E12 (Update Page 3)
rh306
..still waiting for the paperwork on my E12 to come through
Anyone have any idea on tyre pressures? It's running 175 R14 88H tyres
Andyboy
- Alpina Colada
A Reseda green 520!
On a V plate it'll have the old style square tooth cambelt - you'll need to convert it to later (post 10/81) pulleys because the old type belt is NLA. A set of E30 pulleys from an old L Jet car is cheap enough.
Tyre pressures? 27 front and rear. Up to 4 persons, 30 front and rear.
rh306
thanks
It's a one owner, low mileage BMW Park Lane supplied car, absolutely loving it
I don't do my own spannering sadly, was going to take it to J&D in High Wycombe where I used to take my E30, is there anywhere else better though? It's been maintained by a Rolls Royce and Bentley specialists over the last few years so should be in good nick, is dribbling a bit of oil though..
Andyboy
- Alpina Colada
Try Pacerpete on here - he loves these, especially the Solex 4A1 carburettor!
Oil leaks will be cam cover gasket and D seals, cam oil seal and oil pressure switch.
rh306
... will do.
snakebrain
Love it - the colour's superb. When did 'executives' all decide they had to drive silver or black cars to be taken seriously?
Andyboy
- Alpina Colada
I must be ill, but I'm warming to an E12. I had a few back in the day - a 1978 S 520 Auto in Olive green, a silver 525 Auto on a T (WOW118T) that I bought for the plate and a silver 528 Auto TPA308S as well as a Sapphire blue M535i.
The Olive green 520 Auto was the best - despite 180'000 miles it went well, sounded great and drove really well.
rh306
Dezzy
- CR24v it's a lifestyle
Gallery section ftw
More pics required!!
rh306
bss325i wrote:More pics required!!
Andyboy
- Alpina Colada
Lovely - receding green, 3HP22 and a clock!
That Phillips 'turnolock' 864 looks rampant !
rh306
...sounds like a beast at idle, was overtaken by one of these yesterday though
Andyboy
- Alpina Colada
Being a V plate, it should have the electric mirror, rear belts, rear heater air vent - should also have the single vacuum servo for the brakes on a long linkage/bracket and not those hateful twin servos.
Andyboy wrote:Being a V plate, it should have the electric mirror, rear belts, rear heater air vent - should also have the single vacuum servo for the brakes on a long linkage/bracket and not those hateful twin servos.
Looks like a '79 on the V to me, no electric mirror etc till the '80 model ..............
Andyboy
- Alpina Colada
Yep, she's August 1979, first of the V's. The 1980 model was introduced at the 1979 Frankfurt show. I'm looking at a BMW press shot of a 528i centre console, heater dial mounted digital clock and Becker Monza radio cassette looking rampant.
There are a lot of freaks and weirdos in this place but luckily we are normal !Andyboy wrote:Yep, she's August 1979, first of the V's. The 1980 model was introduced at the 1979 Frankfurt show. I'm looking at a BMW press shot of a 528i centre console, heater dial mounted digital clock and Becker Monza radio cassette looking rampant.
rh306
..yep keep fit mirrors (and windows) and racecar style sunroof delete option
Andyboy
- Alpina Colada
It's not as if we went cruising one night around West London looking for a Sahara beige R plated 518, is it?pacerpete wrote:There are a lot of freaks and weirdos in this place but luckily we are normal !Andyboy wrote:Yep, she's August 1979, first of the V's. The 1980 model was introduced at the 1979 Frankfurt show. I'm looking at a BMW press shot of a 528i centre console, heater dial mounted digital clock and Becker Monza radio cassette looking rampant.
suchy
- True Zone Relic
@ Andy and Pacer
You two really are unique aren't you
Is there any room up top for anything else non-bmw??
Andyboy
- Alpina Colada
We certainly are. And that's before we get onto our Xmas council estate cruises!
suchy
- True Zone Relic
You should come down here then, we have a couple of cracking estates...
anothere21323i
Pete, you have PM on a related subject......pacerpete wrote:Andyboy wrote:Being a V plate, it should have the electric mirror, rear belts, rear heater air vent - should also have the single vacuum servo for the brakes on a long linkage/bracket and not those hateful twin servos.
rh306
more peado action today
..will be keeping the faded roundels I think..
Love the steel wheels.
rh306
thanksBlitz wrote:Love the steel wheels.
getting tempted by these:
or these
it'll probably stay bone stock and executive-poverty spec though
anothere21323i
I really like the first ones with the dinky hubcaps. You see them a lot on E9s too.
rh306
...decided it was time to get serious with this one, it's up North right now and will soon be 100% rust free
Bit of a shock to see how bad the scuttle was, just looked like a bit of light bubbling on the surface
'Jimmy' would be proud !
anothere21323i
Bad man Peter!
M-Sport
I have a scuttle panel available cut out from a e12 if needed
rh306
..the body man wants to fabricate I think, am always on the look out if you've got any other bits thoughM-Sport wrote:I have a scuttle panel available cut out from a e12 if needed
dave525
i bet this means he wont have to take out the dash.So long as all the rust is removed first ie underneath.rh306 wrote:..the body man wants to fabricate I think, am always on the look out if you've got any other bits thoughM-Sport wrote:I have a scuttle panel available cut out from a e12 if neededThe (BMW) bodyshop guy is suggesting bonding rather than welding this section, using the tech they use for bonding new panels on the current models. Stronger than a weld apparently. Full pics to follow
dave525
also would be much easier to make repair section from a good used panel due to complex shapeM-Sport wrote:I have a scuttle panel available cut out from a e12 if needed
