E30 from Ukraine - "Shadow of Intelligence"
The_Glory
Post Thu Jun 05, 2025 1:32 pm
All sorts of little things
I continue to finish all sorts of little things.
The plastic trim of the rear left door was not fixed with clips and kept falling out. The reason is that the wiring niche physically does not accommodate all the harnesses. They protrude above the plane of the holes for the clips.
Apparently, German engineers did not foresee the simultaneous installation of all electrical options! :)
But since 1985, they did correct this situation a little, and made an additional mount to the body at the rear end of the trim. I have exactly such trims - with holes for clips at the end. I have already written about this in the relevant section. But there are no holes in the body, so there is nowhere to put the clips. The same wiring harnesses are preventing me from drilling holes, and on the right side there is a metal pipe for the tank ventilation hoses. And I didn't really want to drill. So I found a suitable plate and made such an "adapter".
Through this "adapter" I fixed the cover with a standard self-tapping screw that fixes the seat back. A bit of a collective farm, but practical. :)
I inserted the front edge of the cover under the B-pillar cover and snapped its clips into the threshold. The cover still didn't turn out straight, but in an arc, due to the large number of wiring harnesses under it. There's nothing you can do...
Although it's not exactly even, the trim now holds up well and doesn't fall out every time you open the door.
There's very little wiring on the right side, so this trim holds up well on the clips, so I left it like that.
At the same time, I installed the plugs on the bolts securing the rear seat belt locks, which I had previously forgotten about all the time.
While I was moving the wiring harnesses there, I found a bad contact in the wire twist for the third brake light. I fixed it, now the indicator light goes out after pressing the brake pedal, as it should be.
I also found the reason why the brake pad indicator light didn't go out. While I was installing the connector mount and fixing it, the wire broke - near the connector of the rear right wheel pad sensor. After all, the wiring is 40+ years old.... I fixed it, - now all the indicator lights work normally.
I decided to fix the muffler properly. Without a lift or inspection pit, it was very inconvenient and very difficult. But I did it, lying under the muffler, with my nose in it! )))
I screwed the bracket to the rear beam and hung the muffler on it with the original rubber ring. I lifted it as high as possible.
The right rubber ring, near the spare wheel niche, became practically problem-free.
And I struggled with the left rubber ring for quite a long time. The bracket was welded a little inaccurately, so the ring did not want to fall into place. But in the end, it did. I had to bend the bracket on the muffler a little, put on the ring, and then align the bracket again.
I was afraid that because of this the muffler would be skewed to the right side, but it turned out to be quite even.
In the relevant section, I already wrote that I bought the stock clamps for the muffler, but it turned out that they were for the M20B20, and the diameter was too small for the M20B25 muffler. Therefore, for now, I left the welded mounts to the muffler. Maybe later I will redo the entire exhaust system.... or maybe not.... ))
The pipes are raised as high as possible, to the body.
Outwardly, it also seems to be more or less even.
That's all for now.
The_Glory
Post Tue Jun 10, 2025 9:22 am
TYC Heated Mirrors
I have long written in the relevant section of ETK about heated exterior mirrors. Then I installed my old original mirrors, and the right one was not heated. Later I found the right original heated mirror, but it did not look very good.
And recently I accidentally bought an analogue of the stock mirrors from a teammate - exact copies of the original mirrors, including their mounts - TYC mirrors.
Left 303-0072-1 and right 303-0071-1
There are analogues with a simpler mount, just on latches, but I wanted exactly the mount that was at the factory.
In principle, they are the same, the only difference is the mounting ring turned 180 degrees.
The mirror is installed with the contacts towards the door, and the teeth down. Connect the heating wiring, the "polarity" does not matter.
We install the ring in such a position that four pins are visible.
The pins must fall into the holes on the four "ears" on the mirror adjustment mechanism.
After that, the ring is turned clockwise until it stops and clicks into this position, holding the glass by the "ears".
The ring is turned with a thin screwdriver inserted into the teeth on the ring through a special hole at the bottom of the mirror body.
To remove the glass, you need to turn the ring counterclockwise in the same way.
The heated mirror is installed.
Similarly on the left side.
It looks exactly like the original mirrors, the adjustment works. So far I'm satisfied. How the heating will work, time will tell.
And now briefly about the differences in mirrors.
From top to bottom - TYC analog with heating, original with heating, original and analog without heating.
The mirror glass can be ordinary, spherical, or with a "dead" zone. Each of them can be heated or not. Therefore, in some versions there are critical differences between the left and right sides. Therefore, on the original mirrors there are markings "L unten" and "R unten" - left bottom and right bottom, respectively. As I said, heated mirrors are installed with contacts towards the door. The bottom of the mirror is where there are "teeth" on the mounting ring. The original glass housings differ in the design of the contacts, but this is not critical. On the other hand, a thermistor is built into the housing, which prevents the glass from overheating.
A regular original mirror has exactly the same housing, but without contacts and a thermistor. On the housing of the analogue, there is no place for contacts and a thermistor at all. For these mirrors, it is not fundamentally left or right, it can simply be turned.
But, in fact, in the photo, all three original mirrors are left.
If necessary, the left mirror can be converted to the right, and vice versa. To do this, you need to remove the mounting ring and rotate it 180 degrees.
The glass housing on the side of the heating contacts has a special "tooth" for fixing the glass in the working position (bottom in the photo), and a "tongue" that is a stopper for the ring (top in the photo)
There is a special stop on the ring (between the contacts in the photo)
When installing, the ring is turned clockwise and fixed by this stop by the "tooth" on the housing. If you press the "tongue" on the other side with a thin screwdriver and turn the ring counterclockwise to the stop, the ring will easily be removed from the glass housing.
Turn the ring 180 degrees and install it on the body. Now this is the right mirror - the teeth on the "R unten" side.
I do the same on the heated mirror - now one is left (teeth on the "L unten" side), and the other is right (teeth on the "R unten" side).
Let them be, just in case! )
The_Glory
Post Tue Jun 24, 2025 1:05 pm
Assembly_194. ETK_36_Wheel bolt lock with key
Returning to the section Wheels with tires
We will talk about the original "secret" wheel bolts.
The rarest and most interesting option is bolts with a key.
Part #1 - set of locks (36 13 1 182 006) - 1 pc. No longer available for order. The set includes - bolts, locks, covers, keys - 4 pieces each.
In my set, only one original key and one cover were preserved. I also had one "spare" bolt for a long time.
It is not possible to order the key and cover separately, so for a complete set I ordered 4 duplicates of the original key from a key shop. Also, my clubmate made copies of the covers on a 3D printer. Now the set is complete.
The bolt has a head for a standard 17mm wrench, so it tightens like other regular wheel bolts.
We don't pay attention to the condition of the wheel disks. :) The disks will be different, but they still need to be painted. I'll paint these later too.
Insert the key into the lock and put it on the bolt head.
Take out the key - the "secret" is installed. It rotates freely around the bolt and does not allow it to be unscrewed.
I hope that they will be easily removed if necessary.... :)
We close the lock with a plastic cover.
Looks good! ;)
Part No. 2 - set of wheel bolt locks M12X1.5 (36 13 6 786 419) - 1 pc. The set includes - 4 bolts, 4 covers, and 1 adapter.
These same "secrets" are listed in detail in the ETK section
Wheel bolt lock with adapter
There are many types of these "secrets" by the number of teeth with different ETK numbers. Therefore, for convenience, the bolts and the corresponding adapter to them are marked with digital codes - "CODE XX". I don't see any point in rewriting them here, so I won't indicate the numbers.
But I will post a very useful picture, from which you can find out the adapter code by the number of teeth on the bolt. The first two digits are the code, the next two digits are the number of teeth.
At one time, this picture helped me a lot when I lost the adapter and did not know its code. By the way, the code is indicated on the end of the adapter and on the end of the bolts. But when the bolts are tightened, it is problematic to read it.
So, we count the number of teeth on the bolt.
According to the picture, we enter the corresponding code.
By the code, we find the original number in the ETK and order the necessary adapter by it.
Part No. 2 - wheel bolt with code CODE XX - 4 pcs.
Part No. 3 - adapter with code CODE XX - 1 pc.
Part No. 4 - protective cap SW17MM (36 13 1 180 374) - 4 pcs.
By the way, in the photo there are M14x1.5 bolts from E53. I was somehow sure that they were the same, but on E30 they, of course, did not fit. Although, they come with a turnkey of 17 mm or 19 mm.
I will have to buy another set of M12x1.5 turnkey of 17 mm.
Now more modern "secrets" are available - instead of teeth, they have end slots of various shapes.
Wheel bolt lock set
Part #1 - wheel bolt lock set M12x1.5 (36 13 6 792 849) - 1 pc. The set includes - 4 bolts and 1 adapter.
I have come across many negative reviews about the quality of these modern "secrets". They "lick" and do not unscrew.
They were not used in the E30, so I probably will not buy them. I will order later with teeth, while they are still available.
I will write about the wheels later, when I paint at least one set of four.
P.S.
The problem with the power steering was solved quite easily - just one bolt on the steering rack was not tightened. Tightened the bolt, added ATF - everything is OK. I am very glad that everything is fine with the steering rack! )
But the problem with the brakes turned out to be more complicated than I expected. I will write about it when I solve it.
The_Glory
Post Thu Jul 17, 2025 12:45 pm
ABS hydraulic unit
So, - a problem with the brakes.
Looking ahead, I'll say that I created it for myself, and then I bravely fought with it! )))
After pumping, the brakes were there, but bad, "cotton" somehow. I decided to "pump" them in extreme conditions - on the go, with sharp braking. Surprisingly, it seemed to work! The brakes became better, and somewhere after 3-4 times, the wheels even started to lock. I was already happy. And then somewhere on the 5th or 6th time, the pedal suddenly failed... something must have snapped! - I thought )
And I was not mistaken - from under the left headlight a stream of brake fluid flowed... I opened the hood - it was flowing from the ABS hydraulic unit, from the outlet fitting of the rear brake circuit (h).
I drove into the garage, tried to tighten the fitting, - it didn't work. Then I remembered that during assembly, this particular fitting was screwed tightly, but then I didn't attach importance to it. Oh, in vain. I unscrewed it, it looks like everything is fine with the thread.
But I couldn't screw it in anymore - the thread in the hydraulic unit was already damaged. When assembling, I screwed it in crookedly, it held for a while, but during emergency braking it still didn't hold... We tried to thread the place with an M10x1 tap - after that the fitting was screwed in, the tube was fixed. But when I pressed the pedal, the brake fluid no longer gushed out, but simply flowed out through the damaged thread. Fiasco. I clogged the hydraulic unit. ((
I removed it, and it became clear that here it is necessary to either cut a new M12 thread, or look for another hydraulic unit.
There was also an option to install a "spring" - a Chinese repair kit for thread restoration. I almost bought it, but for some reason it did not inspire confidence in me... also in the brakes.
I also do not really like the option with cutting the thread for the M12x1/M10x1 adapter - if small metal shavings get inside, how can I clean them out later? And if they go through the tubes to the calipers?....
That's why I started looking for another hydraulic unit. On Fortunately, it turned out that they are not expensive, and there are many of them on sale, because few people need them. So, I bought an ABS hydraulic unit at a car scrapyard (at the price of a Chinese "spring"). According to the "legend" of the seller, it was brought from Poland and has been in storage for a very long time. The number is exactly the same - BOSCH 0 265 200 013.
I disassembled it a little, washed it, cleaned it, painted it.
Although the numbers are the same, the units have some insignificant differences.
Ready to install.
I installed the hydraulic unit, and here again something went wrong with the thread! Now the problem was with the outlet fitting of the front right brake circuit (r). It did not want to twist at all! Although the broken fitting twisted freely.
The thread on both fittings are normal.
I don't know what the problem was, maybe my hands are crooked... ))) But I really didn't want to screw in another hydraulic unit. Therefore, after struggling with that fitting for two days, I decided to order an adapter (or in this case, rather, a spacer) M10x1/M10x1.
And it worked! The spacer easily screwed into the hydraulic unit, and the fitting easily screwed into the spacer. I don't understand why it didn't screw in without the spacer, but we have what we have! :)
So, the hydraulic unit is installed and screwed in. By the way, before installation, I blew all the brake pipes with a compressor to completely replace the brake fluid, because it looked very dark. Therefore, the entire system needs to be pumped again. We start pumping - and trouble! The hydraulic unit does not pump. Not at all. No way. I stupidly did not blow it.
I remove the hydraulic unit again! )) I try to blow it with a compressor - it does not blow. And then I remember the words of the seller that should have alerted me - "it has been in storage for a long time". The old brake fluid in it has dried to death.
By the way, about the differences - this unit has two additional outputs (or inputs) on top, which are closed with threaded plugs. I thought they were "parallel" with the standard outputs, but they do not blow. I wonder what they are made for?
After soaking with brake fluid poured from a syringe, the rear circuit and the front left circuit began to blow. And I poured the front right circuit with brake fluid, carburetor cleaner, and solvent for several days - no result.
This is such a mess!
I've already started thinking about trying to disassemble this hydraulic unit to clean it. Although it doesn't look very easy to disassemble. I found a video on the Internet. But after watching this video, I realized that it's better for me not to do this, because I'll have to put it back together later... )) There are 100,500 small parts. You also need a specific tool.
Maybe someone will need it.
So, I'm looking for a third ABS hydraulic unit! ) But, preferably, a working one! ))
And here I got a little lucky. A teammate is building a car for sports/drift, so he completely disconnected the hydraulic unit, because he doesn't need ABS. But until recently it was working. You just need to remove it from the car. We agreed, we removed it. The hydraulic unit is exactly the same as I had before, with the same number, and without those additional fittings.
"Master ABS" )))
Everything is blown out, the brake fluid in it is fresh. Again cleaning, washing, painting.
But there is one nuance - some terrible corrosion of the aluminum body! Just to dust. I don't know what it is from. I cleaned it, and covered it with zinc. Fortunately, it is not through and through! ))
I'm installing the third ABS hydraulic unit. And you think everything went well the third time? Of course not! ))) Again the same problem with the front right circuit fitting! It doesn't turn. It's just some trash! But I already have a miraculous spacer! With it, everything turned without problems!. Such a tricky thing! ))
The brakes were bleeding for a very long time. At first, the brakes were "cottony". Then again a few passes with sharp braking, and again pumping. In the end, the brakes became better, and even ABS started working! Now I not only have it, but it also works! )) Maybe that's why the brakes still seem weak to me, because before, without ABS, it braked much more sharply! )) Or maybe I'm just used to the better brakes in the E53... I'll drive a little, and then we'll see how it brakes... ;)
That's how I've been "having fun" the last few weeks! ) Now I need to go to the rollover/rollover test stand.
The_Glory
Post Tue Jul 22, 2025 9:04 am
First road trip!
So, the day has come! ))
The brakes are working, and finally, I can safely drive onto public roads!
It's already the middle of summer, so it's probably time to replace the winter wheels with summer ones! )
Yes, I was going to paint them, and the summer tires should have been updated by now... but I'm already completely broke with finances, so as they say now - "not the time!" )) I'll probably have to postpone painting the wheels until next season. For now, I just cleaned and washed them thoroughly.
I found a box for the spare tire in one of the wheels - I had already forgotten about it... I already wrote about it before.
It's a pity that it doesn't fit in the regular spare tire...
If you look from afar, or in the photo, then you don't need to paint the wheels! )) In principle, they don't look that bad! )) In the photo, my friend approves! )
By the way, the secret compartments with the lock opened and were removed without any problems.
There is another "secret" on the lid - double protection! )) Now it looks completely different!
I filled the windshield and headlight washer fluid. By the way, I recommend this concentrate - a good thing for its price. Better than cheap ready-made solutions.
I went out to the yard for the first full-fledged car wash, because the car was covered with a thick layer of dust again.
After the wash, the interior and trunk are dry - I was a little worried about the seals, especially the front and rear windows. But the hood seal on the right side leaks a little water, although it was like that before. It will probably need to be replaced. The sunroof drainage also works fine.
Clean, beautiful, now I can go "to people"! ))
First stop, of course, is to the gas station.
Then for a beer! )))
I rode around my village for a bit, and then home, to the garage, until it started to rain! )
Well, what can I say, I rode with an idiotic smile on my face the whole time ))) She's cool!
Although, I'm really used to her. From the low landing, when you can look at the wheels of neighboring cars through the side window, from the sports seats, in which you almost lie down, from the small wooden steering wheel, on which your hands slide, from the manual transmission, when you can control the acceleration dynamics yourself, and then you remember that you have two legs, not one right one, from the stiff suspension, when you feel like you've hit a pebble, from the location of the window buttons, when you look for them on the doors, and they are on the console, from the location of the door opening handle, when you look for it in the front, and it is behind, somewhere near your elbow, from the central locking, when you look for the remote control, and you have to close it with a key, etc.! )))
But it's just great! ) How it accelerates, how it drives!. Of course, I haven't piled on "all the money" yet ))) Let everything "run in" a little first, and I'll also "run in" to it again )))
In addition, I still need to go to the service to check and adjust the suspension.
That will be the next trip. )
The_Glory
Post Thu Jul 24, 2025 11:14 am
Assembly_195. ETK_3_Cassette holder
I have already written about the original cassette holder installed in the center console. At the same time, I also mentioned another option - a cassette holder in the door pocket. This additional option was only available for E30, E32, E34 in the US market.
Therefore, in ETK it is located in the accessories section for the US.
Cassette holder
Part No. 1 - cassette holder (82 11 1 467 123) - 1 pc. No longer available for order. Installed in the driver's door pocket.
Photo (B) from the original BMW accessories booklet:
In all my time, I've only seen it for sale on eBay once, but I didn't have time to buy it. Although, I saved the photo, just in case! ;)
Honestly, if I hadn't found it in ETK, and the photo in the factory booklet, I would have thought it was some kind of homemade box! :) The cassette units are simply wrapped in plastic and pasted over with black vinyl. There are no numbers or BMW logos. I looked for it for a long time on sale, but I never found it again. In the 80s and 90s, similar cassette units from the manufacturer Fisher C-box were installed on almost all makes and models of cars. That's why I decided to buy such units and make this box myself! )
I bought a box with vertical cassette units from some car. Someone painted the white buttons with black paint, but it started to peel off.
I carefully removed it - the buttons, thanks to the paint, retained their pure white color - like new. Although, as usual, they turn yellow from old age.
I take the blocks out of the frame and use thin double-sided tape to glue the blocks together lengthwise. I made a box out of the composite sheet, and a separate bottom for it. I bought black vinyl film with the desired texture.
The composite sheet was a beautiful color, but I still decided to cover it with film so that it would be an exact copy of the original box.
The box is pasted. We glue the tape on the cassette blocks, and insert it into the box. Then we glue the bottom of the box from below.
The box for cassettes is ready.
It is no different from the original box in the photo above.
During my search, I bought all the vertical cassette units I found at local flea markets. So I put together another such box for cassettes.
Now I have a complete collection of cassette boxes for BMW E30! )
The photo shows that the white buttons, over time, turn yellow.
The photo shows a later version of the cassette blocks, with backlighting. Maybe someday I will make another version like this. Or I will try to put it somewhere with this frame.
For all brands and models, the Fisher C-box cassette blocks are the same, but the frames for them are different. Frames are either from the automaker or from the same manufacturer Fisher C-box.
If I find two more cassette units, I'll put them back in this frame. Maybe I'll figure out where to put them! )
There are never too many cassettes! )))
By the way, the units in the center console are also factory or aftermarket. Factory ones differ in buttons and the presence of filling indicators.
The factory frame has a number, BMW logo and an arrow with the inscription "front", which indicates the direction of installation of the box - that is, with the buttons backwards.
The aftermarket frame has the Fisher C-box logo, and can be installed either way.
Although, nothing prevents you from installing the factory box the other way, if that's more convenient for someone.
But I, in any case, will not install a cassette box in the center console because I already have a phone installed there.
That's why I was interested in the option of a cassette unit in the door pocket.
So, the installation, as well as the design, is very simple - it just fits tightly in the pocket. All cars have a special frame, and here the engineers apparently decided not to bother! )) I don't understand why they didn't make a mount with a frame, like on the original coin holder in the door pocket. It would look more solid ) Although, it's normal anyway. ;)
It's convenient to use. But only if you have power windows.
(the speaker is removed, because I'm installing something interesting there, - I'll write about it later ;) )
The texture perfectly matches the texture of the pocket plastic.
So that the passenger also has his own music library, - I installed the second box in the pocket of the right door. )
Surprised passenger ))
Later, when I find the original coin case in the door pocket, I'll remove the right cassette box. But for now, that's it.
P.S.
I wish I could find another box for CD cartridges somewhere, for a complete set...
The_Glory
Post Tue Aug 05, 2025 11:07 am
Searching for an electric current leak
Since I only went out on weekends, the car was in the garage for a week. Previously, I removed the "ground" terminal from the battery, because I could do something with the wiring. Now I've almost finished everything, so I didn't disconnect the terminal. And after three days, the 72Ah battery was discharged. Completely! to 4.8V! Something specifically was "eating" it!
So, I need to find out what exactly. I suspected the standard immobilizer that I installed. After all, it turns on automatically and works constantly. I even started thinking about installing a "ground" switch...
But, I'm starting the search.
We disconnect the "ground" terminal. We connect the multimeter in current measurement mode (up to 10A) in series - one contact to the "-" terminal on the battery, and the other contact to the disconnected terminal on the body.
We turn off all electrical consumers, close all doors and the trunk so that the interior and trunk lights go out. On newer cars, you need to wait 15-20 minutes until the car "falls asleep" and all electrical units turn off. There are no such units on the E30, so you can immediately look at the indicators.
At first, the multimeter showed 0.41A! This is A LOT! It is not surprising that the battery was completely discharged in three days. A normal current leak is considered to be 0.04A-0.06A.
I start removing all the fuses (then the relays) one by one, following the multimeter readings. If the battery is in the trunk, and the fuses are under the hood, then it is more convenient to do this with an assistant so as not to run back and forth every time. )
And then, having reached fuse No. 21, the readings on the multimeter dropped significantly - to 0.02A. That is, something that is in the circuit of this fuse and "eats up" the battery.
According to the fuse list No. 21, these are:
21 7.5A Interior lighting lamps. Glove box lighting lamp. Portable lamp. Clock. Radio receiver (station memory device). On-board computer.
The prospect of once again getting into the interior wiring of the on-board computer or audio wiring scared the crap out of me! ))) So I decided to start simple - it's logical! ) I turned off the interior lights - nothing changed. I opened the glove compartment - the same thing. But when I pressed the button with my hand, the multimeter showed pleasant readings - 0.02A! Great!
That is, the box did not fully press the button, and the lamp was constantly on. Just in case, I made sure of this by putting the phone in the box in video recording mode and closing and opening it. The lamp is constantly on in the video.
I slightly bent the button bracket and everything started working as it should. I checked it again with the phone. )
I'm very glad that everything turned out to be so simple! ) Three days have passed - the battery is normal. Finally, I fully secured its terminals and installed all the clips holding the plastic boxes over the battery.
The_Glory
Post Thu Aug 07, 2025 12:17 pm
Repair of BMW BAVARIA C BUSINESS radio buttons
I have previously written about my collection of stock radios in the relevant ETK section.
After that, I also got a CD player, I also wrote about it.
But I only need to install one of them! Therefore, I connected them one by one to check their functionality.
I started with the top-end BLAUPUNKT MUNCHEN SCD09 - an analogue of the stock BAVARIA ELECTRONIC CDII.
I haven't found the CD cartridge yet, so I only checked the radio. Everything works, but the volume is very low. Later I found the probable cause. I made an adapter for the stock wiring and incorrectly connected the TEL MUTE contact, which mutes the volume when a call comes in to the stock phone. Maybe that's why the volume was muted. I've already redone the adapter, I'll have to connect it again and check. But I won't install it for now.
BMW BAVARIA C BUSINESS RDS
I bought a new screen a long time ago, it needs to be replaced. The radio works fine, but there are a few problems with the cassette - low volume and interference from the radio, fast rewinding of the cassette does not work. That's why I put it off for repair.
All functions work fine. But I stupidly broke two buttons during installation. I'll write about this in more detail later.
BMW BAVARIA C ELECTRONIC
Everything is really bad here - the radio does not respond at all, even to the code entry buttons... For repair.
BMW REVERS
I never planned to install it in the car, although it somehow works. It's the simplest radio, its visual condition is not very good, and the connector there is in terrible condition. So it will just lie in the garage.
BMW BAVARIA DIGITAL II
A simple radio. The volume control doesn't work well. Maybe it'll also need to be repaired.
So, there are a lot of radios, but little use! )) Only one is fully in working order - the BMW BAVARIA C BUSINESS. Accordingly, I'm installing it.
But there is one nuance here. The radio is installed without a "shaft", - it is simply fixed in the dashboard with two spacer screws. I have a little more wiring in my car than normal people, so in places it creates problems. ) And here too - the radio did not fully fit into the dashboard, because the wiring harnesses in it interfered. Well, when I "stuffed" the radio, I accidentally pressed the two leftmost buttons, and the contacts fell out of them! It's good that I noticed it and didn't lose them.
To say that I was upset is like saying nothing at all... (( But, fortunately, a familiar technician calmed me down a little - the contacts did not break, but simply fell out. To put them back in place, you need to unscrew and disassemble the front panel with buttons. I removed the top cover, and from what I saw for some reason I concluded (wrong, as it turned out later) that in order to remove the front panel, you need to disassemble the entire radio - remove the boards and the cassette mechanism. I am not much of a radio technician, so I decided that it would be better to contact a local technician. For two weeks he could not do anything, then he said that everything was complicated there, you need to unsolder the boards, etc. I realized that he was the same technician as me, and took the radio from him in the same condition as it was. I decided to disassemble on your own!
We unclip the plastic cover. After looking closely, I unscrewed one screw, and the front panel with the buttons was removed! Here is this ONE screw, near the volume control, - and that's it.
And here is the reason - the contacts fell out because there was not one screw on the board that they were pressed against.
Just in case, I removed these two buttons - it is clear that there are no contacts on the extreme ones.
I tried to push them between the board and the buttons - they fell out again fell out. Therefore, you need to completely unscrew the button block from the board. Here are these screws.
And here again trouble - I don't have such a small "jeweler's" screwdriver. I had to turn to another local phone repairman again. The master could not disassemble the board, because he could not find this screw, which is located between the two boards.
Although, in the upper board there is a special hole for it, through which you can easily unscrew that screw. Such masters... But the master did not give up, even when almost all the contacts from the buttons fell out, until from her took it apart... He shoved them out, as best he could by feel, between the board and the buttons, and with a sense of victory, returned my panel to me. For a symbolic 100 hryvnias! ) Just in case, I bought a set of "jeweler's" screwdrivers there, - and for good reason! )
At home I put the panel on, connect the radio, - now ALL the buttons work hard and poorly... And the two extreme right ones now don't work at all, - now there are no two contacts there! Yours!!!... I would have been better off just buying screwdrivers from that "master" and doing it myself!
I remove the radio, disassemble the panel.
The contacts are crooked, there are no contacts at all on one button, and there were two on the other! )
I laid out all the contacts in their places, covered them with a board and screwed them in with screws. That's it.
I assembled the radio, connected it - all the buttons work perfectly.
What was the difficulty for the "masters" - I don't understand. Apparently not all masters are equally useful! )) Or, as they say, if you want something done well, do it yourself!
Finally, I installed and properly secured the radio.
P.S.
Recently, I accidentally bought an air conditioner button with whole icons. At the same time, I wanted to replace it, because the icons on mine were erased.
But here too, there is a problem! ) I didn't immediately notice that the buttons themselves are not square, but rectangular, so they stand with gaps. Someone shoved buttons from E32/E34 into the E30 body.
In addition, they are not fixed when pressed. Probably because of the contact that got into the middle of the button.
It will be a spare if it can be repaired. In the meantime, there will be buttons without icons.
By the way, the temperature on the on-board computer is real! ) And I haven't even turned on the air conditioner yet...
But, literally half an hour later, the weather changed dramatically - it started to rain, or almost a hurricane of some kind!
I noticed an interesting trend. In order for it to start raining, I don't even need to wash my E30! )) It's enough to just drive it out of the garage! )) It's happened several times already! )
The_Glory
Post Tue Aug 19, 2025 3:11 pm
Assembly_196. ETK_51_Footrest
There is a rather rare option that is included in the M-package - a left footrest. Maybe that's why I couldn't find its number in the ETK.
Footrest
Part #1 - footrest. There is no number. If anyone knows it, I would be grateful for the information. This rest was in the M-package before the restyling in 1987.
Part #8 - footrest retrofit kit (51 47 2 231 604). This kit was in the M-package after restyling. But in ETK for some reason it is only for convertibles for the American market. Maybe this is another mistake... It is no longer available for order.
Footrest
Photo from the Internet
This platform differs in its fastening. It is fixed together with the fastening of the left front speaker, the central locking unit bracket, and the clutch pedal stop. All these details are also shown in the diagram, although I have already written about them in the relevant sections, so I will not repeat myself. Especially since I have an early version of the footrest.
So, back to my version.
For some reason, the ETK does not list the clip for attaching the footrest. It can be seen in the photo from the Internet.
This is a clip for fixing the original floor mats.
Part #5
Part #1
I also wrote about them in the relevant section. But this clip is for pile floor mats, so it consists of three parts - a clip and two washers. Plastic washers are not needed to fix the footrest, so the clip itself can be ordered separately by number from the retrofitting and accessories section - for rubber floor mats. Washers are not used there either.
Rubber mats
Part #5 - threaded cover SCHWARZ (51 47 1 919 177) - 1 pc.
Fastening the early version of the stop is easier - a clip in the carpet, and a self-tapping screw for the left front speaker.
Mark the location of the clip and screw it into the carpet.
Put the footrest with the hole on the clip, turn it 90 degrees and fix the footrest with it.
At the top, the footrest fits snugly against the metal bracket for mounting the steering wheel guard.
It is screwed in with a self-tapping screw together with the left front speaker. You don't have to screw in the self-tapping screw, because it also screws in the speaker guard. I screwed it in to better secure the footrest.
Next, you need to unscrew the hood opening handle to install the plastic speaker shield. But here it turned out that the shield does not fit at all, because the footrest significantly interferes with it... Looking closely at the shield, I noticed a line on it that was very similar to the cut line for the shape of the footrest...
I don't see any other option, so I cut the shield along this line.
After that, it fell into place perfectly!
By the way, then I looked at the original EBA instructions - and it does say that this is the cut line for both footrest options. So everything is correct. It also says that for the earliest cars with a pile speaker shield, nothing needs to be cut.
We screw the shield with a self-tapping screw together with the footrest and speaker. We install the hood opening handle and door seal.
All that remains is to install the lower steering wheel guard.
The left footrest is installed. Another "plus" to the "full" configuration ;)
A pretty handy thing. And considering that my carpet is the earliest, without the black pad under the left foot, it's also a practical thing - now the carpet won't get so dirty in that place.
But now I need to order original pile mats, because the rubber one from the E34 partially covers the footrest, and gets in the way a little. Well, that's for the best - maybe I'll buy them sooner now! :)
P.S.
Just for information.
There is a similar footrest for the E28, but judging by the photo, it is different in shape and size, and it won't fit the E30.
Photo from the Internet:
Although, I often came across information that the footrests for the E30, E28 or even for the E24 are the same. It looks like this is a mistake.
The_Glory
Post Wed Aug 20, 2025 11:20 am
Bottom guard and brake air ducts for BBS (part 1)
Summer is already ending, and I still haven't installed the air conditioning compressor and started it, so I haven't installed the bottom guard either. Firstly, I still haven't found a place to check the compressor before installation and fill it with R12 freon. Secondly, for financial reasons, the start of the air conditioning, along with the painting of the wheels, is postponed for an indefinite period. Maybe until next season... or maybe the war will finally end sooner, then maybe I'll have some kind of job and salary...
And for now, I decided to finish the bottom plastic guard and install the air ducts for brake air.
Nothing interesting, but the photo turned out a lot )
So I'll just start with a nice photo ))
I've written in the relevant section of ETK for a long time about the lower plastic shields and their differences - early ones before 85, 85-87, and restyling ones after 87.
Previously, I had only the lower shield installed, after 87. I also bought side shields and air ducts for it, but they don't fit my BBS front apron. There was an idea to look for early shields before 85, or M-Technic I shields, but finding them, especially whole, is problematic. And again, they won't really fit my apron. Or "collective farm" something homemade again, like I had before... But here I was a little lucky - by chance in a neighboring village I found the 85-87 shield I needed. Its condition was far from ideal, but I bought it. On the left is a regular 85-87 shield, on the right is a shield for the air conditioner after 87.
It was necessary to make a shield for the air conditioner from a regular shield. That is, to make three rectangular holes for blowing the engine pan. I don't know how this affects the operation of the air conditioner, but it was done that way from the factory.
The condition of the shield was very bad - broken off parts of the fasteners, and many cracks. But there was nothing else. So I decided to repair it.
The plastic resembles fiberglass, so it cannot be soldered. For soldering, I used ordinary plastic ties, melting them with a soldering iron.
These are the "seams" that came out. They seem to be holding up well, but I decided to reinforce them with bodywork polyurethane sealant.
It may not look very aesthetically pleasing, but it's cheap, reliable, and practical! (c) :)
The missing parts of the fasteners were restored using glued overlays made of similar plastic.
In principle, the overall appearance turned out not bad. Especially since it is not visible from below! )
But, nevertheless, for a more aesthetic look, I painted it with black matte paint.
The number remained normal, but the shield is now air-conditioned! ) With holes for blowing.
In the 85-87 version, German engineers for some reason decided to abandon the brake air vents in the front spoiler, and replaced them with these stampings at the bottom of the shield.
Theoretically, they were supposed to somehow direct the air flow towards the brake discs. But, damn it! )) In practice, it doesn't work! That's obvious. This is a "jam" of German engineers, which they fixed after the restyling of 1987, returning normal air ducts for blowing the brakes! But I had to somehow fix this "jam" myself! ) I previously made homemade air ducts from a plastic corrugated interior ventilation pipe from a "Moskvich" )) This time I wanted to do something less "collective farm" and more "aesthetic"! ;)
Apparently there are some ducts from the body kit manufacturer BBS, but I only saw them once in a photo on the Internet, and then for a different type of apron. So it's unlikely to find them. So I started looking through various standard air ducts from different BMW models. And I found a replica of the M-Technic air ducts for the BMW E34 at a flea market, which visually looked similar to what I needed for BBS. The seller gave me the dimensions of their holes - they almost fit! I decided to buy it, although the seller persistently warned me that they would not fit anywhere except on a replica of the M-Technic body kit for the BMW E34! ) But I was more persistent! )) I bought such a set - a 3D-printed replica, M-Technic BMW E34.
The first try-on showed that I was not mistaken - they fit well into the factory stampings on the shield.
On the other hand, it's almost perfect!
So, everything is ready for installation, and I'll deal with the nuances on site!
I'll write about the installation next time.
The_Glory
Post Thu Aug 21, 2025 10:52 am
Bottom guard and brake air ducts for BBS (part 2)
To install the bottom guard, you need a lift or a viewing pit. Unfortunately, I don't have either of those in my garage. I didn't want to jack up the car again, so I decided to make an improvised "overpass" on the garage ramp ;)
My assistant is the first to check the convenience of this "know-how"! ))
So, the guard on the front edge needs to be inserted into the slots in the body under the radiator with its three protrusions.
Left
In the center
Right
In my case, these slots were closed for some reason - I had to bend the metal above them first.
We put the shield under the car and insert it into these grooves. On the sides, the shield is screwed onto the side members with two plastic nuts.
Then we screw the lower edge of the BBS apron to the shield (it already had holes for this).
In essence, the shield is installed. I wonder what the rectangular holes on the sides of the BBS apron are for?... Similar holes are also in the factory spoiler. Maybe this is for attaching the original metal protective grille?
By the way, I had to move the holes for the air conditioner a few millimeters to the left and forward so that the power steering pump pulley would not rub against the edge of the shield (I recall that I had to lower the pump a little lower than it was at the factory). I think that this will not affect the operation of the air conditioner in any way. )
The shield still needs to be screwed to the front edges of the wheel arches. But I will do this after installing the bumper so as not to do the same thing twice.
Now I need to fit the M-Technic BMW E34 air ducts in place and secure them.
First, I inserted them close to the hole in the BBS apron, and marked the required length on the edge of the shield in place. I cut off the excess. By the way, the quality of the plastic, as for 3D printing, is excellent. To make the case hold tighter, I glued it around the circumference with sealing tape.
I inserted the duct case all the way under the edge of the hole in the BBS apron, and screwed it to the plastic shield at the back.
I made a 24mm spacer from thick rubber and glued it to the air duct case. Through this spacer, I screwed the lower edge of the BBS apron to the air duct case.
Now the lower edge of the BBS apron will not sag and scoop up rubble from the garage floor every time you leave - the consequences of this are already visible on the end of the apron...
In this way, the air channel is fixed between the plastic shield and the BBS apron, connecting them together.
On the outside, the channel closes almost the entire opening in the BBS apron, and the seal covers the gaps.
Similarly on the right.
Entrance
Exit into the wheel arch.
Maybe not ideal, but, as for me, it looks good, and it holds well. It's like it was there! )
And the main thing is that the direction of the air flow is now really on the brake discs!
The overall appearance is now much better - the lower edge of the BBS apron is even, but does not sag, and the "holes" in the openings for the air ducts do not shine through.
P.S.
I mentioned the regular BBS air channels here. I've never seen them live. But I saved a photo from the Internet - air ducts for another type of BBS apron.
The direction of the air flow is similar.
But their design is somewhat more complicated - they act as both air ducts and protective shields at the same time.
But for some reason I've never seen them, even in photos on the internet...
Unless you look closely at the picture from the BBS brochure, you can see them.
I wonder if there are similar stock air ducts for my type of BBS apron? If anyone has come across them, I would appreciate the information.
The_Glory
Post Mon Aug 25, 2025 10:50 am
Wheels
I've been collecting rims like a fool is collecting candy wrappers! )) Four sets. In principle, I like them all, and I don't know what to do with them - I don't want to sell them, and you can only drive on one set at a time! ) Maybe I'll change them in turn... Although, I can put all four wheels different )))
1. Borbet A multi-width rims with flat caps 7.5J16 ET20 PCD 4x100 DIA57.1 185/55R16, 9J16 ET15 PCD 4x100 DIA57.1 215/45R16 summer.
This is the basic set. In my opinion, these are some of the best rims for the E30. They look great and are without any spacers and rings. There are chips and scratches on the rim, so for a complete beautiful look, they need to be painted. The tires are already old, the front ones are completely worn out, - you need to buy a new set. But for now I installed these wheels as they are.
2. OZ wheels (ALPINA look, King) 7J15 ET13 PCD 4x100 DIA57.1 195/60R15 winter.
This was my winter set. That's why they're in pretty bad shape. Winter reagents and road salt have really damaged the paint. By the way, they're not painted exactly the same as they were in the original. They're silver with a graphite center from the factory. Mine is only silver on the front surface, and not only the middle, but also the side surfaces of all the "spoke wheels" are painted graphite. I bought another such disk separately for the spare wheel. It is all silver. I need to paint all five of them the same. I haven't decided yet - whether it's factory or the way I had it. It looked good. The tires are winter, the rear ones look almost like new - I drove them for two or three winters, but they are already old. And I don't need winter tires anymore - the car won't be driven in the winter. So, I need a new set of tires.
3. MIM 1900 7J15 ET13 PCD 4x100 DIA57.1 205/55R15 wheels
I got these wheels by chance, and almost for free - it was a sin to refuse! ) Their condition, comparatively, is not bad, although one of them needs to be leveled. These are wheels specifically for the BMW E30, although they were once installed on an Alfa Romeo 75. Even though they have a PCD of 4x98. The tires are very old. I don't know if they should be painted, but the tires need to be installed new. Maybe I'll keep them as a "sports" set... :) Someday this war will end, and then we'll be able to ride in some slalom or sprint at a club fest ;) And they look good on the E30.
4. Alloy wheels 365x150 TD ET35 with TD 220/55VR365 (Michelin TRX)
Original stock "bottle cap" rims. A teammate gave these rims to me a long time ago because he was going to scrap them! ) He bought them by mistake, thinking that they were regular stock 14" rims. In fact, they are original "metric" rims, which have a diameter of 365 mm, i.e. 14.4". This was some kind of joint "experiment" between BMW and MICHELIN in the 80s. Although, similar wheels were also on Mercedes and Ford of those times. Perhaps it was some kind of "prototype" of "runflat", because the rubber is quite hard. Why did they make "metric" diameters 340mm (13.4"), 365mm (14.4"), 390mm (15.4"), 415mm (16.4") - I don't really understand. But this is indicated on both the wheels and the rubber. Accordingly, ordinary "inch" tires do not fit on these wheels - they are either too big or too small, and do not fit on the wheel. Therefore, when buying stock wheels, you need to pay attention to this. Tires for them were produced by MICHELIN. I don't know if this is true, but I read somewhere that they were produced only until 2009. My set is completely new, but it was manufactured in 2009. I bought it by chance at a tire store, as "not liquid" ;) Although, usually, the prices for such tires are much higher than for new regular "inch" tires of the same size. I immediately put one tire on the rim to make sure that the dimensions match.
The rims need to be painted. I bought stock chrome caps for them, but I need to replace the stickers with the BMW logo on them.
This will probably be a set for "photo shoots" )) Just like a rare old-school option.
5. Raking through my supplies, I found a couple more racing "slicks" - I bought them a long time ago, just to try what they were like - for drag racing )) But somehow I never got my hands on them, and then I completely forgot about them ) I don't know... maybe I'll wear them to MIM someday, - at least for a "photo shoot" )))
So, I cleaned, washed all my wheel supplies and put them in a pile - this is such a mountain of junk! ))
In the end - I need to paint four sets of wheels and buy three sets of new tires. At the moment, this does not fit into my budget, so I just packed them in bags and folded all the wheels - until better times...
That's it.
The_Glory
Post Wed Sep 10, 2025 1:22 pm
First visit to the service station
I ride a little on the weekends ) Well, the new owner finally tried to drive it on her own for the first time! )
What can I say... she does much better on the "automatic"! )) She didn't really make friends with the "mechanics" the first time... )) Well, it's okay, I think she'll get used to it over time! ;)
But after a few trips, the brakes got worse again... I didn't start pumping them myself again, but decided to go to a specialized BMW service station to have the brakes pumped under pressure there.
After driving on a gravel road, the car was covered in dust, so I washed it first. And of course, I took a picture, while it was still clean! ))
When recording, over the phone, judging by the voice and intonation, the manager was not very happy when he heard that it was about "E30"... He even asked if it was an "F30" )) But he still replied that "if everything turns out well there, then come..." ))
I came.
I understand that they expected to see an average, killed E30... it was all the more interesting to watch the reaction! ))
And I'll tell you that my "thirty" did cause a "WOW effect"! )) When it pulled into the garage, probably all the mechanics from the service station came together to look at the "wonderful thing"! ))) Then there was the second "wave" when they opened the hood, and the third when they lifted it on a lift ))
Then there was a short "briefing", and answers to all sorts of questions. )
Well, it's very nice that the car attracts attention and arouses interest in people on the streets, on the road, and at the service station! )))
But I came here to bleed the brakes! )
They pumped under a pressure of 2 bar - there was air, but not as much as I expected. Mainly on the rear circuit. After bleeding the brakes started working normally again, the ABS also started working. After several trips, the brakes did not get worse. I hope the problem is solved... But if not, then I will definitely have to change the master brake cylinder to E32/E34, because I haven't found repair kits for the E30 325ix cylinder anywhere... I don't know why German engineers made it individual, and didn't just install the same E32/E34 cylinder... The vacuum booster is the same in them, fortunately )
I also wanted to check the suspension geometry on the 3D stand and adjust the front wheel toe-in, but the mechanic was on vacation, so I couldn't... Maybe next time...
The_Glory
Post Wed Feb 18, 2026 12:31 pm
RADIOPASS Cards
So, the car has been in the garage since the end of September last year. Winter is already ending, and I haven't done anything with it. Although, I was going to paint and install the bumpers and paint at least one set of wheel rims by spring.... I already gave up on planning something...
There are two reasons for this - lack of finances, and lack of electricity. Or rather, it's one and the same reason - damned Russian bastards!
My garage is in the basement, and due to constant rocket attacks and blackouts, we only had electricity for a few hours a day all winter, and then mostly at night. In addition, it was very cold this winter. Therefore, it was physically impossible to do anything in the garage.
But, one day, I remembered that I was going to make code cards for my radios. I had already ordered blank forms for them and a sticker for the glass.
The forms are made according to the original card.
Not an exact copy, but still more like "old school" than the new black originals (01 39 9 781 688).
The back is clean.
If you print a full copy, on both sides, with text and codes for each radio, then each card is quite expensive. So at first I wanted to just write the codes manually in the same forms - as on the new original cards. But, either I explained it poorly, or I was misunderstood - and all the cards were made with the name of one model of the radio, which was on the sample - "RADIOPASS BMW BUSINESS RDS". Therefore, the model of the radio had to be glued. I decided to print the codes separately and paste them into the cards, rather than write them manually.
There was no light in the garage, so I settled down at home in the kitchen. )
I cut out strips with the model names and codes and glued them onto the cards.
Maybe a little "collective farm", but now the goal was to always have the codes for each radio "at hand", and not to look for them somewhere in the notes on pieces of paper every time. Maybe someday I'll make a model myself and print them out right away with the codes, but for now it will be fine )
I caught a moment while it was light in the garage to spread the cards out on the radios and stick a sticker. I also saved the papers with the codes just in case ;)
Currently, the car has a BMW BAVARIA C BUSINESS radio, so I put the corresponding instructions and a card with the code in the documentation folder.
The SAFETY BMW BAVARIA sticker is usually glued to the driver's door glass, but I already have a sticker for the standard alarm there, so I glued it next to it, on the rear door glass. It is glued to the inside of the glass.
I was a little worried that this sticker would look like a bright red spot on a blue car, but in fact it turned out to be almost invisible on the glass.
The text is even difficult to read.
A bit of strange logic - a warning that is almost not noticeable... )
Now everything is as it should be in a car with "music"! )
A little later I will write about one more little thing.
Or maybe I will paint the bumpers.... )
The_Glory
Post Wed Feb 25, 2026 11:50 am
Gift - BMW E30 M3 Touring 3-door
A year ago I gave my daughter an E30 for her birthday, and recently she brought me a gift from Lviv region.
Also an E30, and an "exclusive" one - the M3 Touring 3-door! ;)
Here's one:
Of course, Hot Wheels is not a collectible scale model, but just a toy. Besides, the car model itself doesn't exist in real life, but it's cool! )
It was really nice to receive such a gift from my daughter! I put it on the shelf next to her previous gift - M8 ;)
Well, that was a "lyrical digression" ) , but on topic, I'll write about some little things later.
The_Glory
Post Mon Mar 02, 2026 2:28 pm
Additional functions of the BSC - SRS lamp (Airbag)
During the process of assembling the car, I already wrote about installing the top version of the on-board control system (BSC) for the Japanese market, and described its additional functions. One of them is the driver's airbag indicator lamp - SRS (Airbag). Recently, I learned something new about it, so I decided to make another separate entry about it. Although, this is a trifle.
So, the problem was that with this top unit, the CHECK indicator lamp on the instrument panel did not work. Someone had already tried to repair the board, or solder something there, but nothing sensible came of it. I found out a long time ago that the additional 4 lamps are provided on all units, but on the European market they are simply not used. Therefore, I decided to buy a regular standard unit to take a whole board from it. Although, I still have a regular standard unit for the US market, but it is in perfect condition, and I felt sorry to throw it away.
In the photo from top to bottom - the top unit for Japan, the standard unit for the USA, the standard unit for Europe:
And here I was unsuccessful! ) The units are from three different manufacturers - VDO, HELLA, BOSCH. The connector and functionality are the same, but the location of the four additional lamps on the board is different! Accordingly, the location of the holes for the lamps in the housing is different. I bought HELLA.
Obviously, simply moving the HELLA board into the VDO housing will not work.
Therefore, I decided to move the VDO light filters into the HELLA housing. I disassembled both units, and here I was unsuccessful again! ) It turned out that the backlight in the blocks is implemented completely differently.
In HELLA it is just a lamp that shines through the slots in the housing and an amber light filter - quite primitive. And in VDO the backlight is implemented much better - through a separate transparent amber light guide in the housing, to each lamp. The light filter and the glass with the icons are separate parts.
Therefore, the backlight in VDO looks and shines much better and more beautifully than in HELLA. Of course, I decided to look for a VDO block. I bought two more )
Then it turned out that the backlight in one was not working, and the "Motor Oil" lamp in the other was not working. Another failure...
But later, a clubmate sent me three more VDO boards.
And finally, one of them turned out to be fully functional! )
But during all these "tests" I noticed that on one board, in addition to the four additional lamps, there is one more lamp!
I had never seen it there before.
As it turned out, its contacts are parallel to the driver's airbag lamp (SRS).
That is, in cars with an airbag, a backup indicator lamp for the airbag is provided. I also did not see this in the ETM diagrams. I do not know why this is done, obviously for safety. Apparently, so that this lamp glows brighter than other lamps nearby and attracts more attention from the driver. Or rather, so that the backup lamp glows, even in the event of a failure of the main lamp.
Unfortunately, the coolant level lamp did not work in this board. Therefore, I had to choose a standard board, without this lamp. But, in any case, I decided to add this lamp - if we are going to assemble the top version! ;) Especially since there is a place for it on all boards. And I have such lamps left in stock after replacing them in the backlight of the on-board computer screen.
So, we solder the fifth additional lamp to its regular place.
Parallel to the main lamp
A fully working board in the top configuration is ready.
We assemble the top VDO unit.
Now it is clear why there is an additional hole in the housings of all units near the driver's airbag lamp.
For a backup lamp.
We install a light filter on top of the housing with a light guide.
Cover the case with glass with icons.
Connect and install the unit in the car.
We check the functionality.
In the "test" mode, when you press the button, all the lamps and their backlight work.
When the ignition is turned on, the brake light control lamp lights up, the backlight and the CHECK lamp on the instrument panel blinks.
After pressing the brake pedal, all the lights go out - everything is OK.
All the same in the video:
https://youtube.com/shorts/4uPSerUghtw
The SRS lamp will never work for me, but for the record, now it is installed there as it should be ;) Later I will write about installing impact sensors for the airbag, because I installed the wiring for them together with the other wiring. Maybe I will install the ECU unit. But I am not going to install the steering wheel with the airbag at all. Firstly, a 40-year-old airbag installed independently does not inspire much confidence in it... ) And secondly, I have never liked the design of the steering wheel with the airbag for the E30, especially its early version - it is just terrible! )
So, this will just be a "decorative" function for the top-end configuration! ;)
P.S.
The OVERHEAT function is visible in the video. It does not work normally for overheating of the catalyst, but simply signals the activation of the air conditioner fan to the second speed in automatic or manual mode.
Later I will also improve the driver's seat belt control function - it will work in normal mode.
And the O2 SENSOR function can only be implemented if there is a speedometer for the US market. I did the wiring, but I don't really like the scale in miles. Therefore, this question is still open... maybe somehow it will be possible to make some kind of "hybrid" of a speedometer for the US with a scale for Europe... ;)
The_Glory
Post Mon Mar 09, 2026 9:30 am
Cassette boxes again
Recently, I accidentally bought some more cassette cases for a small price. ) Three boxes with full indicators in excellent condition, and three broken frames with full indicators.
I took out my cassette case collection again to "update" it a little.
One cassette case was missing one full indicator, and the two boxes differed in color.
Once again I went through the optional cassette decks for the E30, - now all three of their types are fully complete and functional.
I assembled another cassette deck with defects from the remnants.
And there were defective parts left.
I also decided to restore the "music" in my garage torpedo. The old JVC CD-radio stopped working properly, so I decided to replace it with a practically new SONY with mp3, which I used in the car for a short time, before installing the original radios.
P.S.
I took the bumpers to the painter for painting. I hope that by the spring departure the car will be completely assembled.
The_Glory
Post Mon Mar 16, 2026 11:22 am
Odometer repair
I didn't have time to go on a trip, and it was already broken! )))
When I was assembling the dashboard, I replaced the broken odometer gears in it. But I used the original old gears from the "donor" dashboard. And in vain. The 40-year-old plastic in them was in the same condition, so they were only enough for 16 kilometers! )
So, it's time to go out again soon, so I decided to repair the odometer again to count that not significant mileage ;)
I removed the dashboard.
We unscrew the 4 self-tapping screws on the back of the speedometer.
We remove the green connector housing for additional options.
Now you can remove the speedometer from the dashboard housing.
The reason is immediately visible - a broken tooth on the brown gear:
We unscrew the two small screws and remove the transparent cover.
And we see broken teeth on the brown and green gears.
These two gears are quite easy to remove from the axles, but the green gear just fell apart!
This time I already bought a new repair kit for the Motometer gears. (For VDO, the gears differ in the number of teeth.)
The lower black gears are usually intact. But the upper ones, brown and green, are probably made of a different type of plastic, which after 40 years begins to decompose into atoms! )
We install new gears and lubricate with special silicone grease. The hole in the small yellow gear had to be slightly enlarged so that it fit tightly on the axle.
We install a transparent cover.
We install the speedometer and screw it in with four screws. We insert the green connector for additional options (cruise control, radio, telephone, automatic transmission, O2 sensor).
I hope that now the odometer will work for a long time.
We screw the case with the glass of the instrument panel.
We install the instrument panel on the car, and check all the connections to it. In my case, in addition to the standard connectors, these are a few more wires and lamps of additional options.
The_Glory
Post Tue Mar 31, 2026 2:30 pm
RAID Steering Wheel
Recently, at a club flea market, I accidentally and spontaneously bought an original RAID steering wheel with an adapter for a BMW E30.
In good condition and for a nominal amount. In fact, for the price of the adapter.
In principle, I bought it for the adapter and the "golden" screws.
To install it on my BBS handlebars, which I will restore someday...
RAID with a diameter of 32 cm, noticeably smaller than BBS
And probably "eccentric"
Probably, I'll install it on my car...although, we'll see... ) And for now, it will be just for the collection! ;)
But with the adapter, not everything turned out so simple. It turned out that the RAID has a diameter of holes with an M6 thread and a size of 6x74 mm, and the BBS has a diameter of holes with an M5 thread and a size of 6x70 mm. Therefore, they do not match.
In addition, the holes have a different location, relative to the "top" mark on the adapter. In RAID, the two upper holes are on the sides of the mark, and in BBS, one upper hole falls directly on the mark.
Therefore, even if you drill holes in the BBS steering wheel, it will either be crooked or the turn switch will not work. And even so, I would not dare to barbarically spoil such a rare steering wheel! )
That's why I decided to "spoil" the adapter! ) Between the 6x74 holes, I marked 6x70 holes, drilled and cut an M5 thread. Now the adapter has become more universal! ;)
The "golden" M6 bolts, of course, did not fit, but now the BBS steering wheel can be installed on this adapter. I tried it on - everything is OK.
There will be a separate post about the restoration of the BBS steering wheel someday, but for now, it will lie on the shelf in the garage with this adapter and the RAID steering wheel until better times...
The_Glory
Post Tue Apr 07, 2026 11:37 am
"Opening of the 2026 season"
Well, spring has come, dry, sunny weather. The puddles and mud have dried up. At least they patched up the potholes on the roads a little. I can try to drive on the E30! )
It sat in the garage for half a year. For some reason I didn't cover it with a tarpaulin right away, and then it was too late - it quickly became covered with a thick layer of dust... Something needs to be done with this "temporary" sand and gravel on the garage floor...
So first wash it with plenty of water from the hose to wash away as much sand dust as possible.
And then a regular gentle hand wash! )
A completely different look!
I drove down my street a few times - for the first time, that's enough! )
P.S.
So that the entry is not completely pointless, I will "announce" some news.
If you noticed, I removed the temporary front bumper. Because the bumpers are finally painted and waiting to be installed.
The_Glory
Post Tue Apr 14, 2026 12:05 pm
Painting bumpers part 3
Almost a year ago I already wrote about how I tried to paint bumpers myself.
Although, I was going to paint them at the painter who painted the car.
But the sellers at the paint selection convinced me that their paint, made according to the BMW code in aerosol cans, is no worse than the painter's.... I didn't really believe it, but I really wanted to quickly completely assemble the car and drive away! ) So I decided to try it...
Preliminarily, the chrome was completely removed with industrial sandblasting. Then the bumpers were treated with a rust converter, cleaned with a solvent. Aerosol acid primer was applied, and then aerosol 2-component acrylic primer. Then, as best I could, I puttied small defects on the surface, and blew with acrylic primer again.
And finally, I tried to paint a small panel from a can. It's good that I had the sense to not paint everything at once! I didn't get the color or texture right! )) It turned out to be some kind of solid matte shagreen! Or crap! ))) Which after a while also cracked with tiny cracks...
So, no matter what kind of paint was in the aerosol can, you can't paint a car with it properly! Now, I know that for sure! )
The primed bumpers lay in the garage for almost a year. I'm glad that no rust has formed on them during this time!
And finally, I made an agreement with the painter and took the bumpers to him for painting. He said that I was a very bad "painter"! )) And it would be better if I didn't do anything! )) But, we have what we have! )
He re-plastered and primed them.
And in the end, I got beautifully painted bumpers.
But the inside wasn't completely painted. So I decided to paint it anyway - don't waste the paint in the can! ) I've already painted the bottom of the car the same way before - it turned out fine.
For the inside, spray paint was just right!
Then I coated the inside of the bumpers with a clear wax anti-corrosion agent.
The final result - the bumpers are ready for assembly.
It turned out not bad...
The_Glory
Post Sun Apr 19, 2026 8:54 am
Assembly_197. ETK_51_Front bumper (part 1)
Finally, it's time to install the bumpers. I'll start with the front one.
Front bumper
Part #1 - middle front bumper (51 11 1 888 265) - standard chrome bumper.
But in my case it is now - primed middle front bumper (51 11 1 959 911) - optional bumper for painting in body color. Used with the option "S339 Shadow Line equipment kit".
Part No. 2 - left front bumper (51 11 1 888 391) - standard chrome bumper.
But in my case it is now - primed left front bumper (51 11 1 959 907) - optional bumper for painting in body color. Used with the option "S339 Shadow Line equipment kit".
Part No. 3 - right front bumper (51 11 1 888 392) - standard chrome bumper.
But in my case it is now - primed bumper right front (51 11 1 959 908) - optional bumper for painting in body color. Used with the option "S339 Shadow Line equipment kit".
Part No. 4 - left trim (51 11 1 888 269) - for the standard chrome bumper.
But in my case it is now - primed left trim (51 11 1 959 887) - optional trim for painting in body color. Used with the option "S339 Shadow Line equipment kit".
Part No. 5 - right trim (51 11 1 888 270) - for the standard chrome bumper.
But in my case it is now - primed right trim (51 11 1 959 888) - optional trim for painting in body color. Used with the option "S339 Shadow Line Equipment Kit".
Part No. 6 - screw (51 12 1 843 029) - 4 pcs. Flat head screw for square hole. I bought similar M8x25 screws at a hardware store. For assembling bumper parts.
Part No. 7 - nut with washer M8 (51 11 7 070 183) - 6 pcs. For assembling bumper parts and attaching them to brackets.
Part No. 8 - leaf nut ST4,8-13-ZNS3 (07 12 9 904 223) - 2 pcs. For fastening pads No. 4, No. 5.
Part No. 9 - self-tapping screw ST4,8X13-Z2 (07 11 9 907 957) - 2 pcs. For fastening pads No. 4, No. 5.
Part No. 10 - protective strip (51 11 1 888 266) - 1 pc. Central plastic plate for the license plate. For the M-Technic I body kit, a plate (51 11 1 953 715) is used, which compensates for the gap from the apron.
Part No. 11 - left protective strip (51 11 1 888 273) - 1 pc. Left plastic trim. For the M-Technic I body kit, a trim (51 11 1 953 713) is used, which compensates for the gap from the apron, and does not have a lower protrusion on its extreme end.
Part No. 12 - right protective strip (51 11 1 888 274) - 1 pc. Right plastic trim. For the M-Technic I body kit, a trim (51 11 1 953 714) is used, which compensates for the gap from the apron, and does not have a lower protrusion on its extreme end.
Part No. 13 - strip clamp (51 11 1 838 076) - 8 pcs. Clips for attaching the strips. For the M-Technic I body kit, a threaded clamping screw (51 11 1 919 151) - 6 pcs. and M6 nuts (07 14 7 134 319) - 6 pcs.
Part No. 14 - bracket (51 11 1 888 122) - 2 pcs. Brackets for attaching the bumper to the body.
Part No. 15 - bolt M8X16-8.8-ZNS3 (07 11 9 902 900) - 4 pcs. Fastening the brackets to the body. The ETK also indicates M6x16 bolts, but this is probably another mistake.
Part No. 16 - self-tapping screw ST6,3X22-C-Z2 (07 11 9 916 971) - 2 pcs. For attaching the bumper on the sides.
Part No. 17 - protective cover (51 11 1 888 293) - 2 pcs. Plastic plug for attaching the bumper to the brackets.
Part No. 18 - leaf nut ST6,3 (51 11 1 900 386) - 2 pcs. For attaching the bumper on the sides.
Part No. 19-22 - not used. These are side panels consisting of two separate parts. They were used on the earliest cars.
Part No. 23 - a set of fastening elements ( 51 11 9 057 083). A complete set of fastening elements for assembling and installing the front bumper, including parts No. 6 - No. 9, No. 13-No. 18. Unfortunately, it is no longer available for order.
In the photo from the Internet, there are even clips for attaching the license plate and some other unnecessary elements.
So, first we screw the bumper brackets to the side members. Two M8 bolts on each side.
The bracket is placed in this position - with the straight side up, and the beveled side down.
Installed. They do not require any position adjustments. The size of the holes on the bumper is sufficient for this.
Now we start assembling the bumper itself.
We fasten the side parts to the bumper - 2 bolts and M8 nuts each.
Since I am not using the original bolts, I had to cut off the cap a little on the two upper bolts so that it would not interfere with installing the pads later.
The rounded cap on the front two bolts does not interfere.
We do not tighten the nuts immediately. We try on the bumper, adjust the angles of the side parts in relation to the body.
After that, we carefully remove the bumper and tighten all four nuts. We install the mounting plate for attaching the pads.
We put the cover on the bumper and screw it in with a self-tapping screw.
Done.
The cover is good, the sawn-off bolt head does not interfere.
There are some more holes on the side parts of the bumper, but I don’t understand what they are for. There are no corresponding holes in the central part, so they are not used.
We install special mounting plates with a plastic spacer on the sides of the bumper and self-tapping screws for fastening.
The metal parts are assembled. Now you need to install the plastic linings. They are attached using metal clips. To make the clips hold better in the linings and press them, I glued splen gaskets to them.
We insert two clips into the side linings and four clips into the central lining. In the central lining, they are initially placed only at the edges. The two clips under the license plate are inserted after the lining is installed on the bumper.
We snap the clips into the holes in the bumper. The clips are not new, they have lost a little elasticity, so some of them had to be pulled out from the inside to lock them in place.
Two clips on the sides. You need to make sure that the plastic guides also fall into the corresponding holes on the bumper.
You also need to carefully hook the upper part of the trim with a special hook to the edge of the bumper. Often it is already broken.
By the way, when installing the M-Technic I body kit, it is not necessary to install other M-Technic I side panels. According to the EBA factory instructions, it is allowed to simply cut the lower protrusions at the extreme ends of the side panels.
Now we snap the two central clips - from the outside, right through the panel.
The plastic panels are installed.
As I wrote above, to attach the plastic overlays, you can use the original M-Technic I body kit mount, which is a metal mounting plate with an M6 threaded stud, which is pressed from the inside with an M6 nut. This will be easier, more reliable and faster. You will need 6 pieces in total. The central mount under the license plate remains on two standard metal clips.
The front turn signal housing is also part of the bumper overlays. We insert them from the outside, align all the overlays and press them, screwing the turn signals with two self-tapping screws.
The front bumper is assembled. Only two plugs remain to be installed after it is installed on the car.
The bumper is ready for installation.
The_Glory
Post Sun Apr 19, 2026 9:59 am
Assembly_197. ETK_51_Front bumper (part 2)
So, let's start installing the front bumper.
Connect the connectors of the front turn signals and check if they work properly. It's better to do this right away, because then you won't be able to get to these connectors without removing the bumper.
Put the bumper on the studs of the brackets and fix them with nuts, without tightening them.
To secure the bumper on the sides, you need to remove the plastic shields in the wheel arch. That's why I didn't screw them in these places when I installed the lower protective shield.
Lower the shield down and unscrew the front part of the wheel arch shield and gain access to the side bumper mount.
Align the bumper and screw the self-tapping screw into the mounting plate installed on the bumper.
Now I can fully secure the protective shields. Two mounting plates on the lower edge of the wheel arch.
And one mounting plate on the lower protective shield.
We tighten three self-tapping screws and one plastic nut on the spar.
Similarly on the right side.
The wheel arches are completely closed.
Now tighten the front nuts on the bumper brackets and close them with plugs.
The arrows on the plugs show "top". This is the position in which they should be installed.
In this case, it will be very easy to remove them through a special hole under them - by pressing a screwdriver from the middle on the "ear" of the plug.
And you won't need to pry them from the front, as most do.
So, the front bumper is installed.
Maybe not ideal, but I like it! )
In my opinion, a body-colored bumper looks much nicer than a completely black bumper.
Cute face! )
The_Glory
Post Tue Apr 21, 2026 8:10 am
Assembly_198. ETK_51_Rear bumper (part 1)
Installing the rear bumper.
Rear bumper
Part #1 - middle rear bumper (51 12 1 888 276) - standard chrome bumper.
But in my case it is now - primed middle rear bumper (51 12 1 959 914) - optional bumper for painting in body color. Used with the option "S339 Shadow Line equipment kit".
Part No. 2 - left rear bumper (51 12 1 922 161) - standard chrome bumper.
But in my case it is now - primed left rear bumper (51 12 1 959 901) - optional bumper for painting in body color. Used with the option "S339 Shadow Line equipment kit".
Part No. 3 - right rear bumper (51 12 1 922 162) - standard chrome bumper.
But in my case it is now - primed right rear bumper (51 11 1 959 902) - optional bumper for painting in body color. Used with the option "S339 Shadow Line equipment kit".
Part No. 4 - left trim (51 12 1 888 283) - for the standard chrome bumper.
But in my case it is now - primed left trim (51 12 1 959 895) - optional trim for painting in body color. Used with the option "S339 Shadow Line equipment kit".
Part No. 5 - right trim (51 12 1 888 284) - for the standard chrome bumper.
But in my case it is now - primed right trim (51 12 1 959 896) - optional trim for painting in body color. Used with the option "S339 Shadow Line Equipment Kit".
Part No. 6 - screw (51 12 1 843 029) - 6 pcs. Flat head screw for square hole. I bought similar M8x25 screws at a hardware store. For assembling bumper parts and attaching them to brackets.
Part No. 7 - nut with washer M8 (51 11 7 070 183) - 8 pcs. For assembling bumper parts and attaching them to brackets. The ETK indicates 6 pcs. - this is a mistake.
Part No. 8 - protective strip (51 12 1 888 286) - 1 pc. Central plastic overlay. For the M-Technic I body kit, an overlay (51 12 1 953 890) is used, which compensates for the gap from the apron.
Part No. 9 - strip clamp (51 11 1 867 927) - 15 pcs. Clips for fixing the strip. For the M-Technic I body kit, a threaded clamping screw (51 12 1 932 230) - 15 pcs. and M6 nuts (07 14 7 134 319) - 15 pcs.
Part No. 10 - rubber washer (51 12 1 886 299) - 4 pcs.
Part No. 11 - M6 nut (07 14 7 134 319) - 2 pcs. The ETK indicates 6 pcs. - this is an error.
Part No. 12 - bracket (51 12 1 916 597) - 2 pcs. Brackets for attaching the bumper to the body.
Part No. 13 - left locking element (51 12 1 888 287) - 1 pc. Left plastic end cap. For the M-Technic I body kit, a cap (51 12 1 953 711) is used, which does not have a lower protrusion on its extreme end.
Part No. 14 - right locking element (51 12 1 888 288) - 1 pc. right plastic end cap. For the M-Technic I body kit, a cap (51 12 1 953 712) is used, which does not have a lower protrusion on its extreme end.
Part No. 15 - leaf nut ST6.3 (51 11 1 900 386) - 2 pcs. For attaching the bumper on the sides.
Part No. 16 - self-tapping screw ST6.3X22-C-Z2 (07 11 9 916 971) - 2 pcs. For attaching the bumper on the sides.
Part No. 17 - self-tapping screw ST6.3X32-C-Z1 (07 11 9 916 975) - 2 pcs. For attaching the end caps to the body. There is probably also a mistake here - a self-tapping screw 32 mm long will go through this cap. Therefore, I use self-tapping screws No. 16 and No. 17 vice versa.
Part No. 18 - hose 8X13X80 (16 12 1 176 779) - 1 pc. This is some very mysterious, and incomprehensible part. I can't imagine where in the bumper mount you can use a piece of fuel hose.... If anyone knows - I will be grateful for the information. Perhaps this is also some kind of mistake, or they meant some rubber gaskets for self-tapping screws...
Part No. 19 - shield (51 12 1 911 293) - 2 pcs. This is a decorative plastic cap for the upper M6 nuts securing the bumper brackets to the body. The ETK indicates 4 of them - this is a mistake, because the lower studs of the brackets have an M8 thread, so they won't fit there.
Part No. 21...№25 - I also don't understand the details. Perhaps they were used on some early versions instead of parts #17, #18. Again, #23 is indicated as a fuel hose... There are some holes on the bumper at the edges, perhaps the end plates were attached with these M6 bolts and nuts. In my case, there is no place to use them.
Part No. 26 - set of fastening elements (51 12 9 057 084). A complete set of fastening elements for assembling and installing the rear bumper, including parts No. 6 - No. 7, No. 9-No. 11, No. 15-No. 19. Unfortunately, it is no longer available for order.
In the photo from the Internet, there are even some extra elements.
The procedure for assembling and installing the rear bumper is different from the front.
We begin to assemble the bumper itself.
Since I'm not using original bolts, I had to cut off the cap a little on the two upper bolts so that it wouldn't interfere with installing the pads. The pads are screwed on at the same time, with the same front bolts. The rounded cap on the front two bolts doesn't interfere. I also used washers.
We don't tighten the nuts right away. We try on the bumper, adjust the angles of the side parts relative to the body. After that, we carefully remove the bumper and tighten all four nuts.
Done. The pad is good, the sawn-off bolt head doesn't interfere.
Now we screw the brackets to the bumper. According to ETK, similar bolts and nuts M8 are used for this. But, in my case, the previous owner welded these bolts to the bumper. In my opinion, it is even much more convenient.
We screw the brackets in this position. As you can see in the photo - the upper stud has an M6 thread, and the lower one - M8. Accordingly. and the nuts are different. Therefore, decorative plastic caps fit only on the upper M6 nuts.
There are some more holes on the side parts of the bumper, but I don't understand what they are for. There are no corresponding holes in the central part, so they are not used.
Now you need to install the plastic pads. They are attached using metal clips. To make the clips hold better in the pads and press them, I glued splenic pads to them.
Insert the clips into the pad, turning them 90 degrees into the groove of the pad.
Place them opposite the holes in the bumper.
In the middle part of the bumper there are 7 pieces.
In the side parts of the bumper there are 4 pieces on each side.
Align the middle of the lining in the middle of the bumper, so that there is enough length of the lining on both ends. Start snapping the clips from the center to the edges.
The clips are not new, they have lost a little elasticity, so some of them had to be pulled out from the inside to fix them.
We insert the end pads into the grooves, snap them into special holes, pressing them against the central pad. You also need to carefully hook the upper part of the pad with a special hook to the edge of the bumper. Often it is already broken.
By the way, when installing the M-Technic I body kit, it is not necessary to install other M-Technic I end caps. According to the EBA factory instructions, it is allowed to simply trim the lower protrusions on the extreme ends of the caps.
The plastic caps are installed.
As I wrote above, to attach the plastic caps, you can use the original M-Technic I body kit mount, which is a metal mounting plate with an M6 threaded stud, which is pressed from the inside with an M6 nut. This will be easier, more reliable and faster. A total of 15 pieces are required.
The front bumper is assembled and ready for installation.
The_Glory
Post Wed Apr 22, 2026 10:50 am
Assembly_198. ETK_51_Rear bumper (part 2)
So, let's start installing the rear bumper. To do this, you need to remove the rear panel trim in the trunk. Also, for convenience, it is better to remove the battery (if it is installed in the trunk).
The rear bumper is more difficult to install than the front one, due to its large side parts - you can scratch the rear wings or apron. In addition, it is not very easy to get all four pins into the corresponding holes in the body at once. Therefore, it is better to do this together, with an assistant.
The brackets should not be fully tightened so that they can be adjusted using the holes in the body. Insert the bracket pins into the holes and adjust the position of the bumper. Carefully remove the bumper, and in this position tighten the nuts of the brackets without moving them. Now you can install the bumper and secure it with four nuts.
Two nuts with M6 washers in the trunk, above the floor. Under the nut, install a rubber sealing washer to prevent water from entering the trunk.
We install plastic caps on the nuts.
Two nuts with M8 washers on the rear spars, under the trunk floor.
To secure the bumper on the sides, you need to screw two self-tapping screws into the trunk through special holes in the rear wings. Under the self-tapping screw, install a rubber sealing washer to prevent water from entering the trunk. There is a special cutout in the trim for this. Align the side parts of the bumper and screw it into the mounting plates with self-tapping screws.
On the right side, similarly, only in my case, for better access, you need to remove the battery. The trim does not cover this place.
On the inside of both wheel arches, you need to screw a self-tapping screw through a special hole in the arch. For convenience, it is better to jack up the car. We install a rubber sealing washer under the self-tapping screw to prevent water from entering the wheel arch. This self-tapping screw fixes the bumper end cap.
The left side is ready.
Everything is similar on the right side. The only difference is that the plastic protective shield bracket is also attached to the wheel arch with a self-tapping screw.
The right side is ready.
After installation, I treated all the nuts and screws with a wax anti-corrosion agent.
The rear bumper is installed.
Not everything is perfect, but overall I really like it! )
P.S.
I put my old black front bumper back on my "E30 nightstand" - I'll probably finish it someday... )
The_Glory
Post Sat Apr 25, 2026 3:16 pm
Assembly_199. ETK_51_License plate mounting
Bumpers installed, now I can install license plates.
The front license plate mounting is not indicated in the ETK for some reason. But, judging by the bumper design, the old mounting, the photo on the Internet, and simply by logic, it is similar to the rear license plate mounting, which is indicated in two sections of the ETK. So, I have already written about this twice, but now I will repeat it again, - more specifically.
The section on the rear of the body lists the following details for attaching the rear number plate:
Part No. 9 - insert nut (51 18 1 852 299) - 2 pcs. Plastic sleeve for self-tapping screw.
Part No. 10 - washer 6.4 (07 11 9 931 044) - 2 pcs. Metal washer for self-tapping screw.
Part No. 11 - self-tapping screw ST4.8X16MM (07 14 3 448 498) - 2 pcs. Pan head self-tapping screw.
Part No. 12 - protective cap WEISS (51 18 1 813 017) - 2 pcs. White plastic cap for self-tapping screws.
Part No. 12 - protective cap SCHWARZ (51 18 1 823 474) - 2 pcs. Black plastic cap for self-tapping screws.
Part No. 12 - protective cap BLAU (64 11 1 375 497) - 2 pcs. Blue plastic cap for self-tapping screws.
So, a similar mount is used for the front bumper, so I immediately ordered two sets of these parts.
Out of curiosity, I ordered protective caps in all three colors - white, black, blue. In fact, the blue ones turned out to be a very dark shade, and from afar they look almost black.
The front bumper has special holes for mounting a license plate.
There are four holes. The additional two holes are located closer to the edges of the license plate, but are closed with plugs on the plastic bumper cover. If necessary, they can be cut out and the number plate can be attached closer to the edges.
But I will use the existing standard holes. We will snap plastic sleeves into them.
Done.
For attaching modern license plates, special plastic frames are usually used. In my case, these are our "club" frames. At first, I thought I would have to abandon them, because the screws are quite short. But it turned out that their length was enough to screw the number plate through with the frame. We just had to drill the corresponding holes in the license plates.
We screw the number plate with the "club" frame with two self-tapping screws with washers to the front bumper.
The screws fall on a white background, so we use white caps for them.
By the way, when changing the color, I'll probably order new license plates at the same time, because these ones don't look very good anymore..
The caps simply snap onto the screw head.
The front number is installed.
I already mentioned the rear number earlier. There is one nuance there. If you use the original black plastic plate under the number, you need to install different plastic bushings.
You can see the difference between them in the photo. The white bushings have a larger diameter head.
Part No. 5 - insert nut (51 18 1 916 071) - 2 pcs. Plastic sleeve for self-tapping screw.
White sleeves simultaneously press the plastic trim to the body.
We fasten the number with the "club" frame with two self-tapping screws with washers to the rear panel of the body.
The screws are on a white background, although one of them slightly touched the black letter. We use white caps for them.
The rear number is installed.
By the way, about the colors of the caps. At first I thought that they play a purely decorative role. That is, whoever likes which colors more, installs them. But after carefully looking at the photos in the factory advertising booklets of those times, I noticed that these caps always match the color of the license plate they are on. In other words, they "mask" the screws against the background of the license plate. And if necessary, even different colors are used on the same number. Here are photo clippings from the advertising booklets.
Two black caps on the letter S and the number 6:
On the same car, the front number, there is already a white cap near the letter S and a black one on the number 6:
A white cap on a white background and a black cap on the number 4:
That's such a "decorative camouflage"! )
Well, my E30 finally has a complete appearance!
Beautiful! ;)
All that remains is to re-register the body color in the technical passport and get insurance so that I can drive.
By the way, next time I'll probably write about the "factory documentation".
The_Glory
Post Wed Apr 29, 2026 3:20 pm
Assembly_200. ETK_01_Technical Literature
So, this is the 200th, "anniversary", entry on the assembly of my E30, according to the ETK sections. Externally, the car is fully assembled, - all the main ETK sections are described in detail (actually, not quite all, - there will be a few more entries a little later).
The last ETK section remains, which, in fact, is the first in its list! Namely:
This section concerns various technical factory literature and documentation. It has many sections - instructions, service books, accessory catalogs, advertising booklets, forms, stickers, tags, folders, CDs, etc.
Of course, I don't see the point in writing about it all here.
Since, as new BMW E30 cars, like all others, were once equipped with a minimum set of technical literature, which included a user manual and service books. Depending on the configuration, there could be additional instructions for accessories or booklets. In the USA, the service manual was even dubbed on an audio cassette.
Unfortunately, nothing of the technical literature has survived in my car. Therefore, this record has no practical meaning - it's more like a "fetish"! ))
So, I collected a set of factory technical literature, although it has no direct relation to my car. We have what we have! (c)
I have already mentioned this in various posts, but now I want to summarize, so to speak.
All books are stored in the original leather BMW folder of that time.
The manual and service books are enclosed in the original transparent envelope. The folder has one wide section and two special transparent pockets for cards.
My set consists of a user manual, a service book, a book with maps and addresses of BMW service centers in Western Europe, a radio receiver manual and a card with its code.
User manual.
Usually, the manual is designed for a specific BMW E30 model, and has a cover with a picture of the hood of a red E30. In my case, this is a more universal manual, for almost the entire BMW E30 model range.
Contains a description of all BMW E30 models and body types.
Service book.
As I said, it has nothing to do with my car. This is a book from a restyled BMW 316i in silver, which was purchased in 1988 in Germany, in the city of Lennestadt at the STRUEWE dealership.
So, a small "lyrical-historical digression" )
The history of maintenance is not extensive, but it is there.
As far as I understand, BMW gave a 5-year warranty on the body, with an annual paid inspection at the dealer service center.
But in this case it was carried out only in the first and second year.
Based on this service book, I ordered an exact copy.
I filled it out myself, with current data at the time.
Since I will not trust anyone to service my E30, I will keep the service book myself! )) Date of the first engine start after assembly.
With my annual mileage, I think this book will last me a very long time! )
A book with maps and addresses of BMW service centers in Western Europe, as of 1987/88.
This book also does not correspond to the years for my car. Maybe someday I will find one for 84/85... but for now this one will do.
Maps of Western Europe
Addresses of BMW service centers
Currently, the car has an original BMW BAVARIA C BUSINESS radio. Accordingly, the instructions and the card with the code for it.
I will still need to find and buy instructions for the rest of my radios.
Everything fits in a transparent envelope.
Each new car from the factory was equipped with a tag containing basic information about the car - VIN code, model, color and type of interior upholstery, body color, production date with an accuracy of up to the minute, additional option codes and some other factory codes and contract and order numbers.
A friend once gave me such a tag, from his former car.
This tag was stored under the frame of the rear seat, or behind its back. Photo from the Internet.
Again, this tag has nothing to do with my car. It is from a white (218 ALPINWEISS) BMW E30 1989, with a blue interior (BMW E30 Diagonal 0271 Indigo Blue Middle Lane).
I have translated and decoded this data. Maybe someone will be interested. The data that I don't understand, I marked (?):
Order No. 500 (?)
Model 1411 (by VIN code)
Interior upholstery 0271 (main color of upholstery)
Interior upholstery version 310 (combination of seat and sidewall colors)
Body No. WBAAD11000 AF51214 (VIN code)
Special order No. 0 (?)
Color 218 (body color)
Contract No. 00095541 (?)
Date of production 11/29/89 Time 8:05 PM
Request H17 (?)
Manufactured 4720 (?)
Serial No. 500 (?)
Option code: (by VIN code)
Then I made a "replica" of such a tag for my car! ;) Not an exact copy, and the data, but something similar... )
The upper one, according to the VIN code and factory configuration of my car.
The lower one - in fact, for now. A different color, and a few more options ;)
I put the upper tag in its place - behind the back of the seat.
And I put the lower one in a folder, along with technical literature. I put the folder in a box for small items.
Since we're talking about tags and the VIN code, I'll also write about the duplicate plate, although I've already mentioned it before.
I haven't had it since I bought the car. The technical passport has a note about it - "Duplicate plate missing". So I ordered a new original blank plate and installed it just "for beauty".
But unexpectedly, the previous owner of the car found this plate and gave it to me!
I even ordered the original rivets again to install it.
But it doesn't look very nice, so I haven't decided yet whether it's worth doing it...
I'll try to restore it a little, touch it up. Maybe I'll replace it when I re-register the car's color so that there are no discrepancies in the documents... Or leave it as is?
As I said above, I'll service my E30 myself, so I also made these OILSERVICE tags so that they are in a visible place.
I didn't fill in the sticker for the scheduled belt replacement, because it's glossy and the pen doesn't write on it! ))
The disadvantages of the "replica" )) Then I'll write with a thin marker. Although, the replacement will not be very soon...
That's all, with the technical documentation!
Maybe later, I'll add something to it, or replace it...
The_Glory
Post Mon May 11, 2026 8:22 am
Emergency flashlight
I have written about this emergency flashlight before - then I just cleaned it and put it away. Finally, it was time to make it fully functional. I bought batteries.
You need 5 R20 batteries.
Insert the batteries, observing their polarity.
Close the case cover.
Check - it's shining!
In "emergency" mode, the yellow light flashes.
Pretty bright!
Especially in the dark.
A white flashlight too.
It illuminates well all around.
It has a convenient stand.
Which folds compactly when stored.
On the back side there is a mode switch and instructions for use in German.
The switch is in the "off" position.
The top mode is a white light.
The bottom mode is an emergency flashing yellow light.
At the very bottom there is a "test" mode for checking the batteries, but I don't really understand what it is for...
Instructions for the type of batteries - R20 1.5V 5 pieces.
Instructions for checking batteries.
Instructions for replacing 6V 2.4W bulbs.
The flashlight, along with the spare bulb unit, fit very well in the empty compartment of the original first aid kit and emergency stop sign box.
I also remembered the regular flashlight in the small box. I also wrote about it earlier. Finally, I found and bought new batteries of the right type for it.
I need 2 pieces. But I bought them in reserve )
But for some reason I can't disassemble the body of this flashlight. It is glued together and does not want to separate.... I'm afraid to break it... So for now I left it as is.
Especially since now there is a much more powerful flashlight in the trunk! )
P.S.
Summer is coming soon, hot weather is starting - it's time to finish installing the air conditioner! ) Next time, I'll probably write something about restoring the air conditioner compressor.
The_Glory
Post Mon May 11, 2026 8:47 am
Disassembly of the BOSCH BEHR R12 air conditioning compressor (training)
Finally, it came to the last element of the air conditioning system - the compressor.
I have three of them. All for BMW E30 with an M20 engine with a pulley for a "V" belt.
The first.
The second.
The third.
The first one that was purchased in the air conditioner kit is a BOSCH BEHR compressor for R12 freon. Apparently this is an earlier version, without an oil temperature sensor on the compressor housing and with a 1-pin connector.
Although, judging by the ETM wiring diagrams, it is the opposite - early compressors were with this sensor, and later ones without it. It is not very clear, but in fact later compressors usually, after all, have this sensor.
I have already told the sad story of the previous owners about installing this compressor with a mount for the M20 motor on the M42 motor, using a homemade "adapter". I don't know what was the reason - this "adapter", or maybe some kind of accident, but the compressor was thrown out, along with parts of its housing.
Over the years, everything there has rusted to death. Of course, it's junk.
Therefore, I immediately bought another compressor - SEIKO. And even started to disassemble it a little.
But from the remnants of the text on the stickers, I realized that it is for freon R134a. Moreover, it was all wet and covered in grease with a green fluorescent dye - that is, it was definitely leaking, and quite a lot. It definitely needs repair.
So I bought a third compressor - again BOSCH BEHR for R12 freon, but a little newer, removed from a BMW E34. It already has a compressor oil temperature sensor and a 3-pin connector installed.
The difference between the first and third compressors is precisely the presence of this sensor and its wiring. The first still has a valve on the inlet fitting for pumping, while the third does not. Structurally, they are identical.
So, I will install the third one.
I have never dealt with these compressors before, so I started looking for information on the Internet. I read that very often a lot of dirt collects in the compressor, which can get into the entire system after it is started. Since my entire system is clean and assembled from scratch, I really would not like this! So, I decided to disassemble and clean the compressor before installation, just in case. I turned to specially trained specialists. ) But all of them, having heard about the 40-year-old compressor for the BMW E30, which had been lying idle for many years, advised me to throw it away and find a new one ))) And when I told them about R12 freon, they almost didn't send me! )))
Therefore, as always - if you want to do something well - do it yourself! )
I started looking for information on repairing such compressors. I only found some articles with randomly placed photos, but practically no text explanations. I don't understand why people make such "reports" if they are of no practical use to anyone... Well, that's it.... That's why I always write in great detail! Maybe sometimes, even too much... ;)
So, not finding anything, I decided to "practice" on my first broken compressor. After all, it won't get any worse from this! ))
Since it was just a "practice", I will write the same stupid "report" as I found on the Internet! )) Just photos and a minimum of text.
A normal report will be when disassembling a working compressor.
So, let's start with the simplest thing - remove the inlet fitting and unscrew the electromagnetic coupling diode.
There's a check valve inside - it's a complete mess! )
We unscrew 8 nuts, but the cover doesn't come off. Inside you can also see a whole trash...
You need to unscrew 4 more bolts. To do this, you first need to remove the pulley and the clutch.
The bolt on the pulley unscrewed easily. At first I thought that the pulley unscrews along the internal thread. It turned out that it doesn't. In general, it is not clear why that thread is there. By trial and error, it turned out that the pulley simply comes off upwards. But no pullers will help - there is nothing to catch and rest against. So I removed it this way - carefully driving a screwdriver in a circle between the pulley and the pressure plate.
And it worked.
Unscrew the nut and remove the pulley. It's easy.
Unscrew and remove the electromagnetic clutch with the wiring.
Now you can unscrew the 4 bolts.
But they are VERY tight! So the disassembly stopped for a while...
These bolts were unscrewed only with an impact wrench.
We remove the cover and see this picture! )) In this case, the experts were 100% right )) Although, it was obvious... ) But here the whole point is in "training" ))
We knock out the key and remove the gland with seals.
Remove the remaining sealant from the lid.
Remove the sleeve from the cover.
There is also a seal in it.
This concludes the "training".
Further disassembly is possible, except with the help of a "grinder"! ))
But that doesn't make sense anymore.
Especially since I still found normal reports on the repair of such a compressor on old American forums.
Next time I will disassemble a working compressor.
The_Glory
Post Tue May 19, 2026 3:08 pm
Interesting chemical experiments - metal blueing
I'm getting ready to assemble the air conditioner compressor - I sent the housing and small parts and bolts to electroplating for zinc plating, bought a repair kit for seals, ordered new stickers.
When disassembling the compressors, I noticed that the inlet flange had some kind of factory black coating. Or rather, its remains. So I decided to try to restore it.
At the same time, I'll conduct interesting chemical experiments! ;) I've already written about my attempts to copper-plate metal in garage conditions, but the results were not satisfactory.
So, the next experiment is chemical (cold) blueing of metal. For this, I bought such a kit - a special liquid 100 ml, an abrasive for surface preparation and instructions.
I decided to experiment on the compressor flange. The factory coating on its lower part was completely preserved, so I decided not to remove it and covered it with masking tape. Since I was not sure of the results...
I sanded the upper part, washed it thoroughly and blew it with air. It seems that everything is ready for the experiment.
But the instructions are for fools! )) I just took it and treated the flange with liquid in two layers - it immediately became a beautiful dark black color. Well, great, right! ) I left it to dry, and when I came to evaluate the result, I was, to put it mildly, confused!... ))) It was simply completely rusted! )))
Not at all the result I was hoping for.... ) It resembles the result of copper plating, but even worse )))
I contacted the seller, who explained to me how to do everything correctly. Although, it was enough to just carefully read the instructions first! )
So, the second attempt.
The parts must be thoroughly cleaned of rust, dirt, dust, and degreased with a solvent.
For quick drying, I used paper towels and an industrial fan heater. Motor oil is used to preserve the coating.
This time I have already taken both inlet flanges from both compressors. I started with the flange from the broken compressor.
We treat it with liquid using a brush, remove the remaining liquid by blotting with a paper towel, and let it stand for no more than 1 minute. After that, we apply a second layer, and let it stand for no more than 1 minute. We thoroughly rinse the part under running water. We quickly wipe it dry with napkins and dry it with a fan heater.
We treat the part with motor oil to preserve the coating. We wipe off the remaining oil with paper towels. We wipe with a soft cloth. As a result, we get a beautiful matte black coating.
I repeat the same process for the working compressor flange.
The first layer after drying, no more than 1 minute.
The second layer after washing and drying, no more than 1 minute.
Preservation with motor oil.
The finished result after wiping off the oil.
Beautiful matte black finish.
The second attempt was even more successful! )
In my opinion, it looks pretty good, but we'll see how long it lasts...
P.S.
It's important to do exactly as the instructions say! Do everything quickly! Otherwise, if you leave it for too long, or don't rinse it well, or don't preserve it, the part will rust completely very quickly, right before your eyes!
P.P.S.
I restored the wheel bolts on my E53 in the same way.
I think that in this case, it will become clear how reliable this coating is!
It's been holding up for a week! ;)
The_Glory
Post Mon May 25, 2026 11:42 am
Disassembly of the BOSCH BEHR R12 air conditioner compressor
So, having "practiced" on a broken compressor, I am now disassembling my working compressor to make sure that it is clean and in good condition inside.
Let's start with the pulley. We unscrew the central bolt on its axis.
To keep the pulley from rotating, my old homemade "special tool" came in handy.
The bolt unscrewed quite easily, but the clutch pressure plate cannot be removed.
The internal thread on it confused me a bit. Although I saw a keyway, I initially thought it was screwed on with some kind of bushing on this thread. I tried to "twist" it with a screwdriver and a hammer, but of course, it was useless. I never understood why that thread was there, because, as it turned out later, it is not used at all. Perhaps on other cars something else is screwed there. But not on the E30.
In the end, having found sensible information on American forums, I understood that the disc is simply removed from the key upwards. But no puller is suitable, because there is nothing to hook it on and push it against. The "wedge-up" method turned out to be effective. That is, I carefully hammered screwdrivers evenly around the circumference, between the pulley and the clutch pressure plate, until it broke off the axis and the key.
The disc has been removed. You can see the cutout for the key. A cylindrical metal spacer and two washers of different thicknesses were installed in it. Obviously, these washers are needed to adjust the gap between the pulley and the clutch pressure plate.
Now there is access to the fastening of the pulley itself.
We clean the nut, bend the ears of the lock washer with which it is fixed.
Using a screwdriver and a hammer, carefully unscrew the nut. Or use a special wrench, if available.
Remove the lock washer from its groove.
Remove the pulley, without much effort.
If you need to replace the bearing, remove the retaining ring and press out the bearing. In my case, the bearing is in excellent condition, so I will not remove it.
Now you can remove the electromagnetic clutch, which is fastened with six screws.
You also need to unscrew one of the nuts holding the coupling diode.
Then we unscrew the compressor oil temperature sensor. In fact, it does not have a through hole and direct contact with the oil. It measures the temperature of the compressor housing.
The electromagnetic clutch with wiring and temperature sensor has been removed.
Unscrew the two screws and remove the inlet fitting.
Carefully remove it from the compressor housing. It is removed with little effort, since there is a rubber seal on it.
On the lower part of the fitting there is a check valve with a spring. It is removed simply by slightly bending the four ears of the valve holder from the groove.
It is clean inside. This gives me hope! )
Under the electromagnetic clutch on the cover there is some part that I do not understand - a plastic holder with a felt insert.
It simply lies on the lid in special grooves made according to its shape. Does anyone know what its purpose is? Let's take it out.
We unscrew the eight nuts along the contour of the lid and remove the special bolts with a cut head.
Then you need to unscrew the four bolts with an internal hexagon. At this point, the disassembly stopped a bit. These bolts are tightened with a very high torque. To unscrew them, I had to go to a friend who has a pneumatic impact wrench. There were copper washers under the bolts.
Carefully remove the cover.
Everything is clean and lubricated under the cover - which is pleasing.
Pay attention to the location of the compressor in the housing - a large triangular arrow points to the outlet fitting on the housing.
The lid is clean, but the seals will of course be replaced with new ones.
A metal sleeve is installed in the lid.
Which is fixed externally in the lid with a retaining ring.
Remove the retaining ring and take out the bushing.
A rubber seal is installed on the bushing.
To remove the shaft seal, you need to knock out the key.
Carefully remove the shaft seal.
It consists of a plastic housing, and a ring made of some kind of carbon, or something similar, that is inserted into the plastic housing.
Remove the spring and rubber seal from the inner hole of the cover.
Two parts of the gland. A rubber seal is also installed in the plastic housing.
The lower ring has a special recess for the spring.
Plastic gland housing.
Rubber seal in plastic gland housing.
Plastic gland housing without gasket.
The compressor sits tightly in the housing, so I took it out like this - turned it over and put it on wooden blocks and lightly tapped the housing.
Clean grease flowed out of it.
I took the compressor out of the housing.
The housing inside is perfectly clean!
I removed the sticker, because now I will definitely galvanize it.
What can I say about the condition of the compressor - it is practically in new condition! Everything is perfectly clean, in clean oil. There is no dirt.
I would show these photos to those "experts" who advised me to throw this compressor in the trash!
At first I was going to disassemble it completely, but the bearings are in perfect condition, there are no backlashes, everything is clean. In addition, to unscrew the bolts of the bottom cover, you need a pneumatic impact wrench again, which I, unfortunately, do not have yet. Therefore, I will not do this.
So, I made sure that the compressor is clean inside. I guess I could have safely installed it on the car right away, and not bother myself! But thanks to the "valuable advice of experts", now my compressor will not only work, but also be beautiful! ))
Everything will be thoroughly washed, cleaned, painted, electroplated, blued, new stickers - everything, as always! ;)
All bolts, housing and clutch pressure plates are sandblasted and ready for galvanizing.
New stickers are ready.
Everything is galvanized, I bought a new set of rubber seals, I also bought mineral oil.
Everything is ready for assembly.
P.S.
The "practice" assembly of the broken compressor has already been successfully completed! ;) Could be a good compressor too....
If it weren't for the holes in the case... )
The electromagnetic clutch is working, the front part has been restored - it will be in reserve.
The_Glory
Addendum to the previous post
In the previous post about the disassembly of the BOSCH BEHR R12 compressor, I had two questions. Thanks to smart people, I found the answers to them. So I'll add them here.
Question one:
What is the purpose of the internal thread on the clutch pressure plate?
Answer:
The internal thread on the pressure plate is just for the puller, so as not to hammer the disc with hammers and screwdrivers.
The puller itself is of such a plan.
This is the principle on many cars.
I think the principle of its operation is clear - the nut is screwed into the thread of the disk, the cone of the bolt rests against the hole on the shaft and when the internal bolt rotates, the disk is pulled off the shaft and the key. It's a clever device.
Question two:
What is the purpose of the plastic clip with a felt insert located between the cover and the compressor electromagnetic clutch?
Answer:
It's purely my assumption: a diagnostic element for checking the compressor seal. It looks like it can be removed by pulling on the ring and then inserted back. The shape is just such that it can be removed, and in what situation it can be removed, I don’t know)
Detailed answer:
This part is a felt oil catcher (often found in English as a compressor shaft seal felt pad or oil slinger).
It performs several very important functions:
Absorbing micro-oil leaks: The air conditioner compressor shaft seal (especially on classic compressors such as Denso or Seiko-Seiki) can leak microscopic doses of compressor oil during operation. This is considered normal. The felt sponge is installed just above the special drain hole of the seal and works as an absorber, absorbing these drops.
Electromagnetic clutch protection: This is the main task of the part. If this catcher were not there, centrifugal force would scatter the oil from the shaft directly onto the friction surfaces of the electromagnetic clutch (which is mounted on top of this unit). A greased clutch would slip, overheat, and fail quickly.
Dust boot: It also acts as an additional barrier that prevents dust, dirt, and abrasives from getting into the shaft seal from the outside, extending its service life.
So, this is a very simple but critical element for the longevity of the compressor clutch. Before installing the clutch, make sure it is securely locked in place.
Now everything is clear. Thanks to everyone for the answers.
The_Glory
Post Wed May 27, 2026 2:15 pm
Assembling the BOSCH BEHR R12 air conditioner compressor
Everything is ready - finally, you can assemble the compressor.
Santech rubber seal repair kit MT2107
The seals are signed according to the markings from the catalog.
M20-2171 internal compressor shaft seal (2pcs.)
M95-2108 internal cover seal
G95-3101 cover seal
M13-2107 external cover seal
M96-2140 gland seal
M13-2103 cover sleeve seal
M95-2101 inlet fitting seal
By the way, the markings are similar to the names of Soviet car models :)
Compressor assembly diagram and parts markings from catalog
By the way, I found a lot of useful information here:
https://bimmerlife.com/2025/02/04/e30-a ... r-rebuild/
https://www.bimmerforums.com/forum/show ... or-Rebuild
Thanks to the authors for this.
So, when assembling, you need to immediately lubricate everything with a thin layer of grease. I chose Errecom Mineral Oil 46 mineral oil. It took me a long time to choose, but I will write about it separately, when refueling the air conditioner.
Since I did not completely disassemble the compressor, I do not use the two internal seals M20-2171.
Lubricate the compressor and insert it into the housing in this position - the triangular arrow points to the fitting.
Lubricate and install the rubber internal seal of the cover M95-2108.
Put the spring on the shaft.
We put on the lower ring of the gland so that its protrusion coincides with the edge of the spring.
We lubricate and insert the gland seal M96-2140 into the plastic gland housing.
Put the gland housing onto the shaft so that the lower ring fits into its grooves.
Drive the key into the groove on the shaft.
Lubricate and put the M13-2103 cover sleeve seal onto the sleeve.
Insert the sleeve into the cover and secure it with the retaining ring.
Lubricate and insert the cover seal G95-3101 and the outer cover seal M13-2107 into the cover.
Carefully place the cover on the shaft. Make sure that the seals do not fall out of their seats. We tighten the four bolts with new washers from the seal repair kit.
These bolts were tightened with a lot of torque. So that when tightening them, the compressor does not turn in the housing, we insert eight bolts along the contour of the cover, but do not tighten them completely.
Now we tighten the four bolts with a hexagon. I don’t know exactly what torque, and I don’t have a dyno wrench. So I tightened it as hard as I could! )
Now you can fully tighten the eight bolts along the contour of the cover.
We lubricate and put the M95-2101 inlet fitting seal on the fitting. We fix the check valve with a spring on the fitting.
We carefully insert the fitting into the cover and fasten it with two bolts.
An interesting detail that I wrote about in the last post is the oil seal catcher.
It is simply placed in the groove according to its shape.
Located at the bottom of the cover. Leaking oil through a special groove falls on the felt insert and accumulates there. Right on the car, by pulling on the ring, it can be pulled out to check the tightness of the oil seal, or cleaned if the oil seal is leaking. Then insert it back into place. Simple and convenient.
Screw on the oil temperature sensor and the electromagnetic clutch diode.
We fix the wiring with a tie through the hole in the diode bracket. We stick a "12volt" sticker on the coupling.
We fasten the electromagnetic coupling with six screws.
The pulley bearing is in excellent condition, so I don't see any point in changing the original Japanese NSK bearing to a new Chinese one.
We put the pulley on the shaft until it stops.
Install the lock washer in the groove.
Tighten the nut and secure it by bending the "eye" of the washer.
Install the clutch pressure plate.
To fit with the required gap between the disk and the pulley, a metal spacer and washers of different thicknesses are used. There can be several washers. In my case, there are two of them. First, we put a thicker washer, then a thin one, then a spacer.
We put the disk on the shaft so that the groove falls on the key. The disk fits quite tightly, we even had to hammer it in a little until it stops.
We fasten the clutch pressure plate with a bolt and washer, holding it with a homemade wrench or something similar.
Next time, if necessary, I will use its internal thread for a special puller to remove the plate - now I know! ;)
We stick a sticker indicating the direction of rotation.
The compressor is assembled. It is advisable to immediately pour 100 milliliters of oil into it through the inlet fitting. The total volume is 200. The rest of the oil will be poured when refueling the air conditioner.
The final "touch" is a new sticker, which indicates the BOSCH, BEHR, BMW numbers and the serial number. It also indicates the type of freon R12, the type of oil D-90PX and its volume 200cm3. Made in Japan.
I have another question - why do you need a metal strip with a hole on the back of the case? It is definitely not for mounting the compressor. It looks like a terminal for the "mass" of the housing. But I haven't seen this in either ETK or ETM... Not used?
The compressor is ready for installation.
Beautiful! )
P.S.
Maybe I'm writing too much, but I've been looking for something like this for a long time, so let it be! ;) Maybe it will be useful to someone.
The_Glory
Post Mon Jun 08, 2026 11:12 am
Adapters for jacks
After a little fiddling, I finally pushed the compressor into place, from above through the hood, and even screwed it to the engine. But to put on the belt, tighten it and fix it, you need access from below. In addition, to put on the air conditioner compressor belt, you first need to remove the power steering belt. And to do this, you will probably have to remove the lower protective plastic shield. Since, unfortunately, I do not have a lift or a viewing hole, I will probably have to make a "mini-overpass" on the garage ramp again. Or try to simply raise the front part on both sides with two jacks.
I'll start with the simpler option - jacks.
I have been meaning to make some adapters for jacks for a very long time, so as not to scratch or bend the lower edge on the sills with them. Finally, this day has come! )
I found suitable pieces of iron in the garage, cut them, cleaned them.
And made such adapters for both of my jacks.
Two adapters in standard places, under the thresholds.
For one jack, we used its standard insert and welded a round steel washer and two supports from a 20x20mm square to it.
For another jack, a ring made of a pipe with a diameter of 50 mm, a height of 15 mm was welded to the steel washer from below.
I glued soft pads to the supports.
Two adapters for the silent block of the rear beam - rings made of a pipe with a diameter of 50 mm, a height of 40 mm. I put a rubber hose cut lengthwise on the end of the pipe.
Adapters in standard places, under the thresholds.
The adapter fits well in its standard place on the threshold, without touching its lower edge, and the BBS plastic pads.
Adapters for the silent block of the rear beam.
The adapter fits well under traction, without touching the nut and bolt of the beam.
I hope that now lifting the car will be easier and safer.
I also glued soft pads to the standard jack spacer so that, if necessary, it can be lifted under the side members or some other surface.
Now I can try to screw the compressor.
The_Glory
Post Mon Jun 22, 2026 12:42 pm
Assembly_201. ETK_64_Heating and Air Conditioning. (Part 12) Electromagnetic Clutch and Air Conditioning Compressor
Finally, it came to installing the air conditioning compressor on the car - the last part of the ETK on assembling and installing the air conditioning in a BMW E30.
Part No. 1 - Bosch/Behr electromagnetic clutch (64 52 1 386 297). Complete with bolt and mounting washer.
Part No. 2 - Bosch/Behr sealing profile (64 52 1 381 193). If I'm not mistaken, judging by the photo on the Internet, this is a plastic compressor shaft seal with a seal. I don't understand why it is shown in this section in the ETK, but I wrote about it in detail in the compressor assembly section.
Part No. 5 - Bosch/Behr thermal switch (64 52 1 385 417). Compressor oil temperature sensor with wiring.
Parts No. 3, No. 4, No. 6, No. 7 are not used.
Air conditioner compressor
Part #1 - air conditioner compressor (64 52 8 385 713). Freon R12.
Different compressors were used for the BMW E30 air conditioner - Bosch/Behr, Seiko/FER, DENSO/Hischier. There are many types of them in the ETK with different numbers. But the main difference is the type of freon. For early versions, R12 freon was used, and for later ones, the more environmentally friendly R134a freon. There are original conversion kits (82 31 9 067 394) from R12 to R134a. But I decided to try to leave the air conditioner on the old R12 freon. Although, this creates some problems with its refueling, due to the fact that it is already very difficult to find in stock. But we are not looking for easy ways! )) Especially since this freon cools much better. So I will try R12 first. If nothing works, then I will have to switch to R134a.
So, the Bosch/Behr compressor is restored and ready for installation.
AVX13x825 V-belt - I have already written about it in the relevant section.
ERRECOM Mineral Oil 46 Lubricant
I will write about the lubricant in more detail. For the old R12 freon, only MINERAL lubricant is used. For R134a freon, synthetic lubricant is used. After talking to our modern "experts", I got the impression that they are not concerned with this issue, and usually pour whatever lubricant they have on hand, regardless of the type of freon or the type of compressor. As a rule, it is something like PAO 68. When I asked about the viscosity of compressor oil, some "experts" were surprised and didn't even know that it can be different, just like for motor oil! )) Unfortunately, now there are only "tick-tock experts" around... So far I haven't been able to find a sensible specialist in car air conditioners who has a specialized education and understands how it works - there are only "refuelers" around who can only fill with whatever they can find. So I had to figure it out myself.
I don't claim to be the truth - all the information is from the Internet.
I found these tables on the use of lubricants for different compressors. Maybe it will also be useful to someone.
According to this table, the Bosch/Behr compressor uses D-90PX grease. This is also indicated on the sticker on the compressor. But I couldn't find such grease anywhere. The table shows PAG100 grease as an equivalent, but this is a synthetic grease that is used when converting to R134a freon. That is, in my case it is not suitable for R12 freon.
I found another table by car brand.
According to this table, for BMW E30 with R134a freon, PAO 68 synthetic grease is used, or according to the original ETK number (81 22 9 407 724), PAG 46 synthetic grease. That is, in both cases it is a synthetic grease, but of different viscosity.
In the same table for the BMW M3 E30 with a piston compressor and R12 freon, Suniso 5GS mineral oil is used. The viscosity of this oil is 100.
So, we already have four options for different lubricants, different viscosities... Probably, you shouldn't trust these tables too much...
So I thought and decided that it would be logical to take only MINERAL lubricant for R12 freon, but of the viscosity that BMW recommends according to the ETK - that is, 46.
It seems to me that this will be correct. After all, the type of lubricant depends only on compatibility with this freon, and the viscosity, regardless of the type of freon, must correspond to the type of compressor for its normal lubrication and operation. If I'm wrong, correct me. While it's not too late ))
So, we install the compressor. I installed its mount and tension bracket when assembling the engine. It would have been more convenient to do it from below, but due to the lack of a lift or inspection pit, I tried from above... ) After several attempts, I still pushed the compressor in and even screwed in the upper mounting bolt.
But there is no access to the tension bolt from above. Not to mention the belt. After all, in order to put the air conditioner compressor belt on the crankshaft pulley, you first need to remove the power steering belt from it. So, I had to raise the front part again on jacks and climb under the car. I really didn’t want to remove the lower plastic protective shield and brake air ducts. Therefore, it was very inconvenient. But I still screwed the compressor on.
It was also not easy to push the belt between the pulley and the viscous coupling impeller.
But it was possible - the belt is in place and tight.
Now all three pulleys are involved - generator, air conditioning compressor, power steering.
The compressor is installed.
But the most difficult thing was to tighten the power steering belt and screw in its pump through these ventilation holes in the lower protective shield... I struggled with this for a long time, but in the end, I screwed in the pump.
We connect the compressor wiring. I have a new dual low and high pressure sensor installed on the dryer. The low pressure sensor has a black connector, and the high pressure sensor has a white one.
My wiring was missing the connector for the high pressure sensor, so I had to restore it. Housing (61 13 1 378 417).
The connector for the low pressure sensor was for the old-style sensor - with two separate flat contacts and a rubber cap for the sensor.
So in order not to cut the wiring, I had to make another adapter for the new sensor.
Connect the adapter to the air conditioner wiring, and then connect the low pressure sensor to the adapter.
Connect the restored white connector to the high pressure sensor.
I previously wrote that my old compressor did not have an oil temperature sensor, so it does not have wiring for it. In fact, this is just a factory jumper that includes this sensor in series with the electromagnetic clutch wiring. The new compressor has this sensor. Therefore, we take the standard jumper and rearrange it in the empty places on the 3-pin connector of the air conditioner wiring.
We connect the compressor.
Earlier I asked why there was a metal plate with a hole on the compressor. One of the answer options was - a hole for the clip fixing the compressor wiring. I liked this option. I don't know if it was like that at the factory, but I installed a wiring holder there and fixed the compressor wiring with it.
By the way, while I was pulling the wiring there, I noticed that water started to drip a little from the seal of the washer tank pump. I bought all three new seals, I will change them later just in case.
I hid all the connectors under the washer tank, fixed the wiring with a tie to the other harnesses.
All that remained was to screw on the two hoses.
Pre-filled the compressor with 100ml of oil.
The total oil volume is 200ml, but the rest will be filled in when filling the system.
And then I had a bad luck... As was the case with the ABS unit fitting, the outlet hose fitting does not want to be screwed into the thread.... I still don't know what to do with it...
And that's not all... The inlet hose fitting has a special bend for the compressor flange, which is installed at an angle. On my compressor, the flange is installed vertically, so the hose does not reach it...
That's such a mess... But I will solve this problem - I will rearrange the flange from my old broken compressor. It has the right shape. It's not for nothing that I restored it too, although its condition is a little worse... But what to do with the damaged thread, I haven't figured out yet...
And the "finish" was so close..... )))
P.S.
If anyone in Kyiv has contacts of a smart R12 air conditioner repairman, I would be grateful if you could share them. But, specifically a repairman, not a "refueler" :)
