Dash
mamodesen
hi guys has anyone got any solutions to cracked dashes?
polsta
Gavla
Depending on how bad, apparently drilling a hole on each side will stop it from spreading. You can then use a flexible filler and it will be half decent.
For best results...get a new dash.
oomz1975
poolnoodle
Nothing - change it over. A surprisingly easy job covered by an excellent article in the wiki
dirtee-herbert
+1poolnoodle wrote:Nothing - change it over. A surprisingly easy job covered by an excellent article in the wiki
just done this last week, alot easier than expected.
mamodesen
yeah Ive had it out a few times now, easy. i tried flocking it but its so tedious without the professional equipment.
mamodesen
ross_jsy
Replace it, or if you want a motorsport look you can fill it then get it flocked.
mamodesen
Ive been trying to write flock for ages keeps changing it to**********
ross_jsy
Get it done professionally. There was a guy advertising it on here who charged around £100 for it
Gert_8
polsta wrote:
verde
Flock it yourself using PVA glue and a burst pillow case
Im surprised theres no DIY reasonable fix. My e21s dash looks like a road in the middle east. Its properly fucked. The e30s is mint but dam the 21 needs help ASAP
Raise hell praise Dale.
capnmchl
All I'm saying is toothpaste and a black permanent marker.
Gavla
capnmchl wrote:All I'm saying is toothpaste and a black permanent marker.
Nick45
Smear of Tiger Seal on a toothpick - away you go.
Carbs 'n Chrome
These last two suggestions are how you SELL an E30 with a cracked dash. The only cure is replacement.
