Is it safe to do so within reason?
Current car's got a 59.1mm bore IIRC and it's proving difficult to find 'nice' alloys with that centre bore. Don't really want to fit spigot rings if I can help it to fit alloys with bigger bores.
TIA
Boring out centre hub on alloys....
Stu_Bee
Two different problems?
Hub on the car (57.1mm) smaller than the hole in the wheel = spigots
Hole in the wheel smaller than the hub on the car (57.1mm) = machine out the wheels
Barx325i
I'd probably end up boring the whole wheel
So is it safe to machine out the centre hole?
Barx325i
as long as it's not imparing your studs it's safe & pretty straight forward for a chap with a machine ya
Okay cool. 57.1 to 59.1 shouldn't be a problem hopefully
mrLEE30
Easy and safe but NOT diy, and machine shop will do this correctly and centred.
Barx325i
yeah don't attempt it yourself Imys
