while in the garage earlier i found a manual M20 one which 'looks' like it will fit and i even cut the connector from the loom
apart from the mechanical fitting (which seems the same from the outside), is there any difference between manual M20 and M30 TPS's? eg, do they have the same fuctions at the same angles?
also, is it just 'idle mode' and 'normal mode'? or dies it do 'wide open throttle' like pug ones? i can only hear the idle 'click' on both.
