M30 swap again :( (alilve again :))
Good new's, another E30 M30 is born
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
blingsta
- Boost Junkie
maybe now i can try driving your car and see what the 3.64 lsd is like !!
- E30 Zone Meets/Events Team
Nice one Zaust, back on the road again
stembo21
dint take long at all. i think i might put one in mine how much did it ll cost you
zaust
- Zone day release
zaust
- Zone day release
johnl320
Good to hear its back on the road
john
john
Mine don't spin in third, i think its underpowered
DRIFTBOY
Maybe your tyres are too good!
What ecu are you using Marc?
zaust
- Zone day release
179. so i'm impressed. only took ten min's before i was told tp pee off and have some fun.
Will be going msd after i have sorted coilovers, but that won't be till next year now. the engine really reacts well to a map. (much better than m20
also rebuilt sal's passanger seat today which was the last job on the list before the mot. so she should be back in the 2 tone with in a month.
DRIFTBOY wrote:Maybe your tyres are too good!![]()
Pirelli P Zeros
DRIFTBOY
Not Wingchungyang Ditchfinders then!
DRIFTBOY
zaust wrote:179. so i'm impressed. only took ten min's before i was told tp pee off and have some fun.
That sounds very good, I didn't even know it was possible!
DRIFTBOY wrote:Not Wingchungyang Ditchfinders then!
blingsta
- Boost Junkie
who done the re-map mate ?
zaust
- Zone day release
Not from stand still. When changing up in to third at a decent pace, Traction is lost and i'm tramping up the road at --mphDRIFTBOY wrote:zaust wrote:179. so i'm impressed. only took ten min's before i was told tp pee off and have some fun.
btw michelin sport with lot's o tread....
zaust
- Zone day release
DRIFTBOY
I meant I didn't know it was possible to re-map that ecu like that!zaust wrote:Not from stand still. When changing up in to third at a decent pace, Traction is lost and i'm tramping up the road at --mphDRIFTBOY wrote:zaust wrote:179. so i'm impressed. only took ten min's before i was told tp pee off and have some fun.
I know about the third gear traction breaking!
zaust
- Zone day release
Is that a standard ecu????
I didn't know you could mess about with it, without dropping another chip into it.
zaust
- Zone day release
Mine is doing the same, over fuelling like fook
Changed the afm too, blue temp switch and back on the co readings, high again.
If you don't mind, but how much was it all in, i might be looking to have it done too.
BTW, was it idling like a dog too??????
zaust
- Zone day release
mine idels a bit lumpy, but thats the map as the values have been moved more to the mid and top end. I can't say how much i paid as it was a one off mates rates price. but it is the best bang for bux i have ever spent
speed touches chips have all had good feed back and i know ants chips are good. so you shouldnt have to spend that much. msd will give the best results but 800 is a lot to come up with for a max of 20 hp extra.
zaust
- Zone day release
zaust
- Zone day release
Loving the "Check light" location.
BTW, what's the silver tank and the 2 hoses going to the inlet rubber for???
zaust
- Zone day release
zaust
- Zone day release
Looking good, should be great fun with the NOS
gareth
loving the coil mounting bracket!
could you not use the empty washer bottle mounting stud with one of those plastic nuts to fix the bracket?
zaust
- Zone day release
It is bolted in but I did not have long enough to move everything. It will be moved to a new point not the water bottle stud(strength not good), and the bracket for the induction will be renewed as I have used a cdl mounting bracket for the mo, Need to make a heat shield for it too.
I have seen a very small washer bottle on the demon tweaks site that will sit i there too.
More next monday
More next monday
gareth
i seem to recall something about E34 washer bottles fitting there.
I've got a Vitara one on the old M20 AFM cracket and that fits quite well.
zaust
- Zone day release
This one ↓↓↓ will e nice and neat tucked away.
http://www.demon-tweeks.co.uk/products/ ... =MAXMXP127
E34 washer bottle fits a treat, like it was meant to.
