M30 swap again :( (alilve again :))
Post Mon Jun 01, 2009 9:49 pm
Good new's, another E30 M30 is born :cool: :cool:
zaust
Zone day release
Post Tue Jun 02, 2009 8:34 am
ImysE30 wrote:Good new's, another E30 M30 is Re-born :cool: :cool:
M30 Tech 1 Touring on gas.
blingsta
Boost Junkie
Post Tue Jun 02, 2009 3:03 pm
maybe now i can try driving your car and see what the 3.64 lsd is like !!
Post Tue Jun 02, 2009 3:06 pm
Nice one Zaust, back on the road again :cool:
stembo21
Post Wed Jun 03, 2009 11:40 am
dint take long at all. i think i might put one in mine how much did it ll cost you
zaust
Zone day release
Post Wed Jun 03, 2009 11:54 am
Cheer's guy's, Drove to rochester to see wilson the same evening. It pulls really well and sounds healthy.
Stembo it is a cheap conversion. 270 for the donner. 100 for the mounts and 100 for the prop. oil plugs filter and plop it in.
zaust
Zone day release
Post Mon Jun 08, 2009 7:30 pm
Had a re-map done today... :) spins up in third no prob's.... got the afpr and induction kit to do next, then slight adjustment of the map and I can't wait.
johnl320
Post Mon Jun 08, 2009 8:20 pm
Good to hear its back on the road :D
john
Post Mon Jun 08, 2009 8:57 pm
Mine don't spin in third, i think its underpowered :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
DRIFTBOY
Post Mon Jun 08, 2009 9:01 pm
Maybe your tyres are too good! :D
What ecu are you using Marc?
zaust
Zone day release
Post Mon Jun 08, 2009 9:46 pm
179. so i'm impressed. only took ten min's before i was told tp pee off and have some fun.
Will be going msd after i have sorted coilovers, but that won't be till next year now. the engine really reacts well to a map. (much better than m20 winkeye )
also rebuilt sal's passanger seat today which was the last job on the list before the mot. so she should be back in the 2 tone with in a month.
Post Mon Jun 08, 2009 10:08 pm
DRIFTBOY wrote:Maybe your tyres are too good! :D
Pirelli P Zeros
DRIFTBOY
Post Mon Jun 08, 2009 10:11 pm
Not Wingchungyang Ditchfinders then! :D
DRIFTBOY
Post Mon Jun 08, 2009 10:12 pm
zaust wrote:179. so i'm impressed. only took ten min's before i was told tp pee off and have some fun.
That sounds very good, I didn't even know it was possible! 8)
Post Mon Jun 08, 2009 10:17 pm
DRIFTBOY wrote:Not Wingchungyang Ditchfinders then! :D
:lol: :lol: :lol: :lol:
blingsta
Boost Junkie
Post Tue Jun 09, 2009 1:23 am
who done the re-map mate ?
zaust
Zone day release
Post Tue Jun 09, 2009 8:45 am
Not from stand still. When changing up in to third at a decent pace, Traction is lost and i'm tramping up the road at --mph :)
btw michelin sport with lot's o tread....
zaust
Zone day release
Post Tue Jun 09, 2009 8:46 am
blingsta wrote:who done the re-map mate ?
Adi
DRIFTBOY
Post Tue Jun 09, 2009 11:24 am
I meant I didn't know it was possible to re-map that ecu like that! :)
I know about the third gear traction breaking! winkeye
zaust
Zone day release
Post Tue Jun 09, 2009 4:56 pm
Was just a case of look at the value's and have a play.
Post Tue Jun 09, 2009 6:28 pm
Is that a standard ecu????
I didn't know you could mess about with it, without dropping another chip into it.
zaust
Zone day release
Post Tue Jun 09, 2009 6:41 pm
Sorry should have said. It is one of jason's (chipped uk) chip's. But it was fueling like hell in low revs at first. So was removed played with and now :) all the way.
Post Tue Jun 09, 2009 8:20 pm
Mine is doing the same, over fuelling like fook
Changed the afm too, blue temp switch and back on the co readings, high again.
If you don't mind, but how much was it all in, i might be looking to have it done too.
BTW, was it idling like a dog too??????
zaust
Zone day release
Post Wed Jun 10, 2009 12:48 am
mine idels a bit lumpy, but thats the map as the values have been moved more to the mid and top end. I can't say how much i paid as it was a one off mates rates price. but it is the best bang for bux i have ever spent :) speed touches chips have all had good feed back and i know ants chips are good. so you shouldnt have to spend that much. msd will give the best results but 800 is a lot to come up with for a max of 20 hp extra.
zaust
Zone day release
Post Mon Jun 15, 2009 3:23 pm
Cleaned and then decided to pint the rocker, Catch tank re-located, early coolant bottle re-located to the batt tray, afpr fitted (set@3.4)
Just need to get the nos hooked up and the bbtb in and on and thats it for a while.
zaust
Zone day release
Post Mon Jun 15, 2009 3:39 pm
Still need's a lot of snagging done and the in-let need's doing.
Post Mon Jun 15, 2009 3:45 pm
Loving the "Check light" location.
BTW, what's the silver tank and the 2 hoses going to the inlet rubber for???
zaust
Zone day release
Post Mon Jun 15, 2009 3:52 pm
Catches moister and excess crap that would otherwies go back into the intake. (from rocker to tb boot)
zaust
Zone day release
Post Mon Jun 22, 2009 5:07 pm
Had a couple of hour's spare. So I have made a intake for the over kill k&n and added the solinoids for the nos :)
Post Mon Jun 22, 2009 5:12 pm
Looking good, should be great fun with the NOS :twisted: :twisted:
gareth
Post Mon Jun 22, 2009 6:53 pm
loving the coil mounting bracket! :D
could you not use the empty washer bottle mounting stud with one of those plastic nuts to fix the bracket?
zaust
Zone day release
Post Mon Jun 22, 2009 7:14 pm
It is bolted in but I did not have long enough to move everything. It will be moved to a new point not the water bottle stud(strength not good), and the bracket for the induction will be renewed as I have used a cdl mounting bracket for the mo, Need to make a heat shield for it too.
I have seen a very small washer bottle on the demon tweaks site that will sit i there too.
More next monday :)
gareth
Post Mon Jun 22, 2009 7:20 pm
i seem to recall something about E34 washer bottles fitting there.
I've got a Vitara one on the old M20 AFM cracket and that fits quite well.
zaust
Zone day release
Post Mon Jun 22, 2009 8:04 pm
This one ↓↓↓ will e nice and neat tucked away.
http://www.demon-tweeks.co.uk/products/ ... =MAXMXP127
Post Mon Jun 22, 2009 9:41 pm
E34 washer bottle fits a treat, like it was meant to. :cool:
