if i bolt the zf box to the b30 then the 6-speed might never find it's way back in the car .. so a bit method in the madness .
wonder how much this box is gonna cost to refurb
This is the combination I'm running on my touringmagpie wrote:yeah it's a sachs cover , the friction plate has an luk stamp on it
Thanks Dan.DanThe wrote:The guesstimation is that its not a 325i clutch, more likely a 525e clutch which is designed for a car with less power.
The CG clutch is a Sachs part but has uprated diaphragm spring and straps, the only Sachs part is the outer housing of the cover. The LUK centre plate also has uprated springs and friction material, again its just the hub itself that is LUK
i get shat on from great heights ,nothing else will do !hotross wrote:
Jesus.. you not had much luck..
Like the BMW E30 grille & headlamps above the garage doors - nice touch.magpie wrote:pulled the car out of the garage for a quick check that it starts and all the electrics still work .................
aaand fitted the wheels![]()
Same ratio as minemagpie wrote:my 40% lock up diff has Arrived![]()
worked on by Gareth and delivered by Baddave the highlander moderator tonight .
thanks very much Dave if you ever read this ... Legendary stuff
graciousBenHar wrote:Castrol SAF-XJ.
Ben
