M5x Looms
Revision as of 12:43, 17 November 2011 by Grrrmachine (talk | contribs)
C101 and X20 engine plugs
The looms available to you are dependant on the donor vehicle. Looms from the E34 will have an ECU plug that reaches to the right side of the car, while the E36 loom goes to Near side of the vehicle.
M50B25
wiring for an E34 M50B25 into an E30
Pin # C101 Colour Goes to.. on E30 Connect to Pin # M50B25 engine plug
1 blue pin 16 blue plug inst cluster - Charge light 25 blue
2 green/yellow Pin 16 check panel - static oil level 1 blue/white
3
4 brown pin 26 blue plug inst cluster- temp gauge 12 brown/yellow
5 brown/green pin 18 blue plug inst cluster- oil press light 23 brown/grey
6 green/white Fuse 9- Oxygen sensor relay 22 green/white
7 green ign switch - switched power 21 green
8 white/black pin 11 blue plug inst cluster- fuel rate input 24 white/black
9 black pin 7 blue plug inst cluster- engine speed input 20 black
10 blue pin 20 check panel- dynamic oil level 2 blue/yellow
11 white/green pin 22 blue plug inst cluster- reset service lights 19 white/green
12 grey Check Engine indicator 8 grey
13 green/purple fuse 11- fuel pump relay 13 green/purple
14 black/white pin 10 white plug inst cluster- speed signal out 14 black/white
15 black/green pin 1 blue plug inst cluster- from unloader relay 15 black/green
16 white/black Diagnostic connector pin 6 17 white/purple
17
18 black/yellow ign switch- start 18 black/yellow
19
20 red/yellow ABS power 3 red/white
M52B28
wiring for an E36 M52B28 into an E30
Pin # C101 Colour Goes to.. on E30 Connect to Pin # M52B28 engine plug
2 blue/black Pin 16 check panel - static oil level if fitting oil level sensor, connect here
3
4 brown/purple pin 26 blue plug inst cluster- temp gauge 12 brown/purple
5 black/brown pin 18 blue plug inst cluster- oil press light 23 brown/green
6 green/yellow Fuse 9- Oxygen sensor relay 22 green/white
8 yellow/white pin 11 blue plug inst cluster- fuel rate input 24 white/black
10 purple/green pin 20 check panel- dynamic oil level if fitting oil level sensor, connect here
11 white/blue pin 22 blue plug inst cluster- reset service lights 19 white/green
12
13 purple/red fuse 11- fuel pump relay 13 green/purple
14 blue/yellow pin 10 white plug inst cluster- speed signal out not connected
16
17
19
20 brown pin 20 blue plug inst cluster- ground not necessary to connect
Comments
Unused Wires
Econometer
