Vanos rebuild
heathy325
Post Mon May 25, 2015 7:31 pm
Got the single vanos m52 and just wondering who has done a rebuild of the vanos unit? Is it easy to do? Where can I get the kit and dose it benefit much from it
Post Mon May 25, 2015 7:33 pm
DanThe will be along shortly. He's the expert.
heathy325
Post Mon May 25, 2015 7:45 pm
Yep had a few bits off him before a˜€
heathy325
Post Mon May 25, 2015 9:53 pm
Anyone?
bosers
Post Tue May 26, 2015 7:00 pm
I've done the seals on my vanos, it was pretty easy. You need to lock the camshafts with special tools, ( I borrowed some) then it's all pretty straightforward stuff. There's a well over the top write up on the Beisan? website, think they also supply the gaskets, I got mine on eBay. Cant comment on before or after as haven't driven it yet!
bosers
Post Tue May 26, 2015 7:37 pm
Not quite a full rebuild though, just read your post again. :)
Post Wed May 27, 2015 10:32 am
Whats the problem with yours? As said the seal naturally deteriorates over time, you don't need to lock the cams or touch the timing to change it though
heathy325
Post Wed May 27, 2015 10:56 am
Nothing I don't think the m52 in mine is on about 140k and not exactly had a quiet life a˜Š just dident know if these get tired or not and benefit from a rebuild
Post Wed May 27, 2015 2:40 pm
They don't need anything more than a new seal, unless its rattling like a can of marbles, in which case just fit another second hand unit. There are several ebay sellers doing bearing shims and what not but if its that bad its not worth messing with
See here for an easy seal change - http://www.e30zone.net/modules.php?name ... &start=625
