Stiff throttle pedal
ah
Post Sat Sep 26, 2020 1:40 pm
As above, anyone got any ideas why.
Post Sat Sep 26, 2020 1:45 pm
Knackered cable. Inner cuts a groove into the outer on the inside of the bends.
Simply rotating the cable 180 degrees will give a bodged cure.
Blanca
Post Sat Sep 26, 2020 2:44 pm
Cables not expensive and a 5 minuet job but I'll bet you will find the pedal bushes shot and possibly grommets as well. Just did all mine and a new spring, amazing difference.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
HJ1981
Post Sat Sep 26, 2020 7:53 pm
I was just going to mention those 4-5 small bushings and one large one in the pedal box/assembly.
