Washer Non return valve
Cypriotgeeza
Good afternoon
I am after a price for the non return valve for the washer jets please.
Hope everyone has a good bank holiday weekend!
Check my M30 build threads:
onthames
I've been after one too mate. Couldn't find one anywhere. I've just ordered these: https://www.ebay.co.uk/itm/264127728530 ... 2749.l2649
Will let you know if works!
onthames
I tried some other ebay ones. The pump didn't have enough pressure to open the valve. In the end I just used a T connector (not a valve) to tide me over until I can get one that works. If you need one urgently you could do that.
Cypriotgeeza
Cheers mate!onthames wrote: โSat May 29, 2021 9:06 pmI've been after one too mate. Couldn't find one anywhere. I've just ordered these: https://www.ebay.co.uk/itm/264127728530 ... 2749.l2649
Yea I was thinking of a T piece but heard that it doesn't build up pressure etc so I thought I'd just see how much the real thing is..if it's not too crazy I might aswell replace it..the one on there looks original
onthames
I asked cotswold last week and they had no stock, said no stock anywhere either, which so far I've found is true, even the breakers I've gone go haven't had any! Maybe they're in stock now though so give it a go!Cypriotgeeza wrote: โSat May 29, 2021 9:10 pmCheers mate!onthames wrote: โSat May 29, 2021 9:06 pmI've been after one too mate. Couldn't find one anywhere. I've just ordered these: https://www.ebay.co.uk/itm/264127728530 ... 2749.l2649
Yea I was thinking of a T piece but heard that it doesn't build up pressure etc so I thought I'd just see how much the real thing is..if it's not too crazy I might aswell replace it..the one on there looks original![]()
Cotswoldbmw
Hello Everyone
I am sorry to say the stock situation has not improved and there currently isnt any stock
anywhere in the world and no date indicating when new stock will arrive.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Cypriotgeeza
Thanks Jon!Cotswoldbmw wrote: โWed Jun 02, 2021 10:51 amHello Everyone
Regards
Jon
Cypriotgeeza
Have you received your one yet mate?onthames wrote: โSat May 29, 2021 9:06 pmI've been after one too mate. Couldn't find one anywhere. I've just ordered these: https://www.ebay.co.uk/itm/264127728530 ... 2749.l2649
https://www.ebay.co.uk/itm/324169959347 ... SwXedewnPc
I was thinkin of trying that one as its technically still Bmw so it should work as good as the original..
onthames
Yep, will try tomorrow morning, gotta pluck up the courage cos it's such an annoying job, will let you know.Cypriotgeeza wrote: โWed Jun 02, 2021 7:12 pmHave you received your one yet mate?onthames wrote: โSat May 29, 2021 9:06 pmI've been after one too mate. Couldn't find one anywhere. I've just ordered these: https://www.ebay.co.uk/itm/264127728530 ... 2749.l2649
Cypriotgeeza
Thanks man! I appreciate it!onthames wrote: โWed Jun 02, 2021 7:49 pmYep, will try tomorrow morning, gotta pluck up the courage cos it's such an annoying job, will let you know.Cypriotgeeza wrote: โWed Jun 02, 2021 7:12 pmHave you received your one yet mate?onthames wrote: โSat May 29, 2021 9:06 pmI've been after one too mate. Couldn't find one anywhere. I've just ordered these: https://www.ebay.co.uk/itm/264127728530 ... 2749.l2649
onthames
I gave it a quick go. Doesn't work, not enough pressure to open the valve, also the nozzles are too small to fit the tube snugly, but some electrical tape wrapped round and zip ties seemed to fix that. I took out 1/4 of the spring inside the valve to see if that reduces the pressure required to open it. Will try tomorrow and let you know.Cypriotgeeza wrote: โWed Jun 02, 2021 8:04 pmThanks man! I appreciate it!onthames wrote: โWed Jun 02, 2021 7:49 pmYep, will try tomorrow morning, gotta pluck up the courage cos it's such an annoying job, will let you know.Cypriotgeeza wrote: โWed Jun 02, 2021 7:12 pm
I was thinkin of trying that one as its technically still Bmw so it should work as good as the original..![]()
Cypriotgeeza
Legend!onthames wrote: โWed Jun 02, 2021 9:24 pm
I gave it a quick go. Doesn't work, not enough pressure to open the valve, also the nozzles are too small to fit the tube snugly, but some electrical tape wrapped round and zip ties seemed to fix that. I took out 1/4 of the spring inside the valve to see if that reduces the pressure required to open it. Will try tomorrow and let you know.PXL_20210602_201718291.jpg
I'm considering getting that Mini one as its prob going to be the closest to OEM that i can find i reckon..
Ill wait to see what results you have first!
onthames
I'd just go for it mateCypriotgeeza wrote: โWed Jun 02, 2021 9:32 pmLegend!onthames wrote: โWed Jun 02, 2021 9:24 pm
. I've tried another one too and not enough pressure to open valve. But when I run the washers using a non valve t splitter the pressure is strong so it's not that. I say you order that one cos mine is requiring quite a bit of bodging-
Cypriotgeeza
I'll be in touch mateCheck my M30 build threads:
onthames
Depending on how long your hoses are you may want some of these too, the OEM valve is quite a bit bigger and my hoses barely reached it so the new ones required extension. I used https://www.ebay.co.uk/itm/283886045936
Cotswoldbmw
Unfortunately these are still on a world-wide back order.
Cotswold BMW Parts
01242 335365
01242 335365
Cypriotgeeza
No worries man, thanks for taking the time to check and get back to me!Cotswoldbmw wrote: โThu Jun 03, 2021 12:43 pmUnfortunately these are still on a world-wide back order.
Cotswoldbmw
I will post something on the forum if they become available.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
01242 335365
