I continue to finish all sorts of little things.
The plastic trim of the rear left door was not fixed with clips and kept falling out. The reason is that the wiring niche physically does not accommodate all the harnesses. They protrude above the plane of the holes for the clips.
Apparently, German engineers did not foresee the simultaneous installation of all electrical options!
But since 1985, they did correct this situation a little, and made an additional mount to the body at the rear end of the trim. I have exactly such trims - with holes for clips at the end. I have already written about this in the relevant section. But there are no holes in the body, so there is nowhere to put the clips. The same wiring harnesses are preventing me from drilling holes, and on the right side there is a metal pipe for the tank ventilation hoses. And I didn't really want to drill. So I found a suitable plate and made such an "adapter".
Through this "adapter" I fixed the cover with a standard self-tapping screw that fixes the seat back. A bit of a collective farm, but practical.
I inserted the front edge of the cover under the B-pillar cover and snapped its clips into the threshold. The cover still didn't turn out straight, but in an arc, due to the large number of wiring harnesses under it. There's nothing you can do...
Although it's not exactly even, the trim now holds up well and doesn't fall out every time you open the door.
There's very little wiring on the right side, so this trim holds up well on the clips, so I left it like that.
At the same time, I installed the plugs on the bolts securing the rear seat belt locks, which I had previously forgotten about all the time.
While I was moving the wiring harnesses there, I found a bad contact in the wire twist for the third brake light. I fixed it, now the indicator light goes out after pressing the brake pedal, as it should be.
I also found the reason why the brake pad indicator light didn't go out. While I was installing the connector mount and fixing it, the wire broke - near the connector of the rear right wheel pad sensor. After all, the wiring is 40+ years old.... I fixed it, - now all the indicator lights work normally.
I decided to fix the muffler properly. Without a lift or inspection pit, it was very inconvenient and very difficult. But I did it, lying under the muffler, with my nose in it! )))
I screwed the bracket to the rear beam and hung the muffler on it with the original rubber ring. I lifted it as high as possible.
The right rubber ring, near the spare wheel niche, became practically problem-free.
And I struggled with the left rubber ring for quite a long time. The bracket was welded a little inaccurately, so the ring did not want to fall into place. But in the end, it did. I had to bend the bracket on the muffler a little, put on the ring, and then align the bracket again.
I was afraid that because of this the muffler would be skewed to the right side, but it turned out to be quite even.
In the relevant section, I already wrote that I bought the stock clamps for the muffler, but it turned out that they were for the M20B20, and the diameter was too small for the M20B25 muffler. Therefore, for now, I left the welded mounts to the muffler. Maybe later I will redo the entire exhaust system.... or maybe not.... ))
The pipes are raised as high as possible, to the body.
Outwardly, it also seems to be more or less even.
That's all for now.
