loom and plug it into the lose plug in the car. Then you need to connect pin #1 (Blk/Blu) on the C104 to pin #6 (Blk) on the ECU, the second connection to make is to connect C104 pin #3 (Wht) to ECU pin #32 (Wht/Blk), C104 pin #2 is not used.
CID
From Motronic 1.1
