auto / manual TPS quesion (M20/M30)
gareth
Post Sun Jan 28, 2007 9:29 pm
i've been keeping an eye out for a manual TPS and plug to replace my auto one. the only reason being the auto one has a much larger connector and this hits the bonnet (while the sump just touches the steering rack!!!)
while in the garage earlier i found a manual M20 one which 'looks' like it will fit and i even cut the connector from the loom :D
apart from the mechanical fitting (which seems the same from the outside), is there any difference between manual M20 and M30 TPS's? eg, do they have the same fuctions at the same angles?
also, is it just 'idle mode' and 'normal mode'? or dies it do 'wide open throttle' like pug ones? i can only hear the idle 'click' on both.
johnl320
Post Sun Jan 28, 2007 9:51 pm
I haven't got the answer but I'm in exactly the same position as you and will watch this thread with interest. Good luck with your build
john
gareth
Post Sun Jan 28, 2007 10:02 pm
M30? :D
Andy335Touring
Post Sun Jan 28, 2007 10:16 pm
M30 TPS can be found on some E30 316i/318i M10's, have a look at the ETK :thumb:
johnl320
Post Mon Jan 29, 2007 6:37 pm
gareth wrote:M30? :D
yep :D
johnl320
Post Mon Jan 29, 2007 6:38 pm
Andy335Touring wrote:M30 TPS can be found on some E30 316i/318i M10's, have a look at the ETK :thumb:
Cheers Andy, let the search begin :thumb:
john
gareth
Post Mon Jan 29, 2007 6:51 pm
cheers mate :D
does your ETK give the bosch part numbers? the online one doesn't...
i have: 0 280 120 321 for a manual M20 and 0 280 120 406 for the auto m30
Andy335Touring
Post Mon Jan 29, 2007 7:01 pm
gareth wrote:cheers mate :D
Sorry, no or at least i don't know how to do it :o:
gareth
Post Mon Jan 29, 2007 7:06 pm
oh well, cheers anyway :D
the online one is sooooo slooooow so search though! it's a pain that i have the program for my computer but it won't run :evil:
Ant
Retired Team Member
Retired Team Member
Post Mon Jan 29, 2007 7:08 pm
M30 units operate in the opposite direction iirc ?
The auto units from all switchable cars have both a proper TPS and the idle/wot switches inside
FYI, the WOT is not a "click" just check the electrical operation both ways and all should be well.
gareth
Post Mon Jan 29, 2007 7:29 pm
haha! that's an obvious point i hadn't thought of!! :D
cheers ant.
i must get some croc-clips for my multimeter as the probes are a pain for this sort of thing as i don't have enough hands!
charlE30
Post Tue Jan 30, 2007 3:08 pm
Don't know if it helps mate but the manual TPS on my E28 M30 535 has the bosch part no 0 280 120 302 and according to the ETK is used on E24/E28/E34/E32 and the E30's that Andy mentioned.
The BMW number is 13 631 273 265.
BMW F31 335d xdrive
Andy335Touring
Post Tue Jan 30, 2007 8:22 pm
Digging through my pics for some thing else and found one, some years back since i had this on my motor :)
Andy335Touring
Post Tue Jan 30, 2007 8:29 pm
erm, guess what i've just found in my out house ? :) ^^^^^^^^^^
No plug with it though :(
Any one want it ?
gareth
Post Tue Jan 30, 2007 9:59 pm
me me me!!! i have a plug on my M20 one :D
how much do you want for it andy?
Andy335Touring
Post Wed Jan 31, 2007 5:33 pm
£5 posted sound OK ?
gareth
Post Wed Jan 31, 2007 8:07 pm
sounds sweet to me! PM me your postal address or paypal address (whatever is easiest) and i'll throw it over to you :D :cool:
johnl320
Post Wed Jan 31, 2007 9:06 pm
:cry: :cry: I hate you both and hope it gets broken in the post :snigger:
Only joking fellas, just jealous
john
