Body Kits
Revision as of 13:30, 13 November 2011 by Grrrmachine (talk | contribs)
Side Skirts
Reiger
GTS
SE Side Skirts
The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. However, there's nothing preventing you from fitting these to your own E30.
Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
Click here for the official BMW side skirt fitting guide
Tech 1
Tech 2
The tech 2 sill covers on 2-door and 4-door/Tourings are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number.
Bumpers
M-Tech
Reiger
Lips
iS Lip
Volvo Lip
Front Valance
Rear Valance
Reiger
GTS
Spoilers
      • TEST AREA***
All info below this mark is for TEST PURPOSES only, while the page is under construction.
Bodykits
Tech 2
Description Fitted to the facelifted 325i Sport in 1988-1991.
Features Fitting Picture
Bumper Fitting Guide
Front Valance
Skirts 2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number.
Rear Bumper
Lips
Name Fitted To Features Fitting Picture
iS Lip
Volvo Lip
