Body Kits
Bodykits
Tech 2
| Description | Fitted to the facelifted 325i Sport in 1988-1991. | ||
| Features | Fitting | Picture | |
| Bumper | Fitting Guide | ||
| Front Valance | |||
| Skirts | 2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number. | ||
| Rear Bumper | |||
| Rear Valance | |||
Lips
| Name | Fitted To | Features | Fitting | Picture |
| Pre-facelift Lip | ||||
| Facelift Lip | ||||
| iS Lip | ||||
| Volvo Lip |
Side Skirts
| SE Skirts | The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. However, there's nothing preventing you from fitting these to your own E30. | Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
The kit is mounted using a series of plastic clips. Along the top edge, these clips plug into holes drilled into the sill, while the bottom edge clips directly to the lower sill edge. As the skirt tucks into the wheel arch at both ends, two more holes are drilled into the wheel arch lip to hold plastic plugs. |
Fitting Guide | |
