Converting to Motronic 1.3
Benefits
| Distributor cap and rotor arm | Toothed crank wheel | ECU |
| Camshaft rotor adapter | Crank Position Sensor | |
| Camshaft dust cover | CPS bracket | |
| Air Flow Meter | Engine bay loom | |
| Oil Level Sender | Cylinder Identification Sensor | |
| Injectors and loom |
Installation
From Jetronic
Distributor
In the space where the distributor was, you will need to fit either a blanking plate or the oil pump drive shaft. You can also remove the Ignition Control Module (mounted to the inner wing) including its wiring. This should include disconnecting a green wire to the ignition coil, which will be replaced when you fit the new loom.
Air Flow Meter
Oil Level Sensor
Temperature Sender
From Motronic 1.0
Crank Position Sender
The most involved aspect is fitting the toothed crank wheel. This involves removing the radiator and the fan before you can access the existing pulley. Once you've got those off, undo the bolts holding the existing pulley, pull it off and fit the toothed pulley in its place.
While you've got all those cooling parts removed, you'll find it easier to mount the CPS bracket.
The Motronic 1.3 system uses a wiring harness to connect all the sensors up to the ECU. Since the Motronic 1.3 ECU is more complex, it is fed by an increasing number of wires to better read and control the engine.
One end of the loom is the ECU plug. So that you can understand how everything fits together, check the pinouts for Motronic 1.3.
The other big connector will be the C101 plug. The C101 connects the engine loom to the main vehicle Loom, supplying a switched power feed as well as sending data back out to the Instruments. Two styles of C101 plug were fitted to the E30, and if you are converting from Jetronic or Motronic 1.0, then you will most likely have the older style plug on your vehicle. You will therefore need to wire your older plug to the newer plug found on your 1.3 loom.
CID
Injectors
From Motronic 1.1
The differences between M1.1 and M1.3 all lie in the ECU, in the way that it processes the information it receives and acts upon it. Therefore, upgrading from M1.1 to M1.3 is as simple as plugging in a new ECU.
