Alpina Wheel Refurb
reggid
Post Sun Mar 12, 2017 12:54 am
Does anyone know what colour Alpina used for their e30 wheels?
mine are in need of some TLC
im guessing it might be better to refurb my caps repaint with new o-rings and badge rather than get new ones if i cant get a perfect match on the paint as around these parts it might be hard
cheers
E30 325is with M20B31
Post Sun Mar 12, 2017 9:00 am
if your doing the wheels get the caps done or it might look odd coloured
Kedge
Post Sun Mar 12, 2017 9:22 am
Did they use Polaris silver, same as BMW did on their wheels at that time? My Hartges were painted Polaris, I didn't have the caps painted and you can't see a difference.
Instagram - Kedge85
reggid
Post Sun Mar 12, 2017 10:22 am
Simon13 wrote:if your doing the wheels get the caps done or it might look odd coloured
was considering new caps but it would be pointless without exact paint i guess, so yeah the caps would likely get done along with new o-rings and centre badges
Kedge wrote:Did they use Polaris silver, same as BMW did on their wheels at that time? My Hartges were painted Polaris, I didn't have the caps painted and you can't see a difference.
it is supposedly brighter than the BMW wheels, i heard was sparkle silver from wurth maybe (unconfirmed)but all i see is wurth silver wheel paint online
http://www.thealpinaregister.com/forums ... 11722f04b4
http://www.autopia-carcare.com/wus-8921 ... MUiF1WGPys
Post Sun Mar 12, 2017 1:46 pm
alpina caps and are alloy instead of the plastic that Hartge used
Reggid are yours badly corroded then?
Kryptonite
Post Mon Mar 13, 2017 12:07 pm
I'm about to get mine done at Lepsons (best place IMO).
They say they do not 'refurb' centre caps, just prep it and paint it - so if it's badly corroded, chipped or damaged they won't / can't repair it as new.
There will be a colour difference if you go with caps new tho - so it's a bit of a dilemma.
You can always repair / prep the caps yourself, then hand them over with the wheels.
Also need the correct Alpina paint details for mine.
Post Mon Mar 13, 2017 6:09 pm
Kryptonite wrote:I'm about to get mine done at Lepsons (best place IMO).
Ive had a few sets of E30 Alpina's done bye Lepsons and even rough caps have come back fine.
Also, the colour is straight silver you want. Not the sparkle silver as used on later Alpina wheels.
reggid
Post Wed Mar 15, 2017 1:55 am
Simon13 wrote:alpina caps and are alloy instead of the plastic that Hartge used
inside is corroded and a bit crusty, outside is scratched and scuffed, could likely be salvaged for less than new assuming you can still get the centre badges etc separately. are the centre badges/emblem just self adhesive?
Kryptonite
Post Wed Mar 15, 2017 7:49 am
Post Wed Mar 15, 2017 8:23 pm
you can still get everything separate, they're expensive but not totally silly money. You won't get the old centre badges out without damaging them. If the surface of the caps isn't corroded badly like some end up here then refurb them!
Post Wed Mar 15, 2017 10:36 pm
reggid wrote: inside is corroded and a bit crusty, outside is scratched and scuffed, could likely be salvaged for less than new assuming you can still get the centre badges etc separately. are the centre badges/emblem just self adhesive?
You can get the wheel badges out of the caps, by heating the back of the plate gently, and using a sharp edge to prise out the badge...........don't over heat it though.
i've done it on mine, time consuming, but if you can save the badge.......
reggid
Post Wed Mar 15, 2017 10:55 pm
badges are cheap and not mint so they will be replaced.
thats exactly what i was going to try with heat gun, thanks
corkie
Post Tue Mar 21, 2017 2:03 pm
Badges are £35 from bmw !everything else is also available from bmw
e30
Post Tue Mar 21, 2017 5:22 pm
they aren't they come from alpina! all of the wheel parts are alpina part numbers
corkie
Post Wed Mar 22, 2017 5:18 am
Well i orderd mine from cotswold !
e30
reggid
Post Wed Mar 22, 2017 7:46 am
Kryptonite
Post Wed Mar 22, 2017 7:58 am
Useful tip.
I just ordered a set of badges, key caps and a lock set from Cotswold - let's see how the price compares.
I'm expecting the thicker set enamel / resin badges not a sticker.
reggid
Post Wed Mar 22, 2017 11:15 am
175 gbp for all 8 orings, locks set, badges and covers by my checks
corkie
Post Wed Mar 22, 2017 4:02 pm
£201.07 from cotswold !
e30
Kryptonite
Post Wed Mar 22, 2017 5:38 pm
That's not what I paid.
But don't think I ordered the main bug O-Rings. Mine are still fine.
reggid
Post Wed Mar 22, 2017 10:25 pm
you can get o-rings from other genenric shops for cheaper likely as they dont need to be anything special. good thing is the site tells you the size lol
reggid
Post Mon Apr 03, 2017 9:58 am
my bits arrived today not too shabby....
