M5x Looms
Looms
M50B25
| Pin # C101 | Colour | Goes to.. on E30 | Connect to Pin # M50B25 engine plug | |
| 1 | blue | pin 16 blue plug inst cluster - Charge light | 25 | blue |
| 2 | green/yellow | Pin 16 check panel - static oil level | 1 | blue/white |
| 3 | ||||
| 4 | brown | pin 26 blue plug inst cluster- temp gauge | 12 | brown/yellow |
| 5 | brown/green | pin 18 blue plug inst cluster- oil press light | 23 | brown/grey |
| 6 | green/white | Fuse 9- Oxygen sensor relay | 22 | green/white |
| 7 | green | ign switch - switched power | 21 | green |
| 8 | white/black | pin 11 blue plug inst cluster- fuel rate input | 24 | white/black |
| 9 | black | pin 7 blue plug inst cluster- engine speed input | 20 | black |
| 10 | blue | pin 20 check panel- dynamic oil level | 2 | blue/yellow |
| 11 | white/green | pin 22 blue plug inst cluster- reset service lights | 19 | white/green |
| 12 | grey | Check Engine indicator | 8 | grey |
| 13 | green/purple | fuse 11- fuel pump relay | 13 | green/purple |
| 14 | black/white | pin 10 white plug inst cluster- speed signal out | 14 | black/white |
| 15 | black/green | pin 1 blue plug inst cluster- from unloader relay | 15 | black/green |
| 16 | white/black | Diagnostic connector pin 6 | 17 | white/purple |
| 17 | ||||
| 18 | black/yellow | ign switch- start | 18 | black/yellow |
| 19 | ||||
| 20 | red/yellow | ABS power | 3 | red/white |
M52B28
| Pin # C101 | Colour | Goes to.. on E30 | Connect to Pin # M52B28 engine plug | |
| 2 | blue/black | Pin 16 check panel - static oil level | if fitting oil level sensor, connect here | |
| 3 | ||||
| 4 | brown/purple | pin 26 blue plug inst cluster- temp gauge | 12 | brown/purple |
| 5 | black/brown | pin 18 blue plug inst cluster- oil press light | 23 | brown/green |
| 6 | green/yellow | Fuse 9- Oxygen sensor relay | 22 | green/white |
| 8 | yellow/white | pin 11 blue plug inst cluster- fuel rate input | 24 | white/black |
| 10 | purple/green | pin 20 check panel- dynamic oil level | if fitting oil level sensor, connect here | |
| 11 | white/blue | pin 22 blue plug inst cluster- reset service lights | 19 | white/green |
| 12 | ||||
| 13 | purple/red | fuse 11- fuel pump relay | 13 | green/purple |
| 14 | blue/yellow | pin 10 white plug inst cluster- speed signal out | not connected | |
| 16 | ||||
| 17 | ||||
| 19 | ||||
| 20 | brown | pin 20 blue plug inst cluster- ground | not necessary to connect | |
EWS
EWS is the immobiliser system fitted to BMW models from 1994 onwards. Its basic function was to check that the doors were unlocked correctly and that the correctly-coded ignition key is being used. If it fails to detect the right signal, it will disable the ignition circuit, the injectors and the starter motor, which is a right pain if you're trying to do an engine swap.
The ECU, EWSII and key come as a set. If you have the key and EWSII box, they can be reprogrammed to suit a different ECU by someone with the right equipment. So it is best to ensure you get all 3 components from the same car when purchasing, even see if there are spare keys to be had.
M50
M52
Comments
Econometer
