Piston to valve clearence issues ? M42 Gods ?
agreen
Post Thu Feb 28, 2008 4:37 pm
what is the piston to valve clearence on a standard m42 engine
IE . . . At tdc how far can you push the valves down before piston contact .
Thanks guys Please say someone knows the answer to this !!
agreen
Post Thu Feb 28, 2008 4:58 pm
Mods may have posted this in the wrong section tech help maybe ?
jaistanley
Post Thu Feb 28, 2008 8:21 pm
No i'd say the engine swap section is where you'll get the most sense...
Jai
maxfield
Post Thu Feb 28, 2008 8:24 pm
Is this for your choice of camshafts?
ShepsEvo3
Master of go faster
Post Thu Feb 28, 2008 8:35 pm
Arron, I would post up on M42club, they seem alot more clued up on these engines.
Also, Tim_S may know also.
www.sabre-tuning.co.uk
agreen
Post Thu Feb 28, 2008 8:42 pm
tim s is building the engine / head for me and he is not sure what the wildet cam i can get away with is guys , i spoke to piper cams and basically there are idiots they dont have a clue what an m42 engine is let alone make cams for it they tried to sell me a 295 cam for an m40 :roll:
so called cat cams very helpfull indeed i am going to be uprating the valve springs and want to know basically what the most agressive / wildest cam i can get away with before i have to poket pistons , or chage to mechanical lifters
yes jamie it is for cam choice ! why you ask dude ?
shep cheers dude i have done that and asw of yet still no reply !
ill wait thats all i can do other than spunk the money on th wild one to find it does not fit ! lool
thanks for everything so far
ShepsEvo3
Master of go faster
Post Thu Feb 28, 2008 8:45 pm
Are you going for higher compression pistons? If ou are changing them, you could get them more pocketed to compensate for any higher lift/duration cam. Also, with higher CR the cam will work better.
agreen
Post Thu Feb 28, 2008 8:50 pm
no not toucing the bottom end yet the plan is to do this to get me threw
then me and tim hopefully will bench build a screamer of a n/a m42 over time !!!
so just the best cam i can get away with for now just changing the springs and running the itb's should see an ok (ish) gain ?
RichIS
Post Thu Feb 28, 2008 9:43 pm
you had a look on the catcams website ? its got loads of info about what u need to change with each of there cams not sure if its got clearances tho got every thing else
Injections nice....but I'd rather be blown ;)
agreen
Post Thu Feb 28, 2008 9:46 pm
hmm really i have spoken to cat cams but not acctually been on their web site , the guy at cat camsasked me what the clearence was so he could decide what the best cam was lool :mad:
