Washer Non return valve
Looking for genuine BMW parts at discounted prices? Try here!
Cypriotgeeza
Post Sat May 29, 2021 6:04 pm
Good afternoon
I am after a price for the non return valve for the washer jets please.
Hope everyone has a good bank holiday weekend!
Check my M30 build threads:
onthames
Post Sat May 29, 2021 9:06 pm
I've been after one too mate. Couldn't find one anywhere. I've just ordered these: https://www.ebay.co.uk/itm/264127728530 ... 2749.l2649
Will let you know if works!
onthames
Post Sat May 29, 2021 9:07 pm
I tried some other ebay ones. The pump didn't have enough pressure to open the valve. In the end I just used a T connector (not a valve) to tide me over until I can get one that works. If you need one urgently you could do that.
Cypriotgeeza
Post Sat May 29, 2021 9:10 pm
onthames wrote: โ†‘
Cheers mate!
Yea I was thinking of a T piece but heard that it doesn't build up pressure etc so I thought I'd just see how much the real thing is..if it's not too crazy I might aswell replace it..the one on there looks original ๐Ÿ˜ฎ
onthames
Post Sat May 29, 2021 9:23 pm
Cypriotgeeza wrote: โ†‘
onthames wrote: โ†‘
Cheers mate!
I asked cotswold last week and they had no stock, said no stock anywhere either, which so far I've found is true, even the breakers I've gone go haven't had any! Maybe they're in stock now though so give it a go!
Cotswoldbmw
Post Wed Jun 02, 2021 10:51 am
Hello Everyone
I am sorry to say the stock situation has not improved and there currently isnt any stock
anywhere in the world and no date indicating when new stock will arrive.
Regards
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
Cypriotgeeza
Post Wed Jun 02, 2021 7:04 pm
Cotswoldbmw wrote: โ†‘
Hello Everyone
Regards
Jon
Thanks Jon!
Cypriotgeeza
Post Wed Jun 02, 2021 7:12 pm
onthames wrote: โ†‘
Have you received your one yet mate?
https://www.ebay.co.uk/itm/324169959347 ... SwXedewnPc
I was thinkin of trying that one as its technically still Bmw so it should work as good as the original..
onthames
Post Wed Jun 02, 2021 7:49 pm
onthames wrote: โ†‘
Yep, will try tomorrow morning, gotta pluck up the courage cos it's such an annoying job, will let you know.
Cypriotgeeza
Post Wed Jun 02, 2021 8:04 pm
onthames wrote: โ†‘
onthames wrote: โ†‘
Thanks man! I appreciate it! :thumb:
onthames
Post Wed Jun 02, 2021 9:24 pm
onthames wrote: โ†‘
I gave it a quick go. Doesn't work, not enough pressure to open the valve, also the nozzles are too small to fit the tube snugly, but some electrical tape wrapped round and zip ties seemed to fix that. I took out 1/4 of the spring inside the valve to see if that reduces the pressure required to open it. Will try tomorrow and let you know.
Cypriotgeeza
Post Wed Jun 02, 2021 9:32 pm
onthames wrote: โ†‘
I gave it a quick go. Doesn't work, not enough pressure to open the valve, also the nozzles are too small to fit the tube snugly, but some electrical tape wrapped round and zip ties seemed to fix that. I took out 1/4 of the spring inside the valve to see if that reduces the pressure required to open it. Will try tomorrow and let you know.PXL_20210602_201718291.jpg
Legend!
I'm considering getting that Mini one as its prob going to be the closest to OEM that i can find i reckon..
Ill wait to see what results you have first!
:thumb:
onthames
Post Wed Jun 02, 2021 9:35 pm
onthames wrote: โ†‘
Legend!
:thumb:
I'd just go for it mate ๐Ÿ˜‚. I've tried another one too and not enough pressure to open valve. But when I run the washers using a non valve t splitter the pressure is strong so it's not that. I say you order that one cos mine is requiring quite a bit of bodging
Cypriotgeeza
Post Wed Jun 02, 2021 9:38 pm
๐Ÿ˜‚ I'll be in touch mate
onthames
Post Wed Jun 02, 2021 9:40 pm
Depending on how long your hoses are you may want some of these too, the OEM valve is quite a bit bigger and my hoses barely reached it so the new ones required extension. I used https://www.ebay.co.uk/itm/283886045936
Cotswoldbmw
Post Thu Jun 03, 2021 12:43 pm
Unfortunately these are still on a world-wide back order.
Cotswold BMW Parts
01242 335365
Cypriotgeeza
Post Thu Jun 03, 2021 8:41 pm
No worries man, thanks for taking the time to check and get back to me! :thumb:
Cotswoldbmw
Post Fri Jun 04, 2021 9:43 am
I will post something on the forum if they become available.
Regards
Jon
Cotswold BMW Parts
01242 335365
