Converting to Motronic 1.3
Revision as of 12:59, 25 January 2012 by Grrrmachine (talk | contribs)
Benefits
If your car is currently equipped with Jetronic management, you will need all of the following components
Sensors
Like all Motronic systems, 1.3 runs on a number of sensors, these are:
Sensor Location
Air Flow Meter Engine Bay
Intake Air Temperature sensor Built into the Air Flow Meter
Crank Position Sensor Front of engine block
Throttle Position Switch Under throttle body
Engine Temperature Sensor Engine head
Cylinder Identification Sensor Fitted to HT leads
Lambda Sensor - catalyzer-equipped vehicles only Exhaust downpipe
You will need all of these sensors to make your engine run properly. While you may already have some of these fitted, they may need replacing.
Jetronic systems also utilised a different version of the Brown Plug which drives the Temp Gauge. These older plugs were two-pin units, while your new system will only have one wire to connect to it. You will therefore need to replace your old Brown Plug for the new one-pin version.
The Motronic 1.3 system uses a wiring harness to connect all the sensors up to the ECU. Since the Motronic 1.3 ECU is more complex, it is fed by an increasing number of wires to better read and control the engine.
One end of the loom is the ECU plug. So that you can understand how everything fits together, check the pinouts for Motronic 1.3.
The other big connector will be the C101 plug. The C101 connects the engine loom to the main vehicle Loom, supplying a switched power feed as well as sending data back out to the Instruments. Two styles of C101 plug were fitted to the E30, and if you are converting from Jetronic or Motronic 1.0, then you will most likely have the older style plug on your vehicle. You will therefore need to wire your older plug to the newer plug found on your 1.3 loom.
Distributor
Jetronic engines have their distributor mounted in the engine block, while Motronic engines have it mounted on the head, driven by the cam shaft. You will therefore need the modern distributor, as well as the adapter and cover plate that fits to the end of the cam that allows you to attach the rotor arm.
Installation
From Jetronic
Camshaft rotor adapter (7) and dust cover (6)
Parts needed:
  • Distributor cap and rotor arm
  • Camshaft rotor adapter
  • Camshaft dust cover
  • Air Flow Meter
Procedure:
the oil level sensor has different plug, you can either cut the old plug off the loom and put the other one on or replace the sensor with a newer one. At the starter motor their is a extra wire that isn't used.
From Motronic 1.0
Parts needed:
  • Toothed crank wheel
  • CPS sensor
  • CPS bracket
  • ECU
  • Engine bay loom
  • CID sensor
  • Oil Pressure Switch
  • Injector plugs and loom
Procedure:
The most involved aspect is fitting the toothed crank wheel. This involves removing the radiator and the fan before you can access the existing pulley. Once you've got those off, undo the bolts holding the existing pulley, pull it off and fit the toothed pulley in its place.
While you've got all those cooling parts removed, you'll find it easier to mount the CPS bracket.
From Motronic 1.1
Parts needed:
  • ECU
Procedure:
The differences between M1.1 and M1.3 all lie in the ECU, in the way that it processes the information it receives and acts upon it. Therefore, upgrading from M1.1 to M1.3 is as simple as plugging in a new ECU.
