Boring out centre hub on alloys....
Post Fri Jan 21, 2011 3:29 pm
Is it safe to do so within reason?
Current car's got a 59.1mm bore IIRC and it's proving difficult to find 'nice' alloys with that centre bore. Don't really want to fit spigot rings if I can help it to fit alloys with bigger bores.
TIA
Stu_Bee
Post Fri Jan 21, 2011 3:39 pm
Two different problems?
Hub on the car (57.1mm) smaller than the hole in the wheel = spigots
Hole in the wheel smaller than the hub on the car (57.1mm) = machine out the wheels
Barx325i
Post Fri Jan 21, 2011 3:59 pm
diy job by the sounds of things...
http://cgi.ebay.co.uk/MK-Morse-Master-C ... 0454036315
Post Fri Jan 21, 2011 7:41 pm
I'd probably end up boring the whole wheel :mad: :mad:
So is it safe to machine out the centre hole?
Barx325i
Post Fri Jan 21, 2011 8:00 pm
as long as it's not imparing your studs it's safe & pretty straight forward for a chap with a machine ya
Post Fri Jan 21, 2011 8:12 pm
Okay cool. 57.1 to 59.1 shouldn't be a problem hopefully :)
mrLEE30
Post Sat Jan 22, 2011 4:47 am
Easy and safe but NOT diy, and machine shop will do this correctly and centred.
Post Sat Jan 22, 2011 8:52 pm
Thanks :thumb:
Barx325i
Post Sun Jan 23, 2011 5:10 pm
yeah don't attempt it yourself Imys :wink:
