rev counter???
dazleeds
old skool raver
old skool raver
Post Sun Apr 10, 2005 10:02 pm
help when car not running rev counter is normal at o
soon as you start her up needle goes to 2500 and regardlaess of revs wont move
any ideas lads???? Daz
www.oldskoolfantasy.co.uk
Post Sun Apr 10, 2005 10:29 pm
Hmm, this is a different one.
IIRC, all the electronics for the rev counter are on the SI board, so I suppose first thing would be to try a different one of these.
dazleeds
old skool raver
old skool raver
Post Sun Apr 10, 2005 10:31 pm
cheers mate im crap at elecs whats the si board??
do you mean main board in clocks?? Daz :cool:
Post Sun Apr 10, 2005 10:40 pm
The SI (service interval?) board is the one that remains in the front part of the cluster when you open it up. The one that has the service interval lights on it, and the rechargeable batteries that regularly fail.
dazleeds
old skool raver
old skool raver
Post Sun Apr 10, 2005 10:59 pm
:cool: got ya guessing theyre all same ie 320/325? hope so got 325 braeker out back will give it a go tomora if it dnt change it what then?
change rev counter?? cheers Daz
Templ8e30
Post Mon Apr 11, 2005 9:12 am
I'm pretty sure that all the SI boards are interchangeable between all models.
If the SI board makes no difference then yes try swapping the tachometer.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
dazleeds
old skool raver
old skool raver
Post Fri Apr 15, 2005 9:15 am
well ive changed si board and rev counter and still doing it any more ideas anyone??? Daz leeds
Post Fri Apr 15, 2005 7:54 pm
If it wasn't getting the RPM signal from the ECU, I would expect it to sit at zero, so I wouldn't think that's it.
Try changing the coding plug on the front of the cluster (one for a different engine would read wrong, but would prove the point), or see if you can aquire a complete fresh cluster to try.
