Dash
mamodesen
Thu Apr 11, 2013 5:29 pm
hi guys has anyone got any solutions to cracked dashes?
polsta
Thu Apr 11, 2013 5:40 pm
Gavla
Thu Apr 11, 2013 6:27 pm
Depending on how bad, apparently drilling a hole on each side will stop it from spreading. You can then use a flexible filler and it will be half decent.
For best results...get a new dash.
oomz1975
Thu Apr 11, 2013 8:00 pm
Change it for one without cracks, job done.
poolnoodle
Fri Apr 12, 2013 10:09 am
Nothing - change it over. A surprisingly easy job covered by an excellent article in the wiki
dirtee-herbert
Fri Apr 12, 2013 10:28 am
poolnoodle wrote:Nothing - change it over. A surprisingly easy job covered by an excellent article in the wiki
+1
just done this last week, alot easier than expected. :D
mamodesen
Fri Apr 12, 2013 11:49 am
yeah Ive had it out a few times now, easy. i tried flocking it but its so tedious without the professional equipment.
mamodesen
Fri Apr 12, 2013 12:03 pm
mamodesen
Fri Apr 12, 2013 12:09 pm
flocking*
ross_jsy
Fri Apr 12, 2013 12:13 pm
Replace it, or if you want a motorsport look you can fill it then get it flocked.
mamodesen
Fri Apr 12, 2013 12:52 pm
Ive been trying to write flock for ages keeps changing it to**********
ross_jsy
Fri Apr 12, 2013 12:54 pm
Get it done professionally. There was a guy advertising it on here who charged around £100 for it
Gert_8
Fri Apr 12, 2013 1:41 pm
polsta wrote:Image
verde
Fri Apr 12, 2013 3:01 pm
Flock it yourself using PVA glue and a burst pillow case
Im surprised theres no DIY reasonable fix. My e21s dash looks like a road in the middle east. Its properly fucked. The e30s is mint but dam the 21 needs help ASAP
Raise hell praise Dale.
capnmchl
Fri Apr 12, 2013 4:27 pm
All I'm saying is toothpaste and a black permanent marker.
Gavla
Fri Apr 12, 2013 5:33 pm
capnmchl wrote:All I'm saying is toothpaste and a black permanent marker.
:eek:
Nick45
Fri Apr 12, 2013 7:52 pm
Smear of Tiger Seal on a toothpick - away you go.
Carbs 'n Chrome
Fri Apr 12, 2013 8:54 pm
These last two suggestions are how you SELL an E30 with a cracked dash. The only cure is replacement.
