Got the single vanos m52 and just wondering who has done a rebuild of the vanos unit? Is it easy to do? Where can I get the kit and dose it benefit much from it
Vanos rebuild
- Brianmoooore
DanThe will be along shortly. He's the expert.
I've done the seals on my vanos, it was pretty easy. You need to lock the camshafts with special tools, ( I borrowed some) then it's all pretty straightforward stuff. There's a well over the top write up on the Beisan? website, think they also supply the gaskets, I got mine on eBay. Cant comment on before or after as haven't driven it yet!
- Contact:
They don't need anything more than a new seal, unless its rattling like a can of marbles, in which case just fit another second hand unit. There are several ebay sellers doing bearing shims and what not but if its that bad its not worth messing with
See here for an easy seal change - http://www.e30zone.net/modules.php?name ... &start=625
