what is the piston to valve clearence on a standard m42 engine
IE . . . At tdc how far can you push the valves down before piston contact .
Thanks guys Please say someone knows the answer to this !!
Piston to valve clearence issues ? M42 Gods ?
agreen
Mods may have posted this in the wrong section tech help maybe ?
jaistanley
No i'd say the engine swap section is where you'll get the most sense...
Jai
Jai
maxfield
Is this for your choice of camshafts?
ShepsEvo3
- Master of go faster
Arron, I would post up on M42club, they seem alot more clued up on these engines.
Also, Tim_S may know also.
www.sabre-tuning.co.uk
agreen
tim s is building the engine / head for me and he is not sure what the wildet cam i can get away with is guys , i spoke to piper cams and basically there are idiots they dont have a clue what an m42 engine is let alone make cams for it they tried to sell me a 295 cam for an m40
so called cat cams very helpfull indeed i am going to be uprating the valve springs and want to know basically what the most agressive / wildest cam i can get away with before i have to poket pistons , or chage to mechanical lifters
yes jamie it is for cam choice ! why you ask dude ?
shep cheers dude i have done that and asw of yet still no reply !
ill wait thats all i can do other than spunk the money on th wild one to find it does not fit ! lool
thanks for everything so far
ShepsEvo3
Are you going for higher compression pistons? If ou are changing them, you could get them more pocketed to compensate for any higher lift/duration cam. Also, with higher CR the cam will work better.
agreen
no not toucing the bottom end yet the plan is to do this to get me threw
then me and tim hopefully will bench build a screamer of a n/a m42 over time !!!
so just the best cam i can get away with for now just changing the springs and running the itb's should see an ok (ish) gain ?
RichIS
you had a look on the catcams website ? its got loads of info about what u need to change with each of there cams not sure if its got clearances tho got every thing else
Injections nice....but I'd rather be blown ;)
agreen
hmm really i have spoken to cat cams but not acctually been on their web site , the guy at cat camsasked me what the clearence was so he could decide what the best cam was lool
