M40
Revision as of 10:48, 16 November 2011 by Grrrmachine (talk | contribs)
The BMW M40 is a 4-cylinder engine, fitted to the 316 and 318 after 1987. It replaced the M10 as the standard 4-cylinder engine.
Models
M40B16 1.6 L (1596 cc/97 in³) 75 kW (101 hp) @ 5500 143 N·m (105 ft·lbf) @ 4250 6200 1988
73 kW (98 hp) @ 5500 141 N·m (104 ft·lbf) @ 4250 6200 1988
M40B18 1.8 L (1796 cc/109 in³) 85 kW (114 hp) @ 5500 165 N·m (122 ft·lbf) @ 4250 6200 1987
83 kW (111 hp) @ 5500 162 N·m (119 ft·lbf) @ 4250 6200 1987
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Breather Hose
Engine Mounts
Won't Rev Over 5000
To confirm, remove the rocker cover and baffle plate so that you have access to the cam shaft, and run your finger nail over the cam lobes. If you can feel scatches, grooves or other imperfections, the cam is in bad condition.
The only solution is to replace.
Useful websites
See also
