M52 b30 stroker rebuild back on the road
Post Sun Jul 19, 2015 4:37 pm
gonna pull this engine and box and put the 2.8 back in with an untested by me e36 zf box i've had lying around for a while . i've bought a 328i manual prop and new e30 centre bearing .
if i bolt the zf box to the b30 then the 6-speed might never find it's way back in the car .. so a bit method in the madness .
wonder how much this box is gonna cost to refurb :cry:
Post Thu Aug 06, 2015 3:31 pm
after 1200 miles another sachs clutch explodes 8O :x
this should solve the problem , stage 2 clutch !
not even gonna put a smiley on !!
Post Thu Aug 06, 2015 7:56 pm
Is the cover a modified Sachs one Mick? Looks like the same cover as the kit I've just bought
Post Fri Aug 07, 2015 12:25 am
yeah it's a sachs cover , the friction plate has an luk stamp on it :mad:
jmc330i
Post Fri Aug 07, 2015 11:47 am
What would cause it to explode like that?
magpie wrote:yeah it's a sachs cover , the friction plate has an luk stamp on it :mad:
This is the combination I'm running on my touring :? I'm not overly impressed.
James
'91 325i Sport
'93 318i touring 16v
Post Fri Aug 07, 2015 1:33 pm
The guesstimation is that its not a 325i clutch, more likely a 525e clutch which is designed for a car with less power.
The CG clutch is a Sachs part but has uprated diaphragm spring and straps, the only Sachs part is the outer housing of the cover. The LUK centre plate also has uprated springs and friction material, again its just the hub itself that is LUK
Ive just bolted up a dual friction one this morning
jmc330i
Post Fri Aug 07, 2015 1:41 pm
DanThe wrote:The guesstimation is that its not a 325i clutch, more likely a 525e clutch which is designed for a car with less power.
Thanks Dan.
Is it worth getting the CG clutch over a standard Sachs 325i clutch?
I'm wondering if I've got a 325e clutch in mine. It seems to struggle with the M44 :?
James
'91 325i Sport
Post Fri Aug 07, 2015 1:51 pm
Pic in here - http://www.e30zone.net/modules.php?name ... 96#2860396
Ive never used one before but sure to find out what they are like soon :D
Post Sat Aug 08, 2015 11:31 pm
we are going with the theory that they build the covers from a sachs base cover, same again using the luk clutch plate centre housing . when i enquired about my order they said it was in the workshop
proof is in the pudding as you say mate , gotta run it in first though.
Post Sat Aug 08, 2015 11:59 pm
hotross wrote:
Jesus.. you not had much luck..
i get shat on from great heights ,nothing else will do !
Post Thu Sep 17, 2015 10:35 am
well that clutch lasted not long ha ha , f00kin straps were made out of toffee !
it appears the cover straps on these stage 2 clutches are standard sachs shizzle and there are only two of them as opposed to the newer sachs cover plates which have x3 straps so they are using old stock . they said they would upgrade the cover straps for me @ £40 all inc so i was off to leeds the next day to get this shit sorted out once and for all .
[ i thought i had bought a clutch that would take abuse and not fail on the first ask of a bit of spirited roundabout hoping ]
knock knock ...any thieving coonts in ?
any way trying to remain calm and sort it out i was soon on my way home with x3 thicker straps on the cover ....this is what i should've been given for £266 delivered in the first place
:roll:
engine and 5 speed box back out [ i fitted the 5 speed due to the tick over noise from the 6-speed and promptly went back to 6-speed with this uprated, uprated clutch lol ] 6-speed ready to go back in .... it's the tits over the zf 5 speed .
yup ^^^^ thats f00ked it :(
new thicker straps ... how it should of been done !
ep90 is good shit 1st 2nd are a bit stiff when cold but the noise is halved on tick over so that'll do me .
aaand back on the road with 300 miles under it's belt this time and feels strong !
i'm off to york raceway this saturday for a pre- santa pod shakedown :woohoo:
jimbom30cab
Tech 1 freak
Post Thu Sep 17, 2015 10:54 am
Nice one, might give that EP90 a go...
Post Mon Jan 25, 2016 1:07 am
looking forward to another year of spanner rash and car meets :D
Post Mon Feb 22, 2016 12:53 am
gathering parts again ... a few upgrades on the way .
anyone else think winter is getting longer ?
Post Mon Feb 22, 2016 8:47 am
Winter? It was about 12°C here yesterday :mad:
maggspower
Turbo Farmer Tractor Driver
Post Mon Feb 22, 2016 9:36 am
Monsoon season here, 80 days of rain :( We used to take the pi55 out of those with webbed feet, not any more :)
Post Sat Mar 05, 2016 8:27 pm
been getting a few things ready for this season .
1. a nice short , short shifter
2. an illuminated 6-speed evo m3 gear knob and gaiter
3. helix clutch cover and paddle clutch
4. 3.25.1 M3 LSD with the full works 40% lock up etc by Gareth , getting this off a long term Moderator who is going to deliver it in April :D
5. had my RG's refurbed in hyper shoiter extra flake silver for a bit of bling and new 225 rear tyres :)
6. pair of bucket seats [ recliners ] on e30 rails but sit too high so need a bit of work , not sure if i'm keeping these yet .
compared to the last 5 or 6 years of winter spending £££££'s .... i've done quite well this year :D
Post Sat Mar 12, 2016 12:48 pm
pulled the car out of the garage for a quick check that it starts and all the electrics still work .................
aaand fitted the wheels 8)
still need to pull the engine out again and do the clutch though :cry:
Post Fri Mar 18, 2016 11:56 am
my new diff arrives tomorrow Hand delivered , happy that it's moved forward a whole month and can fit it straight away before i do the clutch .
something else i've been looking into and finally purchased has arrived .
I can smell car parts..... maybe even new brakes ?
Oh yes yes yes !
Post Fri Mar 18, 2016 2:21 pm
magpie wrote:pulled the car out of the garage for a quick check that it starts and all the electrics still work .................
Like the BMW E30 grille & headlamps above the garage doors - nice touch. 8)
Post Fri Mar 18, 2016 2:53 pm
Had to be Done :D
Post Fri Mar 18, 2016 6:16 pm
Indeed. Do the lights actually work? winkeye
Post Fri Mar 18, 2016 11:06 pm
that was the main plan but had to cut the back off the lights and involve some blue peter skillz with a roll of uber executive reflective tin foil for effect . i couldn't be arsed to core drill the panel and have a 12v charger hooked up with some sort of pir detector .... i did give it some thought though using something like this
http://www.ebay.co.uk/itm/22-LED-SOLAR- ... SwwpdW2H3J
i prefer changing engines tbh :D
Post Sat Mar 19, 2016 10:25 pm
my 40% lock up diff has Arrived :D
worked on by Gareth and delivered by Baddave the highlander moderator tonight .
thanks very much Dave if you ever read this ... Legendary stuff 8)
Cypriotgeeza
Post Sun Mar 20, 2016 11:12 am
magpie wrote:my 40% lock up diff has Arrived :D
Same ratio as mine 8)
Loving the progress as always mick! :thumb:
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
Post Sun Mar 20, 2016 9:31 pm
cheers Geeezza , looking forward to driving it again this year but not the spannering as much :D
whats the best oil to use in this diff ?
BenHar
Post Sun Mar 20, 2016 10:17 pm
Castrol SAF-XJ.
Ben
Post Sun Mar 20, 2016 10:25 pm
BenHar wrote:Castrol SAF-XJ.
Ben
gracious 8)
Post Sun Mar 20, 2016 10:29 pm
BenHar
Post Sun Mar 20, 2016 11:52 pm
Syntrax is the later version and should be fine.
The first ad is a bit worrying because the picture seems to show SAF-XO. Might be my eyes though.
Ben
Post Fri Mar 25, 2016 9:21 pm
the seller of the first link confirmed SAF-XJ and Gareth approved it so i purchased 2ltrs and saved some money ,and on that note >>>>>
i decided to fit the willwoods this afternoon and realised i need to lose my dust shields , i'm not going to cut them up as they are in vgc so i'll remove them properly .... i could do with new front wheel bearings any way tbh .
i managed to get a pair of GSF front hubs for £76.80 , cheers for the heads up on that Craig ;)
Subtotal (Excl.Tax) £112.28
Subtotal (Incl.Tax) £134.74
Shipping & Handling £0.00
Discount (Easter43) -£57.94
Grand Total (Excl.Tax) £64.00
Tax £12.80
Grand Total (Incl.Tax) £76.80
i have done a clearance check with the wheels and it's all good to go , watch it rain for two weeks now :roll:
Post Fri Mar 25, 2016 9:41 pm
Whats the crack with the Helix clutch? You going to use that instead now?
Post Fri Mar 25, 2016 9:55 pm
i'm gonna try an e30 slave or am i pissing clutch fluid away ? my bite is high but could be down to the 2mm clutch fork weld add on ?
if i do the slave change and it's no good i'll do the clutch swap .... or that's what i'm kidding myself with lol .
there is a buttertubs run meet thingy going on early April through yorkshire dales country that i want to do , i think i could nurse the bitch through it before i pull it apart again as it is , after all it made it to pod and back like it is :D
i just need to give it less abuse and it responds ... no fun it that though :mad:
Post Fri Mar 25, 2016 10:08 pm
Nothing wrong with a high clutch release, less work for the clamping springs, just make up a clutch stop. Over use of the pedal wears the springs out faster.
Fitting an E30 slave on an E36 box is a waste of time, it will just explode in the bell housing :D
Post Fri Mar 25, 2016 10:42 pm
thing is when it heats up it slips .
