Stiff throttle pedal
ah
As above, anyone got any ideas why.
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
Knackered cable. Inner cuts a groove into the outer on the inside of the bends.
Simply rotating the cable 180 degrees will give a bodged cure.
Blanca
Cables not expensive and a 5 minuet job but I'll bet you will find the pedal bushes shot and possibly grommets as well. Just did all mine and a new spring, amazing difference.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
HJ1981
I was just going to mention those 4-5 small bushings and one large one in the pedal box/assembly.
