M50 drop
Scrotty
Post Fri Sep 21, 2007 12:25 am
i have a J reg e34 525 sport auto im ripping a m50 out of....apart from engine plug to ecu inc injector/starter motor/alternator loom, what will i need to save? any body looms, senders etc
will be going in a 318/320 for sleeperstyle driftage
also, how do i identify if its the single vanos model?
M50noobness
cheers
Post Fri Sep 21, 2007 9:00 am
Search for a thread called 'M50 developments' in the tech section
If you still have problems after reading that im sure there will be plenty of help 8)
Post Fri Sep 21, 2007 9:10 am
J reg will probably be non vanos. The vanos unit consists externally of a hydraulic cylinder right beside the area of the inlet cam sprocket, with a steel pipe going to the oil filter block, and a lump in the chain cover right in front of the sprocket.
Get the entire engine loom complete with ECU and three relays. No wires need to be cut.
SPADGE
Post Fri Sep 21, 2007 9:56 am
Scott that engine is a non vanos one mate
Scrotty
Post Fri Sep 21, 2007 11:48 am
SPADGE wrote:Scott that engine is a non vanos one mate
thanks. should of just asked you in the first place n save time lol
so which fuel pump do i use, the m50 one or one from whichever e30 i decide to deface?
SPADGE
Post Fri Sep 21, 2007 12:46 pm
The e30 one will be fine mate
